Question about Sony KP-53HS10 TV
Wavy Lines My tv has wavy lines, very dim and noticed expecially when the screen is gray or black. Also there is a small line coming from then left top corner down the left side about 3-4 inches from the side that looks like a shadow of some sort behind the screen. Parts of the line seem to float or move as the picture changes. Any idea on this?
  • djpridemore Sep 12, 2008
    I have been getting wavy lines on the screen (best seen when the screen goes to black or gray, like between commercials) and a somewhat fuzzy picture, especially with reds. Also a faint line down the center of the picture.
  • 70 Answers
Some type of electrical feedback try upgrading your cables or tightening the ones you have. what might work best is a line conditioner i filters out any feedback you may be getting and cleans your power supply they cost from 50.00 and up best buy or circiut city both carry them or online as well
Posted on Sep 21, 2008
Wavy line on a DLP SAMSUNG 65 INCH PROJECTION TV
Bulb does not do anything but project white light. Wavy lines are a digital board problem. You should have a tech look at it.
May 20, 2015 | Samsung Televison & Video
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
How do I fix wavy lines on Hauppauge Wintv hvr950q?
Are they wavy lines throughout the picture or are they just wavy on the side? Waving picture is usually caused by poor power supply filtering. Wavy lines throughout the picture are caused by interference. Try moving the device away from the computer with an extension USB cable it may be picking up interference from the surrounding electronic devices. It could also be defective.
Oct 19, 2014 | Hauppauge WinTV-HVR-950Q (1191) TV Input
Wavy horizontal lines across the screen
It sounds that the main power supply section to your TV has the fault. The horizontal thik lines that appears crawling down across the screen should be of video 'HUM'. Have you replaced the main filter capacitor at the power supply section? If not, replace it along with the main rectifier. The AC power is rectifed by a bridge and applied ot this main filter capcitor. It will have a capacitance value between 120 to 350MFD 450VDC. Check this section. Measure the rectifed DC voltage acorss this main filter capacitor. It should be around 350VDC, if your home power supply line is 220VAC. If it is 110AC, this DC voltage will be around 165VDC; and it should be. If rectified DC voltage found lower than the input AC voltage, replace the rectifier bridge. In some sets, this bridge section have four diodes. Some other circuits, a bridge rectifier stalk may be used.
May 20, 2012 | JVC AV-27050 TV
Thin vertical lines
Those lines are called retrace lines. They are there all the time on projection TVs but you should be able to see them. When you do see them, that's an indication that the kine screen settings are too high or the supply voltage to the kine driver circuit is low or missing. There is a small, black control unit located behind the speaker grill assy in the front of the TV that has 2 sets of 3 controls. A red, blue, and green focus and screen controls. See if you can make the lines dissappear by turning the screen controls counterclockwise. If you can't you'll need to have service come out to troubleshoot it.
michtech
Feb 02, 2009 | RCA D52W19 52" Rear Projection Television
A wavy line with 3 colors
this a convergence problem and the convergence IC's will need replacing along with some testing of resistors and or replacement
to have a technician come out to do this repair will cost about $300 - $350 to get this fixed
Dec 12, 2008 | RCA HD52W59 HDTV Projection Television
Apex gb5108
'I to am getting only wavy blue lines, no sound, doesn't even show channel indicators. TV was off for 4 days, came home turned it on and ten minutes later this screen appeared, it wont even show the menu screen, different channels or video inputs no sound either.
Jun 21, 2008 | Apex Digital GB5108 51" Rear Projection...
Wavy lines across the digital screen of DSC-V1
Can u mail me 1 photo at welcomejee@yahoo.com to understand what exactly happening with your camera?
May 27, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Sylvania 6427FF TV displays wavy verticle lines at top of the screen.
I would suspect defective filter capacitors in the sweep circuits as well as the power supply source voltages.
Aug 07, 2007 | Sylvania 6427FF TV
Sony KP-53HS10 TV Logo
134 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
