Miele w980 pcb fault
Hi Mr Miele, I was looking for a schematic for a EL150 pcb for my washer the board is defective and at the moment I have not got to the bottom of the problem, I have previously replced a capacitor, which temp. repaired the problem, now the pcb fuse has gone in a rather dramatic fashion I think it may be the choke??? Have you got any information on this board or know where I might find some.
Many Thanks in anticipation
Patrick Trower
SOURCE: washer dryer stopped turning
Dovi thanks a lot for that advice will give it a try.
Posted on Aug 28, 2007
Jimster
  • 240 Answers
SOURCE: faulty main pcb board , test cycle showing
If you do decide to remove the board and fix it, you sometimes can see what goes bad by a small burn or tarnish mark around a resistor or capacitor. Other times you wont be able to see a thing. It would all depend on what system or part caused the first problem. Good Luck!!! Jim
Posted on Sep 08, 2007
  • 833 Answers
SOURCE: maytag mah4000 washer
ajshoe,
I'm not familiar with this particular model but I will tell you this:
The schematics for these circuit boards are generally not published. The reason is that the average repair guy will not want to fix them and probably lacks the expertise. Q means transistor. Transistors are 'relays' after a fashion. If you can see a number, you may be able to access a replacement. Otherwise, I would change the board. The fact that the washer will start sounds like the relay that the board controls is operating properly.
You may be able to find a board renewal/exchange online for less than a whole new one. Be sure to unplug the machine and ground yourself when handling the board.
Posted on Nov 30, 2007
SOURCE: Oasis washer repair
This was easy to replace, but after only two months I did a small load and when I went to look at it the washer was completely dead.  I fiddled with the wires by unplugging the blue wire that connects the main circuit to the control panel and sometimes it begins to go, but cuts out.  Does anyone have an idea what's going on with it now?
Posted on Nov 21, 2008
beltronic205
  • 1474 Answers
SOURCE: miele w487 trips fuse when its heating the water i
I think its located back bottom of drum, could be this short circuit, try disconnecting the wiring to it then see if machine runs make sure no power connected while disconnecting also tape up wiring ends..
Posted on Jul 12, 2010
Miele washing machine starts up then goes off I have to wait hour or two press it on it starts then stops again can you tell me what's wrong thank you
You do not mention the model number of your machine.
This happens more often with Miele washing machines with an EL150 electronic.
If so, it can be found below the top cover.
From this electronic it is known that the resin in which the transformer is cast, is developing small cracks. These cracks tear the thin copper wire of the primary winding apart. If the temperature drops, the cracks close again. Remedy: replace electronic or have it fixed (google on "Miele EL150 defective").
Mar 11, 2015 | Miele Washing Machines
Flashing rinse light on meile 864 and anti crease/ finish light comes on.
If you are sure that you made no mistake in mounting the brush cap back on the motor (check the four pins), most probably the electronic EL200 is defective.
This happens often in this type of machine when the shock absorbers are worn (after 10 years).
You can check this by measuring the continuity in the little 6.3A fuse that is on the EL200. If it is blown, you may get the PCB repaired for 55 Euros + shipping (see link below). You also have to replace the shock absorbers (32 Euros) to get a full year guarantee.
Miele Reparatie EL200
Feb 11, 2014 | Miele W864 Front Load Washer
PCB SAMSUNG WA10D3 SCHEMATIC
Please send me the schematic for PCB SAMSUNG WA10D3. TO PEDROROSALES1985@GMAIL.COM
Jan 28, 2013 | Samsung Clothes Washer PCB Board -...
No power on miele novotroninc 520
Check that the washer supply is OK using another item - a kettle for instance. If it's not check your breakers/fuses. Reset/replace if necessary and if the same thing happens, or if there was nothing wrong with the breakers/fuses in the first place, sorry but with such a fault it is impossible for anybody on this forum to remotely guess what could be wrong with your washer. It could be internal wiring/plugs sockets, control panel switches, control PCB.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Oct 08, 2011 | Miele Washing Machines
I have fault of f53 what does this mean
Hi, Below is a post by a previous fault to you washer, I hope this helps you. taurustech
  • Rank: Guru miele.gif
  • Rating: 92%, 159 Votes
i,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
All the credit goes to taurustech
Jul 15, 2011 | Washing Machines
Fuse keeps blowing
Sorry but with such a fault it is extremely difficult for anybody on this forum to remotely guess what is wrong with your washer. It could be internal wiring/plugs sockets, control panel switches, control PCB.
John C
Jul 09, 2011 | Miele W310 Front Load Washer
MIELE G676 dish washer doesnt start anymore. instead all front panel lights start blinking
Hi I have thge same problem. i sent the circuit board away for testing but no fault found.
really frustrating. hard to find any info for miele machines. Thay want you to call their own v expensive service staff.
if i find a solution ill post it here
May 22, 2011 | Miele G2670SCSF Dishwasher
What the meaning of f53 ptoblem?
Error code F53 on Miele is a speed sensor fault.
It has detected the drum speed to be wrong at some point and has indicated the problem to you.
Have you tried unplugging it. That will reset the computer.
If it's not coming up again after unplugging it, I'd not worry about it.
If it is coming up every time you use it, then you have either a faulty sensor, motor or pcb.
Miele are extremely secretive with information on their appliances and this makes it hard to diagnose accurately faults on them.
May 16, 2011 | Miele Novotronic W1930 Top Load Washer
Miele front loader washing machine W3275- error code F53- what does this mean?
hi,
May 21, 2010 | Miele W865 Front Load Washer
F1 flashing on gas stove-manual says to push clear-where is clear button
HI. This actual code cannot be cleared by pushing the Clear/off button. This actual button will usually be located on the touch pad and is a basic cancel button. You can try to reset the entire control board by simply unplugging the unit for 5 minutes. This may correct the issue. If resetting dose not correct this fault, the necessary actions are to have the defective main PCB replaced, asap.
F1 - Defective control board(PCB)
May 23, 2010 | Frigidaire FGB24S5A Gas Single Oven
Washing Machines Logo
368 people viewed this question
Top Washing Machines Experts
