Wiring speaker down to lowest ohm - Audio Players & Recorders
  • 1,498 Answers
Wiring a single speaker won't change Ohms.
More than one is a different story.
Parallel wiring is what you're looking for:
Say you have two speakers and one speaker wire.
The positive speaker wire is connected to the positive terminal of each speaker. The same for the negative.
Wiring speakers 'Parallel' will lower the overall impedance according to the following formula:
1/Rtot=1/R1+1/R2+etc......
Say your speakers are 4 Ohms.
Then the formula would be:
1/Rtot=1/4 + 1/4
1/Rtot=1/2 (or .5) Now isolate Rtot
Rtot=1/0.5
Rtot = 2 (Try it on a calculator)
So two 4 ohm speakers in parallel reduces the impedance to two Ohms.
If you found this useful, please take a sec and rate this response.
Have fun,
Mike
Posted on Jul 17, 2008
How to hook it up for one ohm
oh yes the JBL GTi W15GTI Mkll. this subwoofer is a dual 6 ohm voice coil subwoofer. This is impossible to run this sub alone and get 1 ohm you will need another JBL GTi W15kll. the lowest impedance you can go to is 3 ohms. you can achieve this by connecting the positive terminals together and then running a wire from the two positives to the positive terminal on the amp. then connecting the negative terminals together and then running a wire to the negative terminal on the amp. this is a real nice sub it just has that one down fall of having a six ohm voice coil.
Aug 01, 2011 | JBL GTi W15GTi MkII Car Subwoofer
I have a fosgate 8"
Your ohm meter will not give you an accurate reading on a speaker.
It looks like the PL-300 is at lowest, 4 ohm stable. If it is a 2 channel amp (which
I believe it is) drive each speaker with a separate side (Left and Right).
You may damage the amp if you parallel or series the speakers.
7Here is a great site for all electronics info. See #57 on the right side pane for more speaker info.
Basic Car Audio Electronics Site
Apr 22, 2011 | Phase Linear Car Audio & Video
Hello..im trying to find a diagram on how to wire my subs down to 1 ohm..i have 2 12 in. Audiobahn alum12n..they are currently runnimg at 3 ohms on a hifonics 2500 watt 1 channel amp that only supports 1 2...
Hi, if you wire all voice coils in parallel, you will get down to 1.5 ohms. That is the lowest you can go with these 2 subs. Just hook the amps' positive to all 4 positive speaker terminals and the amp negative to all 4 speaker negative terminals. Please let me know if you have more questions, and thanks for using FixYa.
Mar 22, 2011 | AudioBahn Car Audio & Video
The amp turns on and the lights come on and all my wires are hooked up correctly but i still have no sound?
Make sure your RCA's are hooked up, the take a DMM set it to AC volts, turn the deck up about 75% and see if your getting readings where you plug your speakers into the amp. If your not then its the amp, if you are then check your speaker connections again. If the connections are good, set the DMM to ohms and check your speakers. Set the meter to the lowest ohm setting and put + to + & - to - on the speaker terminals. For example if its a 4 ohm speaker the meter should read around 4 ohms it can move alittle like 3.5-4.2 or so, but if the #'s jump around like 55.6-1.2 then more than likely the speaker is fried...Hope this helps
Apr 02, 2010 | MTX Thunder5601 300W x 1 Car Amp Mono...
Have 2 4+4ohm avi sl500 subs how do i wire it to this amp and what setings on this amp alpine mdr m1005 1000watt amp
using these subs will limit you to a 4 oh load to the amp witch will only let the amp produce half of it's power. the lowest ohm load that amp can handle is 2 ohm and the next lowest you can wire the subs is 1 ohm and that will over heat the amp and destroy it. so to answer your question first wire each sub like this diagram shows...
Wiring Option #1
then once both subs are wired this way you wire both positives from each sub to the positive side of the amps speakers terminals and wire each subs neg. to the amps neg speakers terminal. the wire is series parrelle and will present a 4 ohm load witch will be the safest to run with your amp.
Jan 19, 2010 | Alpine MRD-M1005 1000 Watt Mono Amplifier...
I wont to know if i can run 2 2410s concept amps bridged and how to do it thank you .they can run at 2410 watts at 1ohm or 1150watts at 2ohm .iam wanting to hook them up on a rdaudio v2 15 that is duel...
If you only have one of those speakers the lowest load you could present to an amp would be 2 ohms. So 1 ohm is out of the question. I would advise you to get another speaker and use 1 amp per speaker bridged mono @ 2 ohms. Connecting the outputs of power amps together is not advisable.
Dec 18, 2009 | Concept CD-2410 Car Audio Amplifier
IF THE WOOFERS HAVE 2 VOC.COIL EACH HOW DO YOU CONNECT WITH THE AMP THAT HAS ONE CHANNEL WITH TWO + AND TWO -.
it depends on the load you want to present to the amp. un 12, 2009 - If woofers are 2 coil, then you definately need to know the impedance of the coils (are they dual 2 ohm, or dual 4 ohm?). For dual 4 ohm speakers you will only be able to acheive a summed load of 1 or 4 ohms. If your amp can handle 1 ohm, then connect this way: 1 ohm: Connect both the positives and the negatives together on each speaker. This puts them in paralell which will result in a 2 ohm load per speaker. After you connect the two 2 ohm loads to the amp, it will see 1 ohm as it's load. If your amp can handle this, this is usually the lowest configuration capable by consumer stuff, (if you are not doing competition or some crazy thing), and few amps are rated for 1 ohm so it's not really recommended and may heat up or blow your amp. 4 ohm: Connect one negative to one positive terminal on one speaker. Drive the other open terminals with the amp. This places coils in series and results in an 8 ohm load per speaker. After connecting both speakers to the amp, the amp will see a 4 ohm load. In both cases, the rates power of the amp (at that load) will be divided equally between the speakers. Jun 12, 2009 - For dual 2 ohm speakers, the only loads you can achieve are .5 ohm (1/2 ohm), and 2 ohm. The connections are the same as above, and this results in: ...If coils for each speaker are wired in paralell, the results are 1 ohm per speaker, and after connection, the amp sees 1/2 an ohm. (.5 ohm) ...If coils are wired in series, the result is 4 ohms per speaker, and the amp will see 2 ohms after both are connected.
Jun 12, 2009 | Volfenhag ZX-4712 Car Subwoofer
How to ohm down 4 ohm diesel audio
If you have two 4 ohm speakers you can wire them together to create either a 2 ohm or 8 ohm mono load. Have fun!6456b31.jpg
Apr 20, 2009 | Diesel Audio NHS-12 Car Speaker
Bose 901 repair...
Bose 901s series 1-6 are all wired in the same way. that is nine one ohm full range drivers wired in series to produce around 8 or 9 ohms. No way it can be a short, think of the old christmas lights that were wired in series , one light went out, they all went out. I would check the wiring first to make sure no loose connections exist. The only way to access the wiring is to remove each driver from the cabinet. If all wires are intact, You may have a damaged driver. A simple test with a ohm meter will tell you. set to lowest ohm setting, each driver should read 1 ohm. If your speakers dont have the air tubes in back, you have series1 or 2 removing the drivers will not affect the vaccum, just replace the gasket material around the drivers.
Nov 08, 2008 | Bose 901 VI Main / Stereo Speaker
115 people viewed this question
 Grubhead
Grubhead
