Question about Whirlpool Duet GHW9150P Front Load Washer
Door won't close now
During the wash cycle, load got unbalanced.  It walked across the floor, then when I found it the door was popped open.  Now the door won't close.
I don't get any error messages, but the panel flashes.  I read about pulling a door latch release, but don't know how to get front panel off.
  • 246 Answers
I can tell you where the door latch release is.
Remove the lower front panel. (there are 3 #20 torx screws on the bottom of it holding it on towards the bottom) Once you have that panel removed, reach up just behind where you see the openings for the door latch. the black square hole and black round hol are all part of a larger door latch mechanisim. At the bottom of this mechanisim (cloest to where your hand will be) there is a "tab hanging off the bottom". Pull on the tab for a manual door release.
Please make sure if you found this solution helkful to make sure you rate it. Best of luck with it and drop me a note if you have any other troubles.
Posted on Jul 25, 2008
2 Suggested Answers
SOURCE: maytag pav2300 spin cycle spins unbalanced and walks
I have the same problem from day one........... help
Posted on Dec 19, 2009
Maytag washing machine walks across floor during spin cycle
Did you set the back feet before leveling? On most units to set and lock the back feet you need to pull the top towards you so that the back is raised off the floor, then set it down again, this will release the feet and lock then down. The you level the two front feet. After this is done you must make sure your load is balanced. Distribute the items as evenly as you can in the tub. Once it gets to the spin cycle if its walking or shaking a lot, stop it and redistribute the items more evenly in the tub. Also try not to overload the unit or combining many heavy items with few light ones. If this is a new machine, did you remove the shipping locks from the back before using it? They have plastic strips attached to them, make sure they have all been removed, as well as any shipping bolts.
Feb 17, 2015 | Maytag Neptune MAH6700A Front Load Washer
Maytag fabric matic washer started walking across floor on spin cycle?
Usually an unbalanced load, but check if rubber feet are worn through.
Jan 03, 2015 | Maytag Washing Machines
Washer walks across floor on spin cycle and my level says its level
If the level is registering the machine as level, then you probably have an unbalanced load that is causing it to "walk." When it starts walking, lift the lid, wait until the spinning stops and redistribute the articles in the basket. I hope this helps. If you're satisfied with my solution, please rate my solution on Fixya.
Nov 19, 2010 | Amana Washing Machines
Maytag pav2300 spin cycle spins unbalanced and walks
Dec 16, 2009 | Maytag PAV2300 Top Load Washer
Washer door won't unlock
im sorry to tell you but you may need to get a repair man out to fix the lock from the inside of the washer its sort of stoped half way through its washing cycel
i gess the drum suport springs have poped off and thats why it went for a walkys in the first place
Oct 25, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washer runs quietly steadily except during spin cycle, when it tries to walk out the door. Have leveled the machine,even strengthened and leveled the floor.
Does it always do this or does it only happen when the load is unbalanced? In other words once this starts to happen can you lift the lid and rearrange the clothes within to balance the load and try again.
Mar 30, 2009 | Kenmore 24032\24036 Top Load Washer
Door pops open during wash cycle
this is joyce
What I would do in this situation is fix the door lock first before I would do another load of clothes. you can go to Kenmore.com put in your model # and download your manual to your machine if you want to fix yourself
or you can call service tech out. I will help you find one in your area if you need.
thanks,
joyce
Feb 04, 2009 | Kenmore 44072 Front Load Washer
Unbalanced washing machine
there may be shipping bolts that you have to remove.read your instructions 2 see
Jan 02, 2009 | Maytag Performa PAV2200
LG Intello Washer DD 7Kg. WD-1460FHD
did you remove the shipping bolts before you starting using it consult your owners manual under installation for location and removal procedures all washers have them to stabilize them during shipping
Jan 02, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
198 people viewed this question
Dan Webster
Dan Webster
Sal De
