Question about Microsoft Windows XP Professional
Drivers for Haier A680
Is it possible for you to recommend the appropriate ethernet controlller for the above named computer?
i formatted the Disk and lost some drivers and cannot connect to the net.
    Sergeant:
  • 234 Answers
Download and install the recovery file software! their you get your lost data or file!
www.recovermyfiles.com/ - 22k
or
www.soft32.com/download_7967.html - 72k -
Posted on Jul 17, 2008
I have a Lenovo Y 410 Model Name :7757 which was running on Windows Vista (32 bit). After the OS crashed, I formatted the hard disk and reloaded Vista. Now my Wireless Lan is not working. I tried every...
Try to update your wlan driver manually.
.Right click on "my computer".
.select manage
.choose device manager
.?other devices
.Network controller
.right click on above network controller.
choose update driver... and try to update your wlan driver manually with the inf file in the WLAN driver Folder.
IT WILL WORK
THANKS
PCCLINIC INDIA
pcclinic3@gmail.com
Aug 19, 2011 | Lenovo 3000 Y410 Notebook
I have reinstalled windows, i need the ethernet and sound drivers for this pc. would it be possible to send a link to download them to a disk?
Download the drivers to the computer you are using. Then burn them to a CD disk.
When you go to download the drivers, Note where they are going First. Write the name of the driver file down. Then look to see where it is going to be downloaded to.
See if it is going to your My Documents folder, (Documents in Vista)
(Start > My Documents for WinXP)
It may go to a sub-folder within the My Documents folder. Downloads.
Double-click on Downloads to see.
It may go directly to your desktop screen.
Have a fresh CD disk in the optical drive. (CD/DVD drive)
Right-click on the file name when you see it.
Left-click on Copy.
Then click on Copy to CD, or the name of your optical drive.
Windows running on the Systemax computer, put the CD with the drivers in it's optical drive.
Go to My Computer.
(Start > My Computer)
Left-click on My Computer.
Now double-click on the optical drive name (Letter. Example; (D:) drive)
Then double-click on the name of the Ethernet driver file.
The Installation Wizard should come up, and lead you through installing.
(Essentially click on Next, Next, and Finish)
Restart your Systemax computer.
Go through the process again to install the Audio (Sound) file.
This is Systemax Support > Downloads,
http://www.supportforyourpc.com/tools/downloads4.asp
Oct 09, 2010 | Systemax Dual-Core AMD Athlon 64 X2 4400+...
Hitachi ext. drive formatted for a PC, but now I want to read it
you need to reformat the drive for MAC...
Use Disk Utility To completely erase a Macintosh hard drive that runs OS X 10.3.x or above—not just individual files on the drive—you can use the Disk Utility that is built into the Macintosh operating system.
How to Use Disk Utility to Erase a Macintosh Hard Drive (OS X 10.3.x or 10.4.x)
  1. You must reboot your computer using the OS X system CD that came with your Macintosh. To do so, follow these steps:
  • Insert the CD into the CD drive.
  • Hold down the C key during the startup process.
  1. Select your preferred language. You will then see the Welcome to the Mac OS X Installer window.
  2. From the Installer Menu Bar, click Open Disk Utility. You will then see the Disk Utility window.
  3. In the left pane of the Disk Utility window, click the drive you want to erase.
  4. In the right pane of the Disk Utility window, click the Erase tab.
  5. From the Volume Format drop-down menu, select Mac OS Extended (Journaled).
  6. In the Name field, highlight the existing text and type the name the hard drive is to be called after it's formatted.
  7. NOTE: If you ever plan to connect another computer running OS 9 to this hard drive, you'll want to install the Mac OS 9 disk driver, so that this disk will be visible from an OS 9-booted computer. If you don't know if you will do this in the future, it's best to install these drivers.
  8. The following are the available security options:
  • Don't Erase Data—This option only rewrites the headers on the disk. Files can be recovered by forensics, disk utilities, and other advanced recovery software.
  • Zero Out Data—There are forensics utilities that, albeit expensive and time consuming, can retrieve zeroed-out data.
  • 7-Pass Erase—This is considered sufficient by government standards to erase data from a disk. It writes random data over the disk seven times. It may take several hours or more to complete this process.
  • 35-Pass Erase—This makes it absolutely impossible to regain any data off the drive. This option takes an extremely long time, possibly more than one day.
  1. Click the radio button in front of 7-Pass Erase (recommended by UD).
  2. Click OK.
  3. Click Erase.
  4. Confirm you want to erase. The program will unmount the volume, partition the drive, and rename the volume to the name you typed in step #7 above.
May 19, 2010 | Hitachi Computers & Internet
How do I reformat an external Hard Drive that came with NTFS to work with MAC OS X version 10.4.11? I've gone to Disk Utility but then I don't know what to do. The instructions say to use the Erase...
Disk UtilityTo completely erase a Macintosh hard drive that runs OS X 10.3.x or above—not just individual files on the drive—you can use the Disk Utility that is built into the Macintosh operating system.
  2. Click OK.
  3. Click Erase.
Apr 28, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
Pc won't let me reformat it i've no disc because it's built in on the hard drive please help
If you want to reformat a harddrive on your current computer, you need to remove the drive and plug it in as a secondary drive on another computer. Then formatting is easy.
Alternatively, you can use your operating system installation disk and format before re-installing your OS.
Mar 09, 2010 | HP Computers & Internet
CD of UMAX AstraPix PC520 PC Webcam has broken. Know who can I Install It.
I am appearing upside down wen using onboard webcam on my haier A680. any assistance would be most helpful & welcome..Thank you..
Jul 03, 2009 | Umax AstraPix PC100 Webcam
Deleted browser driver for dell dem. 4600 desk to windows xp home
Assuming that you deleted the ethernet driver.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_P4_4600&os=WW1&osl=en&catid=&impid
if you placed any other modem in the system, then tell the modem name. or else it is an onboard ethernet. you can driver from the above location
Apr 21, 2009 | Dell Dimension 4600 PC Desktop
Ethernet port on laptob gateway not working
http://support.gateway.com/support/drivers/search.asp?param=MX6447&st=kw
From a computer that has internet access, download the appropriate ethernet driver for your network card from the link above. As for the recovery disk, you'll have to contact Gateway for a replacement disk.
Apr 14, 2009 | Gateway MT3705 Notebook
Drivers for my notebook
try booting from ubunto LIve CD (it is free OS)
it may find your hardware chipset and even u can surf the net from it
Jun 28, 2008 | Microsoft Windows XP Professional
Microsoft Windows XP Professional Logo
734 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
