Question about Dell Inspiron 8600 Notebook
Computer froze When I start my computer I get a message that says that Windows has shut down to prevent damage. It says if this error has occurred before, restart then go into Safe Mode. After this the screen turns blue and nothing else happens. Does this mean that the computer crashed?
  • Anonymous Nov 29, 2008
    1. When I start my computer I get a message that says that Windows has shut down to prevent damage. It says if this error has occurred before, restart then go into Safe Mode. After this the screen turns blue and nothing else happens. Does this mean that the computer crashed?
    Sergeant:
  • 313 Answers
Yes, it does. Try this:
How to Repair Install: ***Also removes Service Packs***
Sometimes the only way to repair XP is to reinstall. You do not have to wipe your partition and start over. Just as with previous versions of Windows you can reinstall right over top of an existing setup. This has the advantage of retaining your installed applications, data and settings. You will lose previously saved System Restore Points but System Restore will begin creating new restore points again immediately following the Repair Install. You will need to reinstall SP2 and any Critical Updates from the Windows Update Site. Be aware that a Repair Install will leave your system vulnerable to the Blaster and Welchia worms. Do not go on line until you have enabled XP's firewall first. Then visit the Windows Update Site to patch your system It is always prudent to backup important data before you make changes to XP.
There are two approaches. The first one should be used if you can still boot to your Windows Desktop. Simply pop the XP CD into the CD-Rom drive and select Install->Upgrade[recommended]. This will install XP overtop of itself in the same way as upgrading from a previous setup. However if your version is an OEM version then you will not have this option. If you do not see the option to Upgrade[recommended] DO NOT choose New Install as that will either overwrite your current setup completely or give you a dual boot setup. Also if you have an older version of XP and have upgraded to a new service pack you will get a message stating that a newer version of Windows was found and you will not be able to run the Upgrade. Create a Slipstream version to solve this problem
If you cannot boot to the Desktop, or you have an OEM version of XP, or you want to remove a service pack then the following should be used to complete a Repair Install.
Boot with the Windows XP CD and at the Setup Screen press the Enter Key
You will be taken to the Windows XP Licensing Agreement. After reading the agreement press F8 to proceed.
The next screen gives you the option to do a fresh (clean) install or to repair the selected Windows XP installation. To run a Repair Install Press "R" at this time.
***CAUTION*** if you do not see the option to repair the selected Windows XP installation DO NOT choose the option to continue installing a fresh copy without repairing as that will overwrite your data and cause unrecoverable data loss.
setup03.jpg Windows XP will copy the necessary files to your Hard Drive to begin the installation and will then reboot. You will see the message that informs you to "Press any key to boot the CD". Do not press any keys this time just wait a few seconds and the Windows Startup Screen will be displayed. Following this you will be greeted by the Windows XP Setup Screens.
setup05.jpg setup06.jpg When Setup has completed you should find all of your previously installed apps and settings are intact.
Posted on Jul 17, 2008
  • Dell Master
  • 1,183 Answers
HI,
The symptoms suggest that windows has crashed. What happens when you select safe mode.Does it log you into safe mode ?
You can follow the steps in the following link
http://tinyurl.com/6cfrpt
Thanks
proton
I have an Window XP 2002 operating system that is shutting down.
this has to be caused mainly due to some hardware problems or hard disk problems. try removing your bus wire the white belt you have connected with your hard disk and reconnect it again . if it doesnt work try replacing a ram for temporary to chech the problem whether its caused by ram. let me know if the problem persists.. thank u :)
Jul 13, 2010 | Microsoft Windows XP Home Edition
My computer is stuck in a roboot loop. i have windows xp OS. it suddenly shutted down n when i start my computer now, it shows me a blue screen with message that a problem has been detected and windows has...
a_mamatha
If you can reply back with the error message as well this will better help me see what is going on with your computer. If you look at the link below it will show you the info that I looking for.
http://www.fixya.com/support/r4443711-blue_screen_death_bsod_important_info
Issken
Apr 14, 2010 | Dell Computers & Internet
Unable to get into safe mode
hi there !
