I CAN'T GET MY M-AUDIO MICROPHONE TO RECORD
What can i do ?
  • Brickz8doZ Jul 17, 2008
    i Installed and all but once it comes to me laying down vocals it doesn't record
  • tjreddy Jan 16, 2009
    i am unable to record voice.I am using toshibha satellite 2050.let me know the solution.
    Sergeant:
  • 243 Answers
Make sure its selected as the microphone
Posted on Aug 22, 2008
When I record vocals with stereo setting it always records left more in favour of the right. Is there a way to fix this?
Your microphone is a mono input (one), therefore recording in stereo is not practical. Stereo inputs are left and right (two inputs). Whatever your recording setup or audio workstation, the track you record to from your microphone needs to mono.
Jun 29, 2011 | Samson C03U Professional Microphone
Samson G-Track recording volume issue
Try using a computer with a dedicated sound card, not an onboard sound chip. A condenser mike can't provide very much power on its own, and requires power from the attached receiver/amplifier.
Jun 04, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
My microphone is not working. What do I do? Trying to use Skype, but microphone want work
Hi ldlw65,
Please follow the below steps to set up your microphone properly :-
  1. Firstly check if your microphone's cable is in proper order, if it has been damaged, then it's that physical fault which stops microphone from working.
  2. Now if the wire or cable of microphone is OK, check if you have connected your microphone in the correct slot , in your motherboard , usually there is a sign of mic besides the microphone slot.
  3. Then check for the control panel's sound and audio devices option , by going in your control panel, if you open it and go in the audio tab you should see your recording device as enabled.
    If it's disabled then you need to install your audio driver's again.
  4. Now , if everything is ok till here , all you need to do is do a microphone check by going to sound recorder (start >programs>accessories >entertainment>sound recorder )in windows xp , in case you are using windows xp or any relevant software in the other operating system which records audio.
  5. Once you have the application like sound recorder try speaking on mic while you activate the record option , if you see that your sound is being recorded, then your mic is functioning properly, if it's not then you need to check if your mic is the current recording device.
  6. To check if your mic is the current recording device , all you need to do it double click on the volume icon on your task bar and you will have volume control box open , then you need to go to the options menu and choose properties.sajjad4help_2.gif
  7. After you choose properties you will have a radio button for recording , select it and you will find devices for recording , then make sure microphone is selected and click ok.sajjad4help_6.gif
  8. After you select ok , then you need to select microphone from the recording options to activate recording via your microphone.sajjad4help_7.gif
Now you should be able to use your microphone properly without any problems.
Your feedback would be appreciated.
Hope this helps ..)
May 13, 2011 | Toshiba (P000257700) Microphone
I connected the microphone on my computer and the system rec.ognized the microphone but I don't know how to use it with the computer to bring out sound
The thing is that the Samson C01U was not designed for live applications. Your solution, if you like delayed sound, is to use Virtual Audio Cable. Otherwise, I would get either a Samson GTrack, or invest in a cheap but functional mixer with a good mic. If you want to record however, you go into your audio recording settings and select the C01U as the recording mic. If you record and hear little sound, go into sound manager... Click on properties and select on Samson C01U. A one channel volume control will pop out. change the volume and record. BTW, a good audio program is Audacity... It's free. I hope that I have helped you...
Apr 27, 2011 | Samson C01U Consumer Microphone
Recording quality just went downhill fast.
Make sure your computer audio is NOT set to "echo" as this will loop the audio back out. This setting can sometimes get set by whatever... it happens.
Apr 29, 2010 | Samson G-TRACK USB RECORDING MICROPHONE...
AT2020 Not showing in recording software
find the drivers online then restart your computer. hook up the mic then restart again
Feb 21, 2009 | Audio Technica Audio-Technica AT2020 -...
Sound problem
ok well u need to save the music first den export it n save it on to ur computer den open it wit ur windows media player or wich ever player u have
Aug 04, 2008 | M-Audio Producer USB Microphone with...
ok thats good, when you go to device manager do you see the USB Microphone listed with no conflicts such as ?, X, !..?
About my mic.
go to control panel:-1-select-sound and audio devices.2-select audio3-in sound recording select your audio driver{creative or other}3-press volume you will see capture screen raise mic volume above and select check box under it.===enjoy recording.
Nov 26, 2007 | Shure Head Set Microphone Microphone
203 people viewed this question
 Grubhead
Grubhead
