Question about Iomega (33090) 250 GB Hard Drive
Windows Vista backup
I would like to do a complete Windows backup to my Iomega hard drive but am unable to as it is formatted with FAT32 and not NTFS.Is it possible to reformat?
    Sergeant:
  • 234 Answers
Hello! You completly uninstall all driver in your computer(such as USB port,sound cord etc...)! And then you insert the NEW OS with bootable CD then you can format! Try it
Posted on Jul 17, 2008
Reformat to FAT32
If you are using windows.
You can right click and when the format dialog box opens look for the drop down arrow that is labeled file system. make sure it says fat32. and then format the drive
Mar 23, 2011 | Iomega 250GB Ego Portable HD Red 250 GB...
Cannot complete full format, it take more than 8 hr and at 99 % complete it stops and says "format not complete" , (it works when doing quick format but iam unable to use the drive on my ps3, and...
Welcome to Fixya. If you want to use the drive to your PS3 Console you can still do a Quick Format on the Hard Drive but make sure you select Fat32 File System type to be able for the Ps3 to detect the hard drive. Make sure you use Windows XP or Windows 7 on formatting the hard drive to Fat32 because Windows Vista dont have Fat32 it uses ExFat.
Thanks for using Fixya.
Mar 04, 2011 | SmartDisk FireLite 80 GB Hard Drive
How do I format this hard drive to a FAT32 hard drive?
Go to My Computer, right click on the drive, go to format. select fat32 on the type list. Remember that this will delete all of the files on the Hard Drive.
Mar 03, 2011 | Beyond Micro (BM120MD3U2) 120 GB USB 2.0...
WHERE IS THE FAT32 FORMATTER FOR OPERATING SYSTEM WINDOWS VISTA?
Connect it to the pc, open Computer, right click on it and select Format. In the File system section select FAT32.
Feb 15, 2011 | Iomega Prestige 1 TB USB 20 Hard Drive
If I format the drive/erase, will I loose all the files I was able to save there? I can't copy my iPhoto onto my Iomega because it says "cannot be modified." If I format, will I lose all the...
if you format the drive you will loose all the data on the drive. save the file on a different computer before you format it. later you can transfer them back. (please rate me if this helps Thank you)
Dec 22, 2010 | Iomega (33090) 250 GB Hard Drive
I tried connecting my iomega prestige hardisk to my ps3(I just bought) but it is showing no icon or any notification of my hardisk being connected.What should I do to view its contents on ps3? about my...
You need to format your drive as FAT32.
If you are using Windows Vista or 7, you will have to google search for a FAT23 formatting tool. So take your data off the drive. Format the drive, put your files back on the drive and your good to go.
*************CAUTION************
There is a 4GB per file size limitation with FAT32!
Dec 14, 2010 | Iomega Prestige 1 TB USB 20 Hard Drive
Want to use the drive with a mac and windows
To use this drive on both MAC and WIN, the drive needs a FAT32 file formatting system.
Before you continue, check to is if it isn't already FAT32 in which case you could already use it on both.
Windows doesn't allow you to revert to FAT32, if the drive has HFS+ (for MAC) or NTFS (WIN). The best option would be to format it on your MAC.
Double click on your MAC internal drive and select 'applications' > utilities > double click on disk utilities. On the left hand pane, highlight the drive to format. At the bottom of the screen, select 'options' and check MBR (master boot record) and then ok. Under the volume scheme, select current - You can then rename the drive, if you like and under format, select 'MS FAT' (the title of the option may vary a bit, but i'm sure when you see it, you'll know what I mean). Now select 'partition' and then 'partition' again.
Hope that helps and make sure you backup anything you wouldn't want to lose!
Jan 25, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
Iomega 500 gb hard drive: large file transfers
The default format for the IOMega drive is FAT32. This format will work on all versions of Windows, as well as Mac OS9 and above. Unfortunately, FAT32 can't handle files larger than 4gigs. If you want to use larger files, you're going to have to remove all the files from your IOMega drive and use your computer to format it to NTFS (Windows 2000/XP/Vista) or HFS+ (Mac OS9/X).
Consult your owner's manual for specific details.
Sep 12, 2008 | Iomega (33654) Limited Edition 500 GB USB...
Seagate Free Agent 500GB
Actually, the utility that the above commenter states would make you a fortune is called Disk Management and it is built into both Vista and Windows already. You are able to partition a hard drive to have both ntfs and fat32 partitions. There is also another freeware called swissknife. Also, there is an old hp program that is able to format external hard drives larger than 40gb into fat32 format which is an issue for some. So yes it is possible. I can tell you that from experience. I own a 1tb Iomega that I have a 40gb Fat32 partition for my Playstation 3 to read and the rest is NTFS for file transfer speed with my computer.
Feb 23, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Open Questions:
See all Iomega (33090) 250 GB Hard Drive Questions
Iomega (33090) 250 GB Hard Drive Logo
53 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
