Question about Hitachi 61SDX01B 61" Rear Projection Television
61 Hitachi Ultra Vision has double image
My rear projection 61 Hitachi Ultravision is displaying double image. Its about 7 years old. Magic foucus dosen't help. Any ideas?
  • 1 more comment
  • bmessina24 Oct 27, 2008
    My 61" Hitachi UltraVision has a curved blue line on the top and bottom of the screen. The images are distorted and have a yellowish blue tint.
  • roccor21 Nov 09, 2008
    Ok, I would suggest before you buy anything from anybody is to try to do a manual convergence.
    1) Receive an NTSC signal.
    2) Press Magic Focus to begin magic focus
    3) Press magic focus again during the magic focus process to get the ?stop? screen
    4) While stop screen is up, press STATUS or INFO on the remote control (R/C) to bring you to DCAM mode and
    the service grid (64 point grid)
    5) When you first get in here? I believe red is the selected color by default (it is flashing).
    6) To choose other colors to converge, use the following buttons on the R/C:
    a) ?STATUS? - Green
    b) ?0? - Red
    c) ?ANT? - Blue
    7) Start from the center of the screen and work your way out on one color at a time. I adjusted red across the
    whole screen to match green. Then I switched to blue, and adjusted that to green as well. After you adjust blue, you
    may want to go back and adjust some red again? etc. until the convergence looks good.
    (a) Use 4, 6, 2, and 5 on the R/C to move the cursor position(dotted lines).
    (b) Use thumb stick to move the convergence point color.
    ** There have been other posts in here to tape together the color filters found in the Avia DVD to help converge
    lines more easily. I have used this method, and it works well for adjusting to a greater detail. Basically, you put the
    red filter next to the green and adjust your red to the green line both horizontally, and then vertically. Then you do
    the same with the blue next to the green. Some people recommended you should be at normal viewing distance. I
    did mine from just a few feet back from the set. Maybe my eyes aren?t as good? maybe I just felt like it worked
    better this way. There are some other posts also recommending using binoculars. I think it?s great that people
    suggest things to make the process easier? but my girlfriend would think I was insane if she saw me with
    binoculars on the couch adjusting the convergence. I don?t know? whatever works best I guess.
    8) I did not adjust the green at all. I use the green as the guide and did not adjust the location of any green point.
    This is highly suggested unless you have geometry problems.
    9) When going along the lines and adjusting, you may run into the problem of getting an ?S? curve on the line.
    You?ll know if you get there. Basically, no matter what you do to adjust the line to be converged, the middle of the
    line between the points will not straighten out (it bends between the points). To fix this, the manual recommends
    going to the (7x5) mode which gives you less points to adjust. I had this problem, and the solution worked. There is
    also another mode (3x3) which gives you even less points. Basically, if the set looks good, you only fine tune it in
    (13x9) mode (64 point). If you have serious problems, the grids work as:
    3x3 - ?coarse?
    7x5 - ?medium?
    13x9 - ?fine?
    10) To get to each of these patterns use the following on the R/C: (only if you need to)
    1. (3x3) Press ?STATUS? 5 times (only works when DCU is in uncorrected state)
    2. (7x5) Press ?0? 5 times
    3. (13x9) Press ?ANT? 5 times
    11) If you adjust the 3x3, then you should go to the 7x5, and then the 13x9. You get the point? depending on where
    you start, work your way up, and always finish on the 13x9
    12) When finishing up the 13x9 mode, to get additional ?grids? on the edges of the screen, press the PIP CH button
    on the remote control while in the digital convergence adjustment mode (DCAM). Fine tune the edge convergence
    as necessary. To exit, press PIP CH again.
    13) When convergence is acceptable, press PIP MODE to write data to ROM memory. ROM WRITE? is displayed
    to alarm system that ROM will be overwritten with new data. Press the PIP MODE button again to write
    displayed data to ROM.
    14) DATA WRITE TO ROM will take approximately 4 seconds and no picture will be displayed.
    15) Green dots will be displayed when operation is completed.
