Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Coils ice up
It is a GE Profile side by side, model TFX27PFSM WW. Tried advancing the timer and waiting for over an hour but frost still formed on back panel. removed panel and coils were frozen, top to bottom. Not sure if i need a new switch or heaters.
  • 193 Answers
Appears to be the defrost timer,unit should have advanced out of defrost within the time you listed
Posted on Sep 29, 2009
GE Profile refriderator PSC25MSWA is frosting/icing on bottom of Refriderator side
Try defrosting entire unit. Put all food, freezer and refrigerator sides in coolers with ice. Unplug unit and wait at least 24 hours for unit to completely defrost, if neccessary open doors, plug unit back in and see how unit functions. By doing this lines that carry freon should become unclogged.
May 05, 2014 | GE GSS22SGM Side by Side Refrigerator
I have a GE Side by side Fridge with model #TFX27PFSM WW and the coils were completely frozen. I used the hair dryer on them and thawed them out. As soon as I plugged the fridge back in, they immediately...
Its normal for the evaperator coil in the freezer to have frost on it that is a sign of a heallthy good working compressor...WHEN IT BUILDS UP SO THICK their is no gaps in the coil and its just one huge iceblock that is where the problem lays. Thier is a automatic defrost system that is supposed to periodically come on and melt the frost and a component from it has failed allowing the frost to build up so thick it has restricted airflow through it.
The most probable problem is going to be a bad defrost heater it by far is the leading problem when a GE brand ref.doesnt automatically defrost.
This tip i wrote explains how to check and see why its not automatically defrosting
http://www1.fixya.com/support/r10097882-wrong_when_freezer_frosted_refrig_warm
GENE
Sep 24, 2011 | Refrigerators
GE Frig model TFX20JRBK ww with icing on freezer
I would suggest fixing it . You only have 2 parts in the defrost system . A timer , and the defrost heater which comes with the bimetal , pt . # WR51X10031 .Most probable , is the defrost heater . You will need to remove the rear inside freezer panel , and defrost the coils with a hair dryer . After defrosting , 2 screws hold each ( 2 ) heater on , ant the defrost thermostat , just clips onto the top of the coils .
Nov 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Model: TFX27PFSM BB Ice/water dispenser mother
The board will remove by prying at the bottom of the board . Sometimes I can use my hand only , pulling out from the bottom , to remove . Other times , I have to pry from the bottom to remove . Do not try to remove the dispensor frame , only the board .
Oct 10, 2009 | GE Profile CustomStyle PSI23NGR Side by...
Freezer side of refridgerator doesn't freeze foods properly and also makes only about 10 cubes a day. food side works fine, it's a Hotpoint model #HSS251FMB WW
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
thumbs up
Aug 17, 2009 | Refrigerators
GE Profile - fridge not cooling
Thick layer of ice has formed at bottom of freezer. Cannot even pull out the bottom basket
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Aug 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side ffreezer continues to frost over
A simple defrost may not be all that is needed. There is a piece that connects to the coils called a defrost timer or a " clixon " This is most likely the problem. Have it replaced and that should get you back in business. Hope this helps. Good luck.
Jul 09, 2009 | GE Refrigerators
Freezer frosts up and stops cooling after approximately 2 weeks
either low in freon or defrost timer stuck or unit needs cleaning, remove front louver panel on bottom (either 2 screws or snap fit) look for timer then use small straight screwdriver to turn slowly till clicks then wait to see if working properly, if not could be problem. if you see a lot of dust bunnies while doing then clean with vacuum and do same to back area also
Jun 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE TFX20JR BK WW side by side won't cool or freeze
First point: The entire fridge is cooled by the freezer section. A fan blows air across to the food section.
2) Every 8 hours or so, a timer shuts off the compressor cycle, and starts up a heater to defrost the freezer coils. If the heater(s) are burnt out, or if the safety thermostat (to prevent overheating) is open, then you will have no defrost. The coils will frost up and eventually prevent airflow to the food section. Milk goes sour.
3) In rare circumstances, the timer itself can stall. This cause the same symptoms as above, but this is not as common as the other 2 causes of No Defrost.
Sequence: Check heater continuity. Check safety thermostat continuity while cold. Check defrost timer operation.
Hope this helps. I am a journeyman with 39 years exp. Happy New Year.
Dec 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
197 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
