I cant get the filter out of my washing machine help please
I have a ariston margherita LBE 12X washing machine and i have never cleaned the filter,the machine is 3yrs old and the drum is now quiet smelly,
i have found the filter but i dont know how to remove it,maybe you could help,i have lost the manual also. The filter will turn but wont come out it really needs to be cleaned.
I hope you can solve my problem
Many thanks iv removed bottom panel ,tried to turn anti clockwise as far as it will let me with some water coming out but no joy levering out .hope u can hlep
  • Anonymous Oct 29, 2008
    i have the same problem do you have to turn the dial it seems? stuck
    i have the same problem i do not seem to be able to turn the dial at the bottom to release it and acces the filter any ideas?
  • 3 Answers
DO NOT keep trying to force the filter, especially not with pliers! Mine wouldn't turn, and when I eventually got it out it was because a coin was stuck in there! Rattle it left and right many times to free the coin, and eventually it will come out, but if you force it, either the plastic filter will break or the coin. Guess which?!
Posted on Oct 29, 2008
  • 1,462 Answers
You probably have something like a bra wire jammed in there. no option but to pull real hard with a pair of pliers.
smell is not caused by filter. often smell is due to using liquid detergent. after you have done filter, put on the hottest wash and change to powder detergent
Posted on Jul 17, 2008
Hi, I had purchased second hand MARGHERITA 2000-AB63 Washine Machine. BUt i dont have manual to operate. Pls Help.
i have ariston marghrita 2000 AB 63 it does not clean cloths and does not dry cloths.whenever i takeout cloths they are so wet that water drops out of these cloths. pl tell me what shall be position of different buttons and knob when i wash wash cotton/tetron mix cloths
Oct 25, 2010 | Ariston Technologies Ariston AWD12 Front...
The filter is usually in the top tray or bottom in the little square.
Hope I helped
Dr Reed
Apr 06, 2010 | Ariston Technologies Ariston AWD12 Front...
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Ariston Margherita ald 1 40 Error code H2O
H2O is the symbol for WATER and probably indicates a WATER related fault on your machine. A pressure switch is the normal way the machines 'sense' when the level is sufficient. Overfilling suggests a faulty switch, which will need to be replaced by a technician. Also, ensure that the machine drains as it should, if not, the pump filter may be blocked.
Jan 03, 2018 | Ariston Technologies Washing Machines
Ariston Margherita 2000 AWD12 Advantage washer dryer filter clean
To clean filter, remove the lower plastic panel at front of washer.
Unscrew the pump filter cover anti-clockwise to remove and clean.
Please rate my fixya solution.
Feb 13, 2009 | Ariston Technologies Ariston AWD12 Front...
Ariston margherita washing machine
I have an old Margherita washing machine year 2000, my problem I don't have user's manual. Can you please provide me or teach me how to operate the machine?
Thanks & regards
ray salac
Aug 16, 2008 | Ariston Technologies Ariston AWD12 Front...
Sometimes a bigger object might block the filter knob, and make it impossible to screw out. Then the only way is to remove the end of the sump hose attached to the filter and remove the stuck object.
(In my filter this object was an Umbraco key) :-)
May 03, 2008 | Ariston Technologies AWD120 13 lb. Washer...
Washing Machines Logo
400 people viewed this question
Top Washing Machines Experts