    WARNING: YOU MUST DO THE FOLLOWING STEPS TO COMPLETE MAGIC FOCUS
    INITIALIZATION!!! THERE HAVE BEEN MANY POSTS THAT PEOPLE HAVE HAD PROBLEMS
    WITHOUT DOING THIS STEP BECAUSE THEY LOOSE MAGIC FOCUS!
    16) Press MUTE to return to convergence pattern, then confirm again convergence is acceptable.
    17) Press PIP MODE and then PIP CH to initialize Magic Focus. The initialize operation starts and several
    windows appear during this operation. It takes about 30 seconds or less.
    18) When green dots appear, initialize operation is finished.
    19) Turn power OFF.
    21) Wait a few seconds. Turn the TV on, and you should have your normal signal. Press Magic Focus button just
    to make sure the magic focus still works (and that you did the last few steps properly)
    I went through the hassel of replacing the IC and resistors, taking out the convergence board, ripping apart the heat spring guard above the ICs, running to radio shack and getting a soldering and desoldering gun for getting the parts I needed installed. Really though I should had tried just doing a manuel convergence first.
    I had a problem with double images but when I replaced all this stuff I still saw the same picture. Once I had performed a manuel convergence though I was all set and the TV looks good again.
  • svecho
    svecho Jan 07, 2013
    Is there a way to get to DCAM mode without using the remote. The remote sensor in my 53" Hitachi Ultravision is bad. Grandkids killed it. TV has been wonderful and can't see pitching it for this reason.
  • Hitachi Master
  • 8,617 Answers
You will need to replace both convergence ICs they are STK392-110 you will also need six resistors (2) 2.2 ohm 1watt
(2) 1.5 ohm 1watt, (1) 3.3 ohm 1watt and (1) 1.8 ohm 1watt.
You can get replacemnet ICs and resistors at te following link with free instalation instructions. Here is the link.
http://servicemanuals.vstore.ca/
Posted on Jul 17, 2008
How much is a sale price Hitachi Ultra Vision DX Series 61UDX10B - 61" rear projection
try here -> http://www.beststuff.com/audiovideo/hitachi-introduces-new-hdtv-monitors-and-conventional-sets.html
Mar 25, 2011 | Hitachi 61SDX01B 61" Rear Projection...
61sdx01b The blue image is 3 inches to the right of the red/green. Magic foucus does not correct problem. When it gets to the blue it gets a bit wavie. If I go to the center adj mode by holding down the...
You have a Convergence circuit failure. The Convergence ICs probably need to be replaced. It should be done by a professional due to the adjustments that may need to be done in the factory mode after replacing the ICs.
Hope this helps,
Skyassoc
Jul 16, 2009 | Hitachi 61SDX01B 61" Rear Projection...
Rear projection HD Hitachi Ultravision always has greenish tint
This is what you're going to do, Turn on the Tv and go to the service manual, if the green tint is still there, you have a defective dmd board, but if it's no there, then you have an issue with your video board
Jul 09, 2009 | Hitachi Televison & Video
My hitachi ultra vision television is giving a double picture
This is a common problem with rear projection TVs. It will require pulling the convergence board out of your set and replacing two large ICs and several 1 watt resistors. It can be fixed no other way.
May 17, 2009 | Hitachi ULTRAVISION L42V651 42 in. LCD...
Double vision two picture
conversion chip is blown do a google search on "replace conversion chip"
May 06, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Replace both of your STKs big black ics If they are STK392-110s upgrade to 180s better ics Electronix has them call 1-800-223-3205
Dec 18, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Hitachi 42 inch ultra vision has double image
it is just a convergence problem which makes the image look doubled.it can be repaired by any good local tv technician for approx 75 to 80 dollars.nothing much to worry.
Dec 01, 2008 | Hitachi 60V500 60" Rear Projection...
Double image 6 yr old unit
Have you let set warm and then tried Magic Focus? Maybe after 15min.
Nov 25, 2007 | Hitachi 61UWX10B 61" Rear Projection...
Hitachi 61SDX01B 61" Rear Projection Television Logo
1,979 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
