Sunbeam Stick Blender type 737 Model SM 8650 the inside part you push into the bottom section has broken can it be fixed, if yes, where do I take it, I live in Perth
ThaMp3Doctor
  • 8596 Answers
SOURCE: Replace the glass pitcher for the Margaritaville blender
Replacement pitchers here:
http://www.margaritavillecargo.com/Accessories.aspx
-Tha Mp3 Doctor
Posted on Mar 31, 2009
SOURCE: Sunbean Blender Liking problem
I have a better than original seal made of a material approved by the FDA. Let me know if you are still interested.
Cheers,
JJ
Posted on Apr 07, 2009
SOURCE: Broken glass jug on kitchenaid blender model 5ksb2aer4
Look at the underside of the blade shaft. The metal wing nut on the end of the shaft secures the blade assembly to cream coloured plastic blade base. The wing nut also transmits the drive from the rubber coupling on your blender to the blade shaft. The wing nut has a LEFT HAND thread.
The left hand thread ensures the blade assembly does not unscrew during normal blender use.
Firstly disassemble the blender blade assembly. Place a folded tea towel over the blades and hold the blades firmly. If you do not use a tea towel you may cut yourself.
Grip the wing nut with your other hand and unscrew it CLOCKWISE.
Remove the wing nut. You can now remove the blade from the plastic base.
Put the blade assembly in the new jug and offer up the plastic base from under the jug so that the blade shaft protudes enough for you to install the wing nut.
Screw the wing nut ANTI-CLOCKWISE to secure the blades to the plastic base.
Do not over tighten the wing nut; you may have to replace your jug again at some point.
Posted on Jul 21, 2009
  • 38 Answers
SOURCE: Blades on inside of kitchenaid blender jar won't turn.
look on ebay for a replacement second hand unit
Posted on Nov 09, 2009
woodchuck789
  • 4070 Answers
SOURCE: bottom freezer section iced up solid.-- Fan inside
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others. You can post your model number into one of several appliance parts sites on the internet and search for defrost components to find your parts.
Posted on Feb 19, 2010
Switch on Toastmaster stick blender model 1740 is broken.
Superglue a small tab of cut from an aluminum sheet to the the broken plastic tab. Drill a small hole in the aluminum tab to grab the protrusion in switch housing.
Apr 05, 2014 | Toastmaster 2 Speed Stick Mixer
I have a sunbeam blender model #6094 and the blade is discontinued, is there any others that would fit this model? Thanks, Lisa
If the blade has been discontinued by Sunbeam, maybe they can suggest a substitute.
Jan 10, 2014 | Blenders
Sunbeam 2774 Blender Logo Problem with the Sunbeam 2774 Blender I need a gasket for my sunbeam blender #2774.
The gasket is not available by itself, you need the blade assembly part number 123250-000-000 available from Sunbeam at 1-800-458-8407.
Aug 13, 2011 | Sunbeam 2774 Blender
Have a sunbeam oster kitchen centre....mixer,blender, sausage maker...but no manual..1985 -86 model...help. #97108C ON MAIN BODY.It has stainless bowls, glass blender jug. Sure would love a manual.Thanks.
I have an Oster Kitchen Center by sunbeam. It has the mixer, blender and food processor. When I attach the processor to try to use it the blades do not spin. If I push the siler know down with an objest it will turn. Am I missing some little piece to make it work.
Sep 13, 2010 | Oster Food Processors
Broken glass jug - Sunbeam blender PB7600
I have one, marlene 0409465707
Aug 26, 2009 | Blenders
Wolfgang puck bistro blender won't turn on, need
I had the same problem. There's a little button on top of the base that is supposed to get pushed in by a male-type piece on the bottom of the pitcher. I broke a match stick and duck taped it so that it pushed in the button on the base - Voila! it works!
Jul 06, 2009 | Blenders
Jeff Gordon Blender blew up
Sorry to say we do not repair. You will have to contact sunbeam here at this link for service.
http://www.sunbeam.com/index.aspx?section=kitchen
Good luck and Please Rate FixYa1!
Dec 28, 2008 | Sunbeam Jeff Gordon NASCAR 12 Speed...
Computers & Internet Logo
202 people viewed this question
David Payne
David Payne
