Emac 800mhz will shut off on it's own randomly. I'll press start button and it start up. This has been going on a few days now.
  • 80 Answers
Hi my name is wesley. ok it might be a broken or loose cable in your pc check and make sure they are all in properly then go into your bios witch when you boot up your pc it will say press f1 or delete to enter setup do that then look for pc health or cpu temprature if the temp is high the pc will auto shut down due to danger. you can fry your cpu so you might have to get a new system fan they not expensive and easy to install if the temprature is not the prob then replace a few cables starting with the cable that goes into your hard drive called an ide cable. your system temprature should be about 30 40 degrees usually higher than that it will auto shut off.
Posted on Jul 17, 2008
My iPhone 3GS screen is going crazy! Randomly if I click a letter on the keyboard let's says 'a' then it starts clicking other random letters like 'p' Also, when I'm running an app an let sat I scroll down...
My 3gs has been doing the same thing for the past few days until it got to the point where it opened up settings and started hitting all the different sounds! lol
First i was going to restore but the restore ended up failing due to some kind of unknown error. I then thought what about doing a "hard reboot" by holding the lock button and home button together until it shuts off, then release the lock button while still holding the home button for 10 seconds. That worked. I guess its like disconnecting the battery for a bit. Hope it works for all !!!
Apr 03, 2011 | Apple iPhone Apps
Shut down in sleepmode by mistake, how to awaken?
Press enter twice or press power button to awake.
Thanks,
satheesh
Jan 20, 2011 | Computers & Internet
'97 Honda Accord- Horn honks spontaneously; honks several times in a random pattern every few minutes. Turning car off and restarting it seems to temporarily solve problem, but random honking will then...
THE SWITCH IN THE STEERING WHEEL IS PROBABLY GOING BAD OR HAS A LOOSE CONNECTION THAT IS GROUNDING OUT AND COMPLETETING THE CIRCUIT AT RANDOM. I REALLY DONT KNOW HOW OR WHY SHUTTING IT OFF WOULD TEPORARILY FIX THE PROBLEM BUT WITH ELECTRICAL PROBLEMS ANYTHING IS POSSIBLE BELIEVE ME. ALSO TAKE A LOOK AT THE WIRING AND THE HORN ITSELF TO SEE IF EVERYTHING LOOKS OK THERE.
Jun 03, 2010 | Honda Accord Cars & Trucks
Where can I download instructions for utilitech timer
UTILITECH - Grounded in Quality
Digital 2-Outlet Timer (TE06WHBL)
Instruction Manual & Warranty
Before using your timer please read the following instructions carefully.
FEATURES
- Up to 8 ON/OFF events per day/56 ON/OFF events per week
- Option to program individual days or 8 different weekday groups
- Minimum switching period one minute
- Summertime/wintertime change over
- Easy to read LCD display
- Random automatic ON/OFF security feature
- Countdown feature
- Manual override button
- Rechargeable battery back-up (if there is no LCD display, plug
timer into a wall receptacle, this will recharge the battery)
SETTING TIME
Press and hold CLOCK key, then press DAY key to select correct day,
HOUR key to select correct hour, and MIN key to select minutes. When
MIN key is released, time will be set with seconds starting from 0.
Either holding down or repeatedly pressing appropriate button can
advance days, hours and minutes.
Do not set ON and OFF for same time.
PROGRAMMING EVENTS
The timer has the capacity for 8 ON/OFF events per day.
Save program capacity by using available blocks of days.
Blocks of days are:
1. M,T,W,Th,F,S,Su
2. Individual days of the week
3. M,T,W,Th,F
4. S,Su
5. M,T,W,Th,F,S
6. M,W,F
7. T,Th,S
8. M,T,W
9. Th,F,S
For each ON time and each OFF time--DAY, HOURS and MIN must
be set. Press PROG key onceto set first ON time--"ON" and number
"1" appear to left of LCD display indicating to enter first ON time.
