Question about Universal Interactive 4 X 4 EVO 2 for GameCube
Nicktoons unite At level chum bucket, how do I defeat the robot that appears after Plankton says "prepared to be crushed."
  • 375 Answers
Have Sponge Bob drop a bubble. them pick it up and throw it so it explodes on the robot crab. he will then turn upside down. Get in a bunch of hits. Repeat untill defeated.
Posted on Jul 17, 2008
Cheats and cheat codes
Candy Crush Saga Level 213 help, tips and tricks In Candy Crush Saga level 213 we need to clear all of the Jelly blocks and score at least 130,000 points within 40 moves to defeat this level.
How to Beat Candy Crush Saga Level 213 (cheats ?) In level 213 we can see that we have double jellies everywhere, so we will need to do some serious clearing of candies in the board.
If we can make the wrapped candy + wrapped candy combo just outside the meringues perimeter, this will help us out a lot, but there's still a lot to be done to clear this game.
Once the chocolate fountains come into play we will face even more distractions and make the game even more difficult.
We should keep track of which jellies has been cleared so we don't need to worry about those candy squares afterwards if the chocolates covers it up.
There will be 70 pieces of jellies we need to get, so we should make the best candy combos that can crush through the meringues and get to the jellies underneath.
The bottom pieces are of course the hardest ones to clear here, so any vertical candies we make will be extra helpful in passing through here.
Stars
1 star: 130,000 points
2 stars: 250,000 points
3 stars: 300,000 points
Candy Crush Saga Level 213 Help Tips Tricks and Cheats
Feb 25, 2014 | Microsoft Video Game Consoles & Games
Dispenses crushed ice only, not cubed
remove the dispenser bucket where the ice drops into inside the freezer and get a Tupper ware bowl,remove the bucket and dump this ice into the bowl,then rinse with the dispenser bucket with warm tap water to melt any ice on each end of this ice maker,then wipe dry and replace into freezer where you removed it to get cold again and leave empty till the next harvest of ice,this can be normal on some units after so many weeks,as it will not let the blades retract so as just to dispense only cubes,once bucket is cleaned of ice jams the solenoid and blades will again retract for cubes only
Feb 10, 2013 | Refrigerators
When I choose either cubes or crushed on my icemaker, my unit only crushes the ice. I already had the water inlet control valve replaced and there are plenty of cubes in the bin. It is a dispensing issue...
this manufacture makes 2 seperate style ice buckets one in the door and one in freezer with a large ice bucket and auger screw that turns... first we will explain the one up on a shelf in freezer side up top... if you pull your ice bucket completely out of freezer... there should be a small bar coming out of rear toward bottom of ice bucket assembly now put it back in where you got it but this time watch where the rod goes... there is a solenoid in the rear of freezer actually called cube/crush solenoid and what this does is if switched to crush will raise that rod and activate the teeth in bucket to crush ice... if not will let ice fall out in whole piece...this solenoid sometimes gets hung or will freeze ...make sure with your finger you can move it freely and then watch it with some assistant pushing the switch for you does it go up when the handle is hit... the ice bucket in door works the same way except the componets are in the door and a little harder to access... repost with any questions if this doen not help you out...good luck to you
Jan 19, 2011 | Whirlpool Refrigerators
Im stuck on a level on nicktoons:attack of the toybots
http://www.youtube.com/results?search_type=&search_query=nicktoons+attack+of+the+toy+park+amity&aq=f
lots of tips for this game. just look for the level you need and follow on screen vid.
Mar 01, 2009 | THQ Nicktoons : Attack of the Toybots for...
Dispensing problems
Check that the crush mechanism is not jammed with ice. That could prevent it from disengaging.
Dec 31, 2008 | GE GSS25LGM Side by Side Refrigerator
SPONGEBOB MOVIE GAME
go around him by hiding behind things so he doesnt see you
Nov 22, 2008 | Emerson SpongeBob SquarePants TV
Frigidaire In Door Ice Dispenser
Most likely nothing broken. Just pull out the ice bucket. You will see a metal rod along the bottom area that protrudes into a hole in the back of the freezer. That gizmo has to move up and down freely to set the crusher / cube arm in the correct position. You should be able to move it up and down with your finger. If not, it may be frozen, or have a back solenoid.
Sep 01, 2008 | Refrigerators
Nicktoons Unite - Level 5
At level 6 jellyfish fields, to get the flare you need to destroy the plankton popper, and then jump up to the place where the plankton popper was and as jimmy you stand on the jimmy sign and hit b and then it will open and go in as jimmy.
Jul 17, 2008 | Universal Interactive 4 X 4 EVO 2 for...
Ice despenser
will it still dispense the whole cube?theres a brass rod under yourice bucket, remove bucket and check that rod, should be spring loaded and have a little bit of action(youll see it move a flap in front of bucket as its twisted, if so make sure the bucket is being reinstlled correctly, try the dispensor w/o the bucket installed at all, open the door trip the switch with one hand and depress the plunger for both crushed and cubed and check for the motor to turn
Feb 22, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Universal Interactive 4 X 4 EVO 2 for GameCube Logo
221 people viewed this question
Top Universal Interactive Video Game Consoles & Games Experts
James Wishart
Are you an Universal Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
