Question about Xerox Phaser 8200 Laser Printer
Phaser 8200 my phaser 8200 came up with a message to load cleaning sheet ...... i added a clean sheet of paper ..... the following day the red light came on with the message load paper tray ..... now it acts as if there is no paper tray has anyone got any advice
  • Anonymous Aug 09, 2008
    Cleaner sheet prompt won't go off. Have fed clean sheets through all trays, loaded & unloaded paper, and turned-off printer ... no luck. Can print no real jobs needed!
    President:
  • 2,072 Answers
Have you loaded both trays? The bottom tray and the upper tray ? The one that folds into the machine. Something may be trying to run from tray 1. Upper tray
Posted on Jul 18, 2008
How do I clean toner from machine?
Probably it's the jammed paper that might caused the error. I suggest have it serviced by the technician. Be aware of the paper handling capacity of your machine to minimize jamming:
3300MFPV_X
Phaser 3300MFPV/X, Copy/Print/Colour Scan/Fax, B&W, 28 ppm, A4, 1200 dpi, 50-sheet ADF, 250-sheet Paper Tray, 50-sheet Multipurpose tray, 150-sheet Output Tray, 96 MB, Automatic 2-sided printing, USB/Ethernet, PCL/PS3, Scanning software, 220 V
Apr 28, 2014 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Red and green light turn after first run
Its common problem in T Series Plotters:
Cause of malfunction: These plotters having separate sheet path as well as roll path for print media. After initializing plotter its verify the available media(sheet or roll). If sheet path is occupied by the media it wont allow the roll media, means first priority is for sheet.If sheet path paper sensor dusty or malfunction, printer will say "remove paper from sheet path" even no paper in sheet path..
How to shoot this problem:
You need to clean sheet path sensor located at sheet loading area.(black 'U' shaped part) Applying the pressured air at sensor is the best method to clean.. If problem remain you need to remove the sensor & clean or replace it.
Follow the snaps:
Need to open roll feed right side portion
dadb8b23-32b2-4d8a-952b-038117715d5b.jpg f7392b92-295a-4144-8387-b83355c6889e.jpg 6f066468-8698-4d24-94d4-af1703c40407.jpg 6ed46665-db38-4ccc-8522-c52ae9c50dbf.jpg 37e6b4f2-cc2e-438b-849e-9911bd553c7e.jpg
Clean the IR sensor...
Fix it back..
Note: Technical knowledge required to understand the remedy..
Jan 26, 2014 | HEWLETT-PACKARD CP1025 Laser Printer
Printer says "Claening sheet required install
The phaser printer using the wax cartridges requires cleaning every so often.
Load standard 8.5x 11 paper and go into the maintenence area on the front panel of the printer. There are 3 types of cleaning available. Use the deep clean option and the printer will spit out several sheets of paper. (THROW THESE AWAY) Don't atempt to reuse the cleaning sheets as it has caused problems for me in the past.
Once done reset the printer.
Good Luck
Jan 25, 2011 | Xerox Phaser 8500N Printer
Xerox Phaser 8200 goes through post then hangs.
Sounds like a RAM problem. Go to the back of the machine, You will see  2 large, thumb Screws, Twist them about half a turn and remove the main board. Remove and reinsert the memory stick. If that does not fix it the main board or the electronics module has probably failed.
Mar 03, 2010 | Xerox Phaser 8200 Laser Printer
The paper isnt going through
If the paper feed rollers are not clean, they may slip and cause paper feeding problems.
The problem may be alleviated by performing paper feed roller cleaning.
1. Open the Printers folder.
- For Windows XP Home Edition Click/Select "Start," "Control Panel," "Printers and Other Hardware," and "Printers and Faxes."
- For Windows XP Professional Edition Click "Start" and "Printers and Faxes."
- For Windows 2000/Me/98 Click/Select "Start," and "Settings," then "Printers."
2. Right-click the icon of the printer for paper feed roller cleaning, and select Properties from the displayed list.
3. Click the Maintenance tab and click Roller Cleaning. 4. Remove all sheets of paper from the auto sheet feeder, and click OK. 5. Confirm the message to be displayed, and click OK.
Do not try other operations until printer's operation completes.
6. When the printer's operation is completed, follow the confirmation message to load three new sheets of A4 or letter-sized plain paper in the auto sheet feeder
7. Click OK.
8. Confirm the message to be displayed, and click OK.
Do not try other operations until all the three sheets are ejected.
Memo: The printer prints nothing on those sheets.
9. When all the three sheets of the paper are ejected, paper feed roller cleaning is completed.
10. Click OK.
Performing Roller Cleaning is completed.
Nov 09, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Phaser 8200 Smears on Linen Paper
Your maintenance kit is running low on oil and needs to be replaced. Since the image drum is not getting enough lubrication, some of the ink from the previous page is sticking to the drum and carried over onto the next page. Also, try to match the printer paper type to the paper you are using. It will adjust speed, temperature, etc. to optimize print.
Mar 24, 2009 | Xerox Phaser 8200 Laser Printer
Xerox 8200
There are special cleaning sheets that you need to get for this printer. Ask the company you get your ink from, they should be able to get you some.
Sep 23, 2008 | Xerox Phaser 8500N Printer
When the printer pulls a sheet down it grabs the right side of the sheet (as you face the machine) leaving the left side up, to warp the sheet and make a grinding noise trying to pull the sheet in. Of...
Solution: Cleaning The Paper Feed Rollers (Windows) iP1600
Clean The Paper Feed Rollers (Windows) Instructions how to clean the paper feed rollers. If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the printer properties.
  2. Click the 'Maintenance' tab and click 'Roller Cleaning'.
  3. Remove all sheets of paper from the auto sheet feeder.
  4. Confirm the following message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. Thisactivation will take about 90 seconds. Do not perform other operationsuntil this operation has finished.
  5. Confirm the following message, and click 'OK'.
  6. After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
  7. Confirm the following message, and click 'OK'.
    Note: The following message is displayed when the paper is fed and ejected.
  8. Click 'OK'.
Jul 02, 2008 | Office Equipment & Supplies
Error message
9,037.45 Yellow Ink Stick Count Fault
your 04,021.42 here are the possibilities.
arrwup.gifPrimary Causes The troubleshooting table lists parts and wiring referenced in the troubleshooting procedure.
Table 1. 4,0xx.4x Troubleshooting Reference Table Applicable Parts
Wiring and Plug/Jack References
Electronics Module, PL 5.0
Right Side Wire Routing (2/2), Figure 3
Printhead, PL 2.0
Electronics Module, Figure 6
Drum Assembly, PL 2.0
Electronics Module Power, Figure 7
Drum Heater Relay Board, PL 5.0
Right Side Wire Routing (1/2), Figure 2
Drum Temperature Sensor, PL 6.0
I/O Board (2/2), Figure 10
arrwup.gif Troubleshooting Procedure Table 2. Process Control Error Troubleshooting Procedure Step
Questions or Actions
Yes
No
Test the heaters.
Run the Service Diagnostics Monitor Heaters tests with all heaters On.
Do the heaters function properly?
Replace the Electronics Module ( REP 5.0.5).
Go to Step 3.
Check the harness to the failed heater.
Is the harness damaged?
Replace the harness.
Replace the failed component.
Jan 06, 2008 | Xerox Phaser 8500N Printer
Xerox Phaser 8200 Laser Printer Logo
289 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
