Question about Kenmore 62622 Microwave Oven
Start button on microwave does not work
You can operate the microwave by using other programmed buttons. Cannot do anything that involves using "start".
How do you change the start button?
Model 721-62622 Kenmore
  • lilvan Sep 22, 2008
    my keypad numbers won't work. All the other buttons work but not the numbers.
  • Kenmore Master
  • 9,098 Answers
Some numbers are missing off that model number. Would that be model 721.62622200?
(If not, please reply back with the correct model number off the tag)
If it's cooking with the programmed buttons, but Start is not working, it sounds like the keypad has failed.
The keypad for model number 721.62622200 is no longer available as a separate part.
So you'd have to buy the entire controller assembly, which includes the plastic frame, keypad, and circuit board, etc.
It is part # 4781W1M307A and it runs $110.10 at the Sears parts Web site.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 20, 2008
The start button stopped working. Everything else works on my MCD990B.
I think you are right on the money, the keypad control board is vital to the operation of the microwave oven, if the problem cannot be resolved it will require a complete replacement of the above mentioned part, unfortuneately cost should be considered.
Apr 14, 2012 | Magic Chef CHEF9 Microwave Oven
How do I fix the programmed buttons 1 - 5, they stopped working? We can only use the 6 and above numbers.
You must dismantle the circuit board and check if some grease vapours between touch buttons and the the circuit film. Clean with some wet soft cloth.
Nov 13, 2017 | Whirlpool MH3184XP Microwave Oven
Our 2006 Samsung Microwave has suddenly ceased to heat anything. The clock works and the turn table goes around, but that's it. We had a couple of power outages just before this happened. Could it be...
Press the "Off/Clear' button to cancel anything on the display, and reset the microwave. This is a soft reset and will simply get you out of any program you have started. Press it when the cooking complete reminder appears on the display.
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the GE microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock.
Nov 29, 2010 | Samsung Microwave Ovens
My daewo microwave oven Kor 860A start button doesn't work or function.
Possible that the pad is not working or a possible failure.
Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if contact is not through the microwave will not work.
If only the start button is inactive but you are able to set timing then then the start button pad must be worn out.
Nov 08, 2010 | Daewoo KOR-860A Microwave Oven
Keypad number buttons not working on ge spacesaver microwave - auto program buttoms work?
Very angry. Fairly new, little-used Spacesaver Microwave [3][Clock][Surface Light] buttons now do not work. We never even press [3], just [1] and [2] to warm sandwiches.
Unplugged for an hour. Still not working. Everything else works. We never use anything else. Bad solder joint in circuit board or keypad?
Thank you.
Aug 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Can't use the microwave at all
you have either a bad keypad or control board.
If you have operation of some buttons and not others its the keypad. if you have no operation out of the buttons at all you have a bad control board.
If you turn your microwave on and it sets and the timer counts down you have a bad interlock switch..
please let me know exactly what your microwave does when you set the cook time
Jan 08, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Kenmore 62622 Microwave Oven Logo
813 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