-try t drain everything out of the computer first; remove the power adapter then remove the battery; after 1 minute try again; if problem persists run diagnostics
--while the computer is off, press and hld the "Fn" key then press the power button at the same time to start the test; note down error message then consult manufacturer for the code obtained. if no errors found it is a windows problem; you need to reinstall windows on the computer
cheers!
Sep 28, 2009 | Dell Vostro 1700 Notebook
I hav a laptop cq60-104tu. i want to install xp on it but it gives an error message. what should i do???
Go to the bios and change the SATA into ATA before installing window xp. You will find this option under hard disk type.
Sep 25, 2009 | Computers & Internet
Blue Screen on Windows XP
Sometimes there are conflicts that cause errors to show up, I am glad you mentioned that no new hardware or software have been installed. That helps to rule out some things. At this juncture, if it only occurred once, reboot and don't worry. If you see it again, it will most likely tell you a error occurred at such and such a place and the computer will now shut down. If this happens try to write down the offending part or error and contact us again. However, it is always prudent to backup your computer. You can go in to the setup and look in you event log to see if it was a heat event that will cause your computer to shut down. Should this screen appears again, try the following:
Check to be sure you have adequate disk space. If a driver is identified in the Stop message, disable the driver or check with the manufacturer for driver updates. Pay attention to the video adapters.
Check for any BIOS updates. Disable BIOS memory options such as caching or shadowing. If you need to use Safe Mode to remove or disable components, restart your computer, press F8 to select Advanced Start up Options, and then select Safe Mode.
Tech Information:
*** STOP: 0x0000007E (0xC0000005, 0xF85F9AD9, 0xF898B7A4, 0xF898B4
please leave me a rating...
May 15, 2009 | Microsoft Windows XP Professional
A problem has been detected and windows has been shut down to pre
this error comes from hardware .restart the system and press F8 key in start then choose safemode option and log on the system.then remove the software which you install on the system before error.try it it solve this problem......rate it
Apr 16, 2009 | Computers & Internet
Computer will not boot up
need to reinstall windows it is corrupted
Mar 27, 2009 | Dell Dimension 2400 PC Desktop
My computer shut down windows to prevent damage from my computer
Try tapping the F5 or F8 key (could be either one) right after you power up. This should take you to a short text message with a couple of choices to continue; you'll find the Safe Mode option there.
Sep 27, 2008 | Compaq Armada E500 Notebook
For solving blue screen error
HP Notebook PCs - "Windows Unsafe or Sudden Shutdown" Blue Screen Error Occurs During Startup or Boot
Description
Windows XP may not start and the following error message may appear on a blue screen:
This error occurs after Windows was not shutdown using a safe method. The notebook may have been turned off without clicking Shut Down or briefly pressing the computers Power button. The power may have been suddenly disconnected from the computer or the Power button may have been held for more than 5 seconds.
An unsafe shutdown can damage some of the Windows system files, preventing the computer from starting properly.
Solution
If the error occurs allow the operating system to complete a check of the hard disk. Windows will prompt your to run CHKDSK. CHKDSK scans the hard drive for damaged files and repairs the files if necessary. The scan may take up to an hour depending on the size of the hard drive and the number of damaged files. The computer will restart when the scan is complete and Windows should start normally.
If Windows will not start or the computer will not boot after the scan is complete see: HP Notebook PCs - Troubleshooting a Startup or No Boot Problem (In English)
use the link to know how to use recovery option with hp laptop
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=us&dlc=en&product=18703&docname=c00608578#
_____________________________________________________
Thanks and Regard
dilipbagdi
Technical Associate
May 18, 2008 | HP Pavilion dv9000z Notebook
Dell Inspiron 8600 Notebook Logo
186 people viewed this question
Alun Cox
