Question about HP Photosmart 3310 Printer
HP shotosmart 3310
Scanner failure cannot scan copy or send fax
  • 4 more comments
  • Anonymous Aug 01, 2008
    scanner failure cannot scan copy or send fax error, acts like scanner bar cannot move or is stuck, tore it apart since I have no warranty, couldn't find anything wrong, still same problem, very frustrating, glad I spent a fortune on the best and it stops working after one year, seems to be very typical of every HP printer I have ever owned, this is the fourth, you think I would learn
  • donaldingram Aug 30, 2008
    Scan feature on the HP 3310 has stopped working. No solution at this time.
  • pldillon Dec 08, 2008
  • Anonymous Jan 09, 2009
    ditto here.
  • sctam255 Jan 09, 2009
    ditto
  • Anonymous Feb 07, 2009
    have same problem. can't find fix
I cannot scan any documents
Posted on Nov 05, 2008
I can't get my HP potosmart C6180 ALL IN ONE PRINTER TO SCAN/COPY OR FAX WITHOUT GETTING A SCANNER FAILURE MESSAGE SAYING UNABLE TO SCAN,COPY OR SEND A FAX
Solved! I now can scan wirelessly throughout my network. I downloaded the drivers for a friends newer HP all-in-one scanner and I can scan. Look for the driver for the 309a series of printers and install it. Complete the install and set up your existing printer. You can now scan, print, fax wirelessly. It includes updated HP apps for these functions that work with OS 10.5. I didn't upgrade to the HP 1.1 drivers through Apple. The file name is: PS_AIO_05_C309a_Net_Full_Mac_WW_102.dmg
May 24, 2011 | HP Photosmart C6180 All-In-One InkJet...
My HP Photosmart C5240 will print from computer but will not scan or make copies.
Is there any error message displayed on the control panel of the printer just like one of the following:
Scanner failure, power off and on
Scanner System Failure
Scanner failed, cannot make copies or fax
Scanner failure. Unable to scan, copy, or send a fax
Scanner failure, cycle power
You may want to try following these steps:
1. Check if the scanner light does turn on when you initiated the scanning process, if not you need to reset the product.
2. Try using your other electrical outlet because your AVR or Surge Extension may not be providing enough voltage for the printer.
3. Try using dirty cycle, meaning you need to directly cut the power of your printer by pulling of the power cord from the rear side of your printer and wait for about 30 seconds before inserting again and turn it on.
If all these steps do not improve your printer functionality, you may want to call the HP online help and ask for replacement.
Job Espinosa
Feb 15, 2011 | HP Photosmart C5280 Printer
I just got my printer its an hp officejet 4500 model G510g. i got it not too long ago about two weeks and when i turn on the printer after it says warming up, it says "scaner failure. unable to scan,...
Your printer should still be under warranty.
Either take it back to the place where you purchased it or call HP. Their number should be in your manual.
Jan 04, 2011 | Office Equipment & Supplies
When attempting to scan document or copy a document on Photosmart all in one seriers I receive an error message "Scanner failure unable to scan or copy"
try to remove and re install driver, and look into device manager if scanner detected. if not restart you pc and when found new hardware popup browse driver manually.
Apr 10, 2010 | HP Photosmart 3310 Printer
Can't launch fax with HP solution Center
I'm having the same problem... did you ever fix it?
Jul 26, 2009 | HP Photosmart 3310 Printer
HP Officejet Pro L7680 All in One - cannot send faxes - keeps jamming and says "scanner failure unable to scan copy or send a fax. Turn the power off and on and try again" I have done this several times...
The scanner is the problem, the scanner is the real bright light that comes on to scan the orginal document. Does your Scanner lamp come on? mite be burned out? stating scanner failure, doses your scanner move when it scannes the document? Motor or cicruit board that control scanner mite be bad, check the scanner "Home " position sensor maybe the scanner board and main board don't know where the scanner is phyiscal when it goes thur its routine.
Jul 08, 2009 | Office Equipment & Supplies
Hp officejet 5610 Wont scan . Print. Copy
your printer is dead and is uneconomical to repair. sorry
Jan 25, 2009 | HP OfficeJet 7310 All-In-One InkJet...
HP photosmart c7180 scanner failure
you can run a reset on the printer and clear the scanner failure yourself. You can find the instructions at: http://www.inkbank.com.au/webcontent21.htm
good luck...
L.C.
Apr 04, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP Photosmart 3310 Printer Logo
422 people viewed this question
Seeker5211
Seeker5211
