Toshiba E65 Did PM - Refilled developer - ran 05 - 200 code for setting the DV the simulation ran until it would go into the adjust mode than showed error with no error code. Changed the toner sensor on the DV unit still same problem. Tried to make copies with out setting DV and all I get is add toner forever and the drum turning black. Moved entire "guts" of machine into another machine and had no problems. Took the "guts" out of that machine and placed into the original Iam talking about and had exactly the same problems.
  • 1,326 Answers
How about the drum bias is it getting grounded. How about this was there a problem there before you did the developer change? Did you replace the opc and reset the counter? How about this... did you switch out one unit at a time... switching them out one at a time till the problem shows up. Also change the primary and trans fer you may have a arching problem???
Posted on Jul 18, 2008
Dear sir,good day, during copying two blank(white) column detected on paper .can u help us ?
I do not know your product .any way this two blank lines means :-
1-the charge roller is not clean .
2- the corrona wire is dirty
3-first of all the glasses should be cleaned.
i hope thats help
Jan 13, 2017 | Office Equipment & Supplies
350 Toshiba copier paper is stuck where is the problem
Need mush more information on this problem to assist in any way.
Jan 13, 2017 | Toshiba Office Equipment & Supplies
Toshiba e-Studio 456 Error Codes F901
The challenge is with the speed of LGC is not corresponding to the model of the machine installed now try to check it if theres no harness for connecting to the connectors of LGC Board of CN311 and CN316
Jan 09, 2017 | Toshiba Office Equipment & Supplies
Bizhub C250 using to much toner. Images are very dark. Ink can even be rubbed off pages. How do you adjust?
Check that the fuser is not in enevople mode. two green handle up not down. check the files
Oct 28, 2016 | Konica Minolta bizhub C250 All-In-One...
Toshiba estudio 455 Error Code E030
E030 indicates jam error on exit...U need to see where the paper stop and why...
Jul 28, 2015 | Toshiba Office Equipment & Supplies
How do i solve an error e000-0000 canon ir 2202 please
Dear
Its related to the fixing temp. do the error clear on service mode. then check the fixing film assy. heater circuit contact points for corrosion. Replace it.
Thanks.
Dec 12, 2014 | Canon Office Equipment & Supplies
I have a donated photocopier for the scout group and it has a code which no-one knows. Speaking to an IT Engineer we should be able to rest to factory settings. We have tried Admin as user name and admin...
Really depends on the model/maker.
Sharp photocopier? try one of those: (note the capital A and S )
Login Name: Administrator
Password: admin
or
Username: admin
Password: Sharp
Oct 02, 2014 | Office Equipment & Supplies
Scanner computer cant comunicate
What do you want Darrell?
Code reader or Professional scan tool?
I think your going to need a shop to work on it
Without wiring diagrams your done
You have to chase every wire from the under dash
connect to their ends, until you fix the issue & can
connect to the Bus & Data stream,we can't help with that
Jul 17, 2014 | Office Equipment & Supplies
Forgot password toshiba estudio 450
The default password is either 12345 or 123456.
If neither of those work then, turn machine off then power on while pressing the 0 & 8 keys then enter 263, then press Start. It will then display the Admin Password.
Oct 23, 2009 | Toshiba Estudio 200L Copier
Open Questions:
126 people viewed this question
k24674
