Question about Pioneer DVR-520H DVD Recorder
DVD shelf won't open
My Pioneer DVR-520H DVD player has been working fine for a few years, now however the dvd shelf won't open. I'm not sure if there is a dvd inside or not, but either way I can't get it open.
I not too sure wether to force it open with a pin. is this a good idea? or do I have another option?
  • 3 Answers
You know you can place a paperclip in the hole next to the DVD drive to release the door. Never just pull on the tray when it is all the way closed. Once the door is part way open you can gently pull it out the rest of the way. This will not fix anything, it just allows you to open the tray once.
Posted on Aug 19, 2008
Power supply unit failure
It could be the IC101 (MR2920) and the zener D104 both failed, or IC1 (MD5001T) failed as well, here is the link where I've descrived how I fix the issue on my DVR-520H, it is in italian but you can translate it with Google: http://www.plcforum.it/f/topic/181344-riparazione-guasto-alimentatore-pioneer-dvr-520h-dvr-520h-failure/
Feb 08, 2013 | Pioneer DVR-520H DVD Recorder
Looking for a manual free of charge for DVR-520 H. Where to find?
Hello
Get into this site where you can get its user manual for free download. If you fail to do it, either send your email address by fixya of send a mail to me at gopakumarg43@ymail.com. I've the manual in pdf format, and will send it to you by return mail. OK.
www.pioneerelectronics.com/.../Manuals/ci.OPERATING+INSTRUCTIONS+ DVR-520H.Protected - United States
Ok.
May 18, 2011 | Pioneer DVR-520H DVD Recorder
My Pioneer DVR-520H DVD Player works fine but sometimes when it is powered off the power just goes completely. When this happens I plug it into a different socket or just pull out the power cable from the...
It seems problem with power supply board in Pioneer DVR-520H, possible causes for that symptoms are few dried up/ leaky capacitors, cold/ dry solder joints on circuit board or chip resistors would be devalued.
Local repair shop will help you to replace bad capacitors, chip resistors in power supply board to solve this issue if you are not familiar with soldering work in circuit board.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Jan 11, 2011 | Televison & Video
Anyone know why my color input is coming out in black and white? the on sceen menu and dvd's are in color
Have you tried reprograming your dvd, you must also save the changes that you made during reprograming.
Aug 21, 2010 | Pioneer DVR-520H DVD Recorder
DVD was working fine then display screen flashes ":LSI NG", help!
I actually got the same problem.
Did you succeeded to solve it ?
Jun 23, 2009 | Pioneer DVR-520H DVD Recorder
Power off after recording
Hi All,
This is a power supply problem.... the MR2920 stanby IC miss behaved, it power off and fail to power back on.
Solution, get pioneer power supply replacement or take the dvd recorder to your local electronic service repair to take a look at the power supply circuit.
Best of luck
Kenny
Apr 21, 2009 | Pioneer DVR-520H DVD Recorder
No power
Something inside is loose, so it's time to buy a flat panel tv or spend $50 to get it repaired.
Oct 17, 2008 | Pioneer DVR-520H DVD Recorder
Forgot to Finalize Disk
well nero 8 contais a finalize utility you can use to finalize it.
antoer method is to retrieve the data via certin software and then bur it back off one such program is CD RECOVERY TOOL BOX (dont worry it does dvd's as well) http://www.recoverytoolbox.com/cd.html
although its for damaged and unreadible disc it will retrieve the video from unfinalized disc as well.. I used it many taimes and it works perfectly
Jul 16, 2008 | Pioneer DVR-520H DVD Recorder
Pioneer DVR-520H DVD Recorder Picture is Yellow
If running component or RGB try replacement lead set. Otherwise is TV issue.
Oct 12, 2007 | Pioneer DVR-520H DVD Recorder
Pioneer DVD Recorder - can get picture but no sound
If you are using RCA cables, you need to hook up three cables (1) yellow video, (2) white - left audio, (3) red - right audio.
May 28, 2007 | Pioneer DVR-520H DVD Recorder
Pioneer DVR-520H DVD Recorder Logo
214 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
