Question about ElectroVoice . Speaker
Convert sb121 to sb121xp/sb122 by installing crossover posssible?
Can this be done? I have a great set of sb121's I use with zx-1 satellites.and don't want to buy sb122's. I don't want an outboard crossover. Can the crossover be installed in the sb121? I believe they used to be available as sb121xp's. Is the crossover attached to the jack plate and just a matter of switching them out? What would the part number and approximate cost be (Is it worth it)?
  • 1 more comment
  • sparky589 Jul 17, 2008
    I found the crossover (part# xpsb2002) from the sb121xp is no longer available. The crossover assembly (part# 560487000) from the sb122 is available from EV for $21.35 ea. Can anyone tell me if this part is compatible with the sb121?
    Is there anything other than removing/disconnecting the stock jack plate and replacing with the new assembly (no other parts etc)?
    Thanks everybody-now I've got work to do.
  • 97 Answers
No there isnt, it is compatible and at that price you wont fid better unless you go to www.ebay.com. hope this helps.
Posted on Jul 17, 2008
    Sergeant:
    Champion:
  • 417 Answers
Yes That is compatible
  • nicholas Rokkasarno
    nicholas Rokkasarno Jul 17, 2008
    $21.35 ea Is A Barging i cant find any were else cheaper
I have a bose av321 series2 gsx media center and satellite speakers and also have cinemate subwoofer need to connect them is it possible
  1. Probably not. Bose has their own laws of acoustics and all eq. and crossover points are done inside. You need a separate crossover component to accomplish this. From a professional viewpoint, we always say BOSE = Buy Other Sound Equipment and the EQ/Crossover/phasing trickery inside every Bose system is a large reason for this.
Nov 15, 2017 | Bose Audio Players & Recorders
Tip
How to convert and burn any videos to DVD?
This guide helps you to convert and burn AVI/MPEG/DivX/Mov/RMVB and any videos to DVD:
Tools required: Cucusoft video to DVD converter
More information of dvd creator
resource:free dvd burner
Install and launch Cucusoft video to DVD converter pro, you will see the UI below.
1. Select radio button "To DVD"
2.choose the "merge" or "batch" tab.
3.Click "Open" button to open your movie file(s)
4. (optional) Set your preference. Region "4" in red frames can set the output MPEG properties.
5. (Optional) Set the advanced settings as following.
6. Click "Convert" button to start the conversion task
7. After you click "Convert" button, the following dialog will pop up automatically.
8. After video conversion done, the "CD/DVD Burning engine" will be launched automatically. Please choose the DVD burner.
9.Please place a DVD-/+R/RW disc into your DVD burner. If it is arewritable disc, the program will erase the disc before burning DVDdisc.
10. When burning DVD is done, the DVD disc will be ejectautomatically. You can also find the output file at the output folder.
on Feb 03, 2010 | Computers & Internet
Peavey xt22 horn not working
Across the diaphram you should be reading about 8 ohms. it sounds to me like it's blown.However,if you think it'ds thre crossove, take it out and send it to Peavey. They do good , fastwork.............................................................
Mar 23, 2017 | Music
Toshiba Satellite 1805-S254 beeps"long, short,
sounds like you have bad memory. if you have 2 installed try taking 1 out and restart.if that don t work install it back in and take the other 1 out to see which 1 might be bad
May 25, 2011 | Toshiba Satellite 1805-S254 Notebook
Cerwin Vega SUB8...how do I connect
grady66,
We will start with the easy one, Phase. The phase selector is a setting that can be adjusted by sound; which one sounds better? Either one will work fine. It's mainly for situations where the sub enclosure is located at a distance or behind the listening area. The 'in and out' crossover selector and the input from the receiver goes together. The 'in and out' crossover selector is asking if you want to use the internal crossover to block the bass from getting to the satellite speakers. Most home surround sound receivers only have the one sub out and most subs have both left and right inputs. When there is a single signal being fed to the sub you use the subs left input or buy a splitter and send the signal into both left and right, but either way will work equally the same.
There is two ways to connect the speakers to the receiver.
1) Cross-over 'In': you connect the output speaker wires from the receiver to the speaker inputs on the sub and the speaker outputs on the sub to the satellite speakers; the sub will get its sound from the input speaker wires.
2) Cross-over 'Out': you connect the sub to the receiver using the receiver's single sub out, then connect the satellite speakers directly to the receiver's speakers outputs; in this configuration the satellite speakers are given a full range of signal including the bass.
I have used #2 with the same system and had great results.
-Chris
Jul 05, 2010 | Cerwin Vega AVS-5.1 System
Do you have instructions for wiring install on volfenhag GX8200??
Amplifier Class AB
Number of Channels 2
RMS Power (4 ohms) 120 watts x 2 channels
RMS Power (2 ohms) 200 watts x 2 channels
RMS Power (1 ohm) Not Stable
Bridged RMS Power 400 watts x 1 channel
Total RMS Power Output 400 watts
Peak Power Output 1000 watts watts x 1 channel
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.1%
Speaker Level Inputs No
Preamp Outputs 1 pair
Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
High-Pass Crossover Frequency 40 - 250 Hz
Low-Pass Crossover Frequency 40 - 250 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio N/A
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled Yes
Fuse Rating 20A x 2
Dec 24, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
Srt 8 factory kicker system
try running the cables trough a crossover & u can run what u want to what speakers u want
Aug 09, 2008 | Kicker 01C8VR4 Car Subwoofer
DVRMS recordings
Hello there
Well, lowering a bit the settings may solve problems, but decoders too. a new version of DX10 is on site, depending if you use Vista, o XP.
Dec 06, 2007 | HP Media Center m7060n PC Desktop
ElectroVoice . Speaker Logo
433 people viewed this question
Top ElectroVoice Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
 Grubhead
Grubhead
Are you an ElectroVoice Audio Player and Recorder Expert? Answer questions, earn points and help others
