Question about Acer Aspire 5600 Series 5630-6951 Laptop
A/C RECHARGE I am trying to recharge the a/c for my 1992 Acura L. legend the engine is a 3.2 L. I can not locate the hide side or the low side and there is no indication as far as red or blue for either .....Please let me know
    Genius:
  • 2,028 Answers
You might want to repost this. It has shown up in the laptop category. You will get a better response in the automotive section. IN my experience, I had a Kia that the lines were marked with a + & - instead of red and blue. Don't know if this helps, my area is laptops.
Posted on Jul 18, 2008
Where is the freeze plug located on a 1991 Acura Legend
more info on freeze plug failure? - The Acura Legend & Acura RL Forum
www.acura-legend.com/vbulletin/.../more-info-freeze-plug-failure-1436...
May 29, 2010 - 5 posts - ‎2 authors
my mechanic told me that my freeze plugs could have failed, i have already searched ... Car 1: 1991 Acura Legend ... Car 1: 94 acura legend ls. anti freeze leak
May 11, 2010
Easiest way to
Jul 17, 2007
Manual transmission fluid change help
Apr 7, 2007
engine block heater?
Dec 21, 2003
More results from www.acura-legend.com
Where is the freeze plug located on a 1991 Acura Legend ...
www.fixya.com/cars/t26009696-freeze_plug_located_1991_acura_legend
1 hour ago - where is the freeze plug located on a 1991 Acura Legend - Acura Cars & Trucks question.
Acura Legend leaking freeze plug Questions & Answers ...
Dec 16, 2015 | Acura Cars & Trucks
Fuel pump fuse location 1992 acura legend
fuel pump fuse is located under the dash on the driver's side. Look for THIS -
The fuel pump relay is located underneath the dash, driver's side, up behind the metal panel (behind the plastic kick panel). It is NOT plugged into the fuse panel.
See #18 in this diagram -
Feb 20, 2014 | 1992 Acura Integra Hatchback
Where is the low ac suction side located on a 1992 buick regal
First find the A/C compressor, it is attached directly to the engine and has a pulley on it. When you turn on/off the A/C while the engine is running you should be able to locate it by listening for it to engage.
When you find it you need to trace the two metal pipes that come out of it. One pipe is the high pressure side and one is the low. You will know which one is the low side when you find the 'tee' with a plastic cap (both high and low have one).
The fitting that comes with the A/C recharge kit will only fit properly on the low pressure port. Sometimes, but not always the low pressure port has a blue cap.
Jun 19, 2011 | 1992 Buick Regal
Where is the thermostat located on a 1994 acura legend
Hi:
The thermostat is located under the thermostat housing, which is on the engine, and what the upper radiator hose connects to. To remove the thermostat, you should : 1) start with a cool engine, 2) drain the coolant 3) disconnect upper radiator hose 4) unbolt thermostat housing. To install, reverse the process, but make sure you have a new gasket for the housing, and clean up the mating surfaces on both the housing and the engine.
May 05, 2010 | 1992 Acura Legend
Where is the Fuel Filter located in a 1992 acura Legend?
The filter is located in the passengers side of the engine compartment. It looks like this!!!
Oct 02, 2009 | 1991 Acura Legend
1994 Acura Legend check engine light is on. When
turn the ignition key to the acc or lock position with the odometer reading showing.
while holding the trip/reset button turn the ignition to the on position. light should flash and go out!
reset done. if you have any more issues plese ask. good luck
Sep 25, 2009 | 1992 Acura Legend
Acura legend passenger windows wont go down
PASSENGER MASTER SWITCH TURNED OFF ON DRIVERS DOOR WINDOW SWITCH PANEL?????
Mar 30, 2009 | 1992 Acura Legend
Finding my thermostat
Thremostat is located in engine just before the engine cooling system return hose, three bolt housing (thermostst housing) the lower coolant hose on the radiator is the cooled return hose.
Dec 03, 2008 | 1992 Acura Legend
Acer Aspire 5600 Series 5630-6951 Laptop Logo
42 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