Press DAY button to choose required day or blocks of days, then set
hour and minutes using HOURS and MIN buttons. After setting required
ON time, press PROG button to validate entry and move onto first
OFF time--"OFF" and number "1" appear to left of LCD display
indicating to enter first OFF time by using DAY, HOURS and MIN
buttons as above. Press PROG button to validate this entry. Repeat
remaining 7 ON/OFF settings as required. After setting required
ON/OFF settings, press CLOCK button to return display to clock. Timer
is now ready to operate. Check programmed settings by pressing
PROG button repeatedly--each setting will appear on screen.
MANUAL OVERRIDE
To choose permanent Manual ON, permanent Manual OFF,
Auto ON or Auto OFF, press Manual button. Each mode will be
displayed on screen. When choosing Auto ON, timer turns ON until
next programmed OFF time. The programmed settings will only work
on Auto mode. When Auto mode OFF is chosen, timer is OFF until
next programmed activity. (Inverted black triangle on LCD points
to either AUTO or MANUAL indicating which is selected)
COUNT DOWN FEATURE
To enter count down feature, press CLOCK and PROG buttons
simultaneously. Using HOURS and MIN buttons, set count down time.
(Maximum selection is 9 hours 59 minutes, minimum is 1 minute.)
Press MANUAL button to start countdown. Output will turn ON until
end of count down. Count down may be paused at any time during
period by pressing MANUAL button. To re-start, press MANUAL button
again. To review time during count down period, press and hold
CLOCK button. Release CLOCK button to return to count down display.
Note: To return to timer mode, press CLOCK and PROG buttons
simultaneously.
RANDOM AUTOMATIC ON/OFF SECURITY FEATURE
With this option selected, timer will switch ON and OFF in a random
pattern at least once in every 8 hours. (This may mean timer will
switch OFF within a set ON period, or vice versa.) Ideal for use with
a light--switching it ON and OFF automatically gives appearance of an
occupied home, but not at exactly the same time every day. To enter
Random mode, press DAY and HOURS buttons simultaneously.
An "R" will appear on display and unit will start random switching.
If no programmed times are set, timer will switch ON or OFF
approximately 1 minute after entering Random mode, then continue
randomly. To turn Random mode OFF, press DAY and HOURS buttons
together again.
SWITCH OVER SUMMERTIME/WINTERTIME ZONE CHANGE
To change from wintertime to summertime, press HOURS and MIN
buttons simultaneously. Clock will be set forward one hour and
"S" will appear on display. Repeat same procedure to return to
wintertime.
Note: if unit is purchased during summer, set clock time for one hour
less than correct time, select Auto mode and press HOUR and MIN
keys simultaneously. The unit will then adjust to correct summertime
and "S" will appear on LCD.
RESET
To reset unit for time and programmed ON/OFF settings,
press RESET button.
IMPORTANT SAFETY PRECAUTIONS and
RATINGS
[Contact the manufacturer; I've already wasted too much time typing
this in:
AmerTac
Saddle River Executive Centre,
One Route 17 South, Saddle River, NJ 07458
800-777-0802
www.amertac.com
Made in China
May 05, 2010 | Kitchen Appliances - Others
I have an eMac and would wireless USB adapter to work
It depends on which eMac you have. The 1/1.25 Ghz and the 1.42 ghz models have USB 2.0 so either adapter will work. The slower speed eMacs only had USB 1.1 and will not work for those types of adapters. The 700/800Mhz models will use the original AirPort card while the rest of the eMacs use the Airport Extreme cards.
Dec 30, 2009 | Apple eMac G4 Desktop
Dell Inspiron 6400 shuts off at randomly
STEP: Run the Preboot System Assessment (PSA)
Additional Information
  1. Ensure that the computer is powered off.
  2. Press and hold <Fn> and press the power button to power the computer on.
  3. Release both buttons. The PSA diagnostics sequence begins.
  4. Make note of any PSA beep codes or PSA error codes
Check for PSA Error codes on support.dell.com.
If all Test Passed. Then Perform Dell Factory restore or OSRI.
Nov 21, 2009 | Dell Inspiron 6400 Notebook
Power on/off problem
If possible go for a repeareing.
Feb 18, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
