-i dowloaded game to the pc
-i have n-gage installed in the mobile(it has only demo games)
-i cannot install it using nokia application installer
-its in the exe format in the pc
-pls help me
How can i install n-gage .rar file in to n82
F u have * .rar file or zip with 2/3 folders ( Apps , Libs , Programs )
* 1. This type is the easiest . Firstly connect your Phone to your PC
* (or put your MMC inside card reader)
* 2. Open the files with winrar(www.rarlabs.com). There should be 2/3 folder
* System / Apps / ??????? ----- any game folder ie. 6RAV / 6R12 etc.
* System / Libs ----- Library files (VERY IMPORTANT)
* System / PROGRAMS ----- for games that (supposely) support N-Gage Arena Only*
* if it s not there then don't worry .
* 3. Then Just EXTRACT/UNRAR/UNZIP the files with the folder to your MMC. This is using the USB cable method .
* ie. if your MMC is drive E: -- then extract the game folder files to
E / . Then using any filemanager ( Fexplorer ) make a new folder with
the exact name of the ngage game folder in E / SYSTEM / APPS / .
Example , if the ngage game folder is named 6R56 , then make a new
folder in the specified path with the same name ( E / SYSTEM / APPS /
6R56 ). Then copy the contents of the game folder from E / SYSTEM /
.......... to E / SYSTEM / APPS / ????? ( NEW GAME FOLDER CREATED ) .
The same applies ti LIBS and PROGRAM folders.
* using CARD READER if your MMC is drive E: -- then extract the game
folder files to E / SYSTEM / APPS / ????? ( GAME FOLDER ). the same
applies to the LIBS and PROGRAM folders if they are present ie. E /
SYSTEM / LIBS and E/SYSTEM / PROGRAMS
* 4. Next just disconnect your Phone from your PC
* (or put your MMC back to your Phone if you are using card reader)
* 5. Finally restart your Phone. New Icon will appear and you are ready to go!
* ( just switch on your Phone if using the card reader method )
* WHEN INSTALLING THESE GAMES YOU WILL HAVE TO OVERWRITE ANY FILES IN THE 'LIBS' FOLDER IF ASKED TO DO SO !!!
If the download is in the .exe format, you just have to do the following tips : 1. connect your phone via usb cable 2. choose the memory reader in the phone option 3. Unzip the rar and run the exe and follow the instruction.. 4. It will ask if you read your mmc card automatically and tick the option i have installed the N-Gage application, click Next.. 5. Voila..it'll automatically download the game and installed it in your memory card..
I did it on nokia n73 and it didnt working
SOURCE: ngage game
You need to extract the files from the rar file and put them in the Apps folder in your memory card. You can use Winrar to extract the rar files. You may download the Winrar from www.rarlabs.com
SOURCE: ngage software removed
Update your phones firmware first by using Nokia PC suitthen install N-gage software.
f u have * .rar file or zip with 2/3 folders ( Apps , Libs , Programs )
* ie. if your MMC is drive E: -- then extract the game folder files to E / . Then using any filemanager ( Fexplorer ) make a new folder with the exact name of the ngage game folder in E / SYSTEM / APPS / . Example , if the ngage game folder is named 6R56 , then make a new folder in the specified path with the same name ( E / SYSTEM / APPS / 6R56 ). Then copy the contents of the game folder from E / SYSTEM / .......... to E / SYSTEM / APPS / ????? ( NEW GAME FOLDER CREATED ) . The same applies ti LIBS and PROGRAM folders.
* using CARD READER if your MMC is drive E: -- then extract the game folder files to E / SYSTEM / APPS / ????? ( GAME FOLDER ). the same applies to the LIBS and PROGRAM folders if they are present ie. E / SYSTEM / LIBS and E/SYSTEM / PROGRAMS
tryed to download fexplorer but my nokia n82 says its not supported so i cannot install it i tryed to manually add the same name for the new folder but it tells me to use a different name.
