Sony DVP-NC80V DVD Player Logo
Posted on Jul 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
System shuts down while playing movie
After about 10 minutes of watching a DVD, the system shuts down. Both the Sony DVD (NC80V) and the Receiver (Denon AVR 3805). Is this a problem with the DVD player or the Receiver? I don't have this problem while watching T.V. (using the receiver for sound), so I'm inclined to think it's the DVD. As a side note, this problem started occuring around the same time a got the "circle of death" message on my X-box 360. I have diconnected the x-box, but still have the problem. Could the over-heating of the x-box (assumed cause for the circle of death message) have caused damage to the DVD and/or reciever?
What would be your recommended next steps?
  • djett Jul 17, 2008
    So what is the reommended next steps in correcting this problem? Buying a new DVD Player / AVR receiver? How do I determine which component is causing the problem?
Anonymous
Level 3:
Master:
  • Master 497 Answers
  • Posted on Jul 17, 2008
Anonymous
Master
Level 3:
Master:
Answers
497
Questions
0
Helped
221237
Points
1118
I recommend u disconnect the dvd player from the receiver and try it in another system... maybe a neighbor or friend could help out. If it works ok in another system, then maybe an interface problem exists; bad cables, wrong connections, etc.
Thanks for using Fixya
Anonymous
Level 3:
Brigadier General:
  • Master 6,966 Answers
Anonymous
Master
Level 3:
Brigadier General:
Answers
6966
Questions
17
Helped
3088637
Points
19604
Initially, may I inquire how the system as physically placed in relation to each other? Is it atop one another, along a single shelf? It would appear heat related instigated by the Sony and spilled over to the Denon. Would there be sufficient ventilation space in between the units?
Other than the above, it could be a faulty power strip or mains outlet. Pls try alternative mains source.
If it is heat related, forced ventilation or relocating unit placement might be corrective.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 417 Answers
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
417
Questions
Helped
99436
Points
802
No should not of damage it
I Only Can Say It Could be Power Shorting out shutting it off
this is a strange one make sure the power is not over loaded more than 3 or 4 things connected to one power point
  • Anonymous Jul 17, 2008
    I Think It May Be Shorting out
    try putting it in area well ventilated could be overheating aswell
Ginko
Level 3:
  • Sony Master 19,396 Answers
Ginko
Sony Master
Level 3:
Answers
19396
Questions
25
Helped
8073272
Points
55462
It is probably a oveheating problem
  • 3 more comments
  • Ginko
    Ginko Jul 17, 2008
    Try turning on the devices separately, with cables not connected to each other, and see which one turns off.
    It is one of the devices overheating and messing the whole system. Test them out and post result of the test back here for more troubleshooting.
  • Ginko
    Ginko Jul 17, 2008
    Regarding the "circle of death" message, it often happens because of a bad update, if the Xbox was connected to Internet and doing update it is possible that the first power cutoff caused it.
  • Ginko
    Ginko Jul 17, 2008
    Did you do what I told you?
    You jump to buy a new dvd, test your devices first.
  • Ginko
    Ginko Jul 17, 2008
    If all stuff turns off at exactly same time, it does not mean they are
    all overheating or all faulty. One of the devices is faulty, when it
    goes off it returns electric feedback to the rest of the system and
    they go down at same time.
  • Ginko
    Ginko Jul 17, 2008
    To find out what component is going down connect them separately (no rca, hdmi, composite, scart, or whatever cable you use to connect devices one to the other)
    If everything works fine then it is a bad cable.
    If not replace or repair faulty unit.
    About the circle of death, if you cannot get rid of it Microsoft will replace your Xbox, just claim you were doing an update.
    To contact uncle Bill at Microsoft US:
    Online Chat - available Monday through Friday, 11 A.M. to 8 P.M. (Eastern Time).
    For U.S. customers only; international customers, please visit Microsoft Worldwide page to choose from Microsoft sites worldwide.
    Contact by e-mail - you will receive an e-mail response within one business day.
Dennon gets hot shuts off
how are your four outside speakers hooked up? If you have four speakers hooked up to only two output channels on the receiver, the receiver is sensing a short and shutting down to avoid damage to the amp.
1helpful
Dear Sirs, Recently, my Sharp dvd-video combi player has been encountering some problems regarding the playing of dvd's. When I watch a movie, in several occasions the movie will freeze up. And for...
the DVD unit in your sharp is a self contained unit. IT is only repaired by replacing the DVD as a assembly. the cost of replacing may exceed the cost of purchasing a new one.
The most likely cause of your problem is in the brass gear assy that runs the optical pick up in the traverse deck. IT is not an available part.
Bought a samsung dvd home theater system HT-X70 off of ebay and its plays beaytifully for like 10 minutes into the movie and then all the sudden it flashes "PROTECTION" and then shuts off. I unplud it and...
Sounds like a heat problem, look on the back of the player and see if the fan is full of debris ( dust, pet hair, ect.) blow it out and see if that helps.
PS3 freezes but sound still works
when it happens, give it some time, like 5-10 min. the ps3 is most likely accessing the hard drive, and if it is, shutting down in the middle of it could currupt your hdd. if it doesnt work, even after 10 min, call sony tech support, but if it works fine afterwords, i dont see why it would be neccessary. unless it gets worse, i think you should just turn it on, turn it off after a few min, then back on, and then play.
2helpful
2answers
Movie recording disabled
   Just delete unuseful data from drive or connect the camrea to your pc cut the required movie and paste it on your pc drive then it will work.
Thanks for using fixya.
6helpful
2answers
Receiver overload problem
The overload message is indicating that a problem was found and the system is shutting down the output section to prevent further damage. There are probably poor connections on the main board and failing capacitors in the front end. Expect a parts vcost in the $10 range. Add in the local labor rate for the total repair bill.
Dan
Player suddenly freezes
Try running a dvd cleaner through it first, before trying anything else (the type that looks like a DVD with a brush underneath).
The regular DVD might have been a fluke (scratches, rental?, burned dvd?)
Was there anything special about the new Blu-Ray Disc - what was the tile? On certain titles, you may need the firmware upgrade found at:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=BDPS300
2answers
Philips FTR 9964 Receiver Problem
The problem is in your cable connection on the back of your monitor or Box. I had the same problem and solved it by reattaching the VGA cable that was loose.
No color only black and white
Here's a link to a similar problem - http://www.fixya.com/problems-solutions/t103270,p181041/LG-DVD-Players.aspx post back if it doesn't apply
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
