Question about Fuji FinePix Z10fd Digital Camera
Lines across the photos
My New camera is displaying lines across the taken picture, where can i send it to be repaired? it is still under warranty.
  • Anonymous Jul 26, 2008
    I'm having the same problem with my camera after dropping it. The LCD screen looks fine but the pictures have vertical lines. Any help is appreciated.
  • 96 Answers
Usually the warranty is for the first 30 days. If you are in this period, you might get it fix for free or replace.
Artgirlny
Posted on Jul 18, 2008
When i take a photo ,the image has horizontal line across it ...? what's should i do .is it lens problem ?
The fact that it takes the pictures ok confirms that it's not the ccd which has failed. A CCD problem would explain the lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image). CCD (Charge Coupled Device) is one of the two main types of image sensors used in digital cameras.
Some symptoms of a defective CCD include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
When a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value. This last step occurs outside the CCD, in a camera component called an analog-to-digital converter.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details: Bad CCDs. This, isn't a good new, but hope helps to solve it.
Samsung themselves wouldn't normally bother; a warranty claim usually means they chuck your camera away and send you a replacement. If you're in the UK click here for details of how to proceed with Samsung.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day
Dec 19, 2011 | Samsung S860 Digital Camera
Have lines across picture? do have warrenty ..do I send in or take to store where purchased?
Hi. If your camera is under warranty, return it to the vendor. White horizontal lines is a result of a failing parts inside the camera that needs replacement.
Sep 03, 2010 | GE A730 Digital Camera
Green and purple pink horizontal lines on lcd screen
As it's definitely not a bicycle which you're asking about, I shall assume it's a camera.
You have described the typical symptoms of a failed CCD imager unit in a digital camera. if it is the imager, then photos taken before the fault occurred will display normally on the camera LCD display, and those taken after the fault occurred will display incorrectly on both the LCD and when uploaded to a host pc. The fault can only be repaired professionally, but unless the camera is under manufacturer's warranty and so qualifies for free repair it's usually not cost-effective.
Note that a few makes and models may qualify for a free repair even if out of warranty, but as you haven't mentioned the make and model I cannot advise you specifically about this.
Aug 15, 2010 | Cycling
There are gray fuzzy lines across the pictures
Sounds like it could be cracked glass or a dirty lens. if its a cracked lens take it to a repair shop or buy new. if its a dirty lens whew! you saved some money just clean it off good luck please rate,
Rshutterbug
Aug 17, 2009 | Canon PowerShot A75 Digital Camera
White lines appearing on display after picture is taken
I have the same problem, and upon looking into my problem, i recall reading that Sony had used crappy glue in which they attached the CCD to the inner guts of the camera, and when that deteriorates, which doesn't take very long, then your pictures will have lines through them.
I think i remember reading that Sony said they will replace all cameras within 2 years of their manufacture. Call Sony's troubleshooting and support and they may replace it for you.
Hope i helped solve your problem.
- Josh
Oct 20, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Wavy lines on photo's
Check if it is a dirty lens problem.
If lens are ok, then is either the camera optical sensor defective or a fault in camera main board.
You will need to take your camera to a computer shop or to send it in for repair.
You can call the number listed on the camera user manual to get repair service.
If camera is less than one year old, it may be covered by factory warranty, check warranty terms.
Sep 14, 2008 | Fuji FinePix S5200 / S5600 Digital Camera
F460
Lines across your pictures could indicate that the sensor is damaged. If your camera is still under warranty get it back to Fuji asap, otherwise get it to a repair service and ask for a quote to repair. As far as i know fuji have a fixed price to repair each camera model.
May 19, 2008 | Fuji FinePix F460 Digital Camera
LCD screen shows weird colours
Gimbo again. Think LCD damaged will need to repair. Pics. as normal when viewed or printed.
Why has nobody commented?
How much to replace screen? Any ideas?
Feb 16, 2008 | Cameras
Red lines
It seems that you have been selecting Panoram view to shoot photos. Go to menu and change the image options and select SHQ or whatever and not panorama. This should solve the problem. Panorama view shows the grid lines all over the screen and it is meant for taking 360 degree panoramic views.
Jun 13, 2007 | Olympus FE-230 Digital Camera
White pictures and lines across pictures
Try this to isolate the problem.
Switch on the camera in auto and put it into full optical zoom. Now turn the camera to face you and angle it so that you can see into the lens without reflection. On full zoom the internal lens will be right up to the outer lens. Now press the button to take a picture. You should be able to see the shutter cover the inside lens and then open again. Did it completely cover the lens? It should do. If not then you will get an over exposed picture or a picture with lines across it.
Email me for more info and how to solve. daveward712@aol.com
Jan 29, 2007 | Fuji FinePix E900 Zoom Digital Camera
Fuji FinePix Z10fd Digital Camera Logo
65 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
