Question about Cameras
I have a Canon SRL Rebel 1.5 years old and the flash stoped to work. If I am taking pictures inside the house the pictures are dark( you can see the subject but is dark)and the flash does not activate. When I am taking outside everything is working fine.Could anybody help me, with any suggestion?
  • vizoli Jul 17, 2008
    Thank you.
    Problem Solver:
  • 9 Answers
The flash mechanism is broken. You will have to either take the camera to a repair shop or buy a new one. It could get pretty expensive to fix that. Also I would check with the manufactorer too see if you have any type of warranty left.
Posted on Jul 17, 2008
My Canon Rebel Sii wont take picutres
And the battery is still ok? See the LCD display.
When the battery is almost empty, it won't be able to charge the capacitor in the flash, and the flash can't fire. The camera protects the shot, because if the flash was needed, the shot would be much to dark.
Feb 01, 2014 | Canon Eos Rebel Sii 35mm Camera Body
My Canon EOS rebel suddenly won't take pictures in dim light. The flash pops up and blinks and blinks trying to register the image but won't ever autofocus and take the picture. The light has to be very...
To autofocus the sensor needs a fair amount of contrast (light and dark eges) to operate. If you're trying to take a photo in a dim room of a dark colored subject for instance the focus won't lock and the camera won't take the picture. Try switching your lens to manual focus and shoot that way.
Jan 07, 2011 | Canon EOS 500D / Digital Rebel T1i Digital...
Have Canon EOS Rebel Xsi Digital. Burning smell and flash busy.
Are you trying to use the flash when you are having the problem? Were you taking a lot of pictures with flash when the problem started? Rapid pictures with flash can melt the flash and capacitors in the camera. Also, a single drop of water rolling around inside the camera in the right place can do things like that. You can try taking pictures in bright sunlight so the camera will not try to use the flash and see if it will work normally, If it does than something is probably fried in the flash system. Bad thing is that if you smelled smoke something is most likely already fried and will have to be repaired by canon. Canons quality has been going down hill for several years now and they have a lot of quality problems. If the camera has been used very little, has never been abused, dropped or wet and not far out of warranty, try using google to see if this is a common problem and call canon and try to get them to repair it for free. If all else fails threaten to replace it with a Nikon assume pay to have barely used camera fixed.
Sep 29, 2009 | Canon EOS Rebel XSi Digital Camera
Canon EOS Rebel S taking bad pictures
Your camera has a faulty shutter or shutter timer.
Given that you can buy a perfectly good Rebel S for anywhere between £1 to £25 on Ebay it's not economical to repair it.
Jul 01, 2009 | Canon EOS Rebel K2 35mm SLR Camera
Missing light on pictures
Hi Louise. I found you anyway!
Troubleshooting this could get complicated, so I want to try some basic stuff first and get that out of the way.
First: Let's check your camera settings, You may have accidentally set the exposure setting incorrectly. Have you tried resetting your camera back to factory default? The way to do it is in Setup Menu number 2. Scroll down to "Clear All Camera Settings". Then press the Set button. This will take your camera back to like it was when you took it out of the box.
Now try taking a picture, If you still have the same problem, let me know by commenting in this session and we'll move on to step #2.
Rob
Mar 01, 2009 | Canon Digital Rebel / EOS-300D Digital...
Canon 350d slr flash problems
fiist the built in flash isn't super powerfull , try the green cornered (auto) mode inside home, be shure to make it a dark site , zoom in on a subject in the dark and the camera should pop up the flash, loading the flesh costs a bit time and power so be shure that the accu is full , if the flash doen't react check in the manual if it isn't switdhed off , bur in auto mode it should popup and flash , if you take pictures in the dark often a lens with a greater light sensivity is a usefull option , normal lenses go from 1:3.3 - 5.6 (for example) a light ensivity lense is a f2.8 , f1.8 or f1.4 in diafragma . lenses tha have the same diafraga (f2.8) over the entire range are more expensive and ussually better than a lens from f2.6 - f 4 in the same zoom range
Aug 19, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon powershot SD600 - flash doesn't work
It could be the sensor or a short in the flash wiring. You should take it into a camera shop and have them look at it. You could be covered under warranty if the camera is less than a year old.
Jun 22, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Built-in flash does not work
DO NOT MESS with a new camera (or any other new equipment).
Take/send it back to the vendor, The purchaser has rights also. Number one it must work.
I don't know your location but in UK (& Europe) we have very strict consumer legislation.
Mar 30, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Dark shadow on right side of picture
sounds like a shutter leaf dropping into the image. however, they are usually horizontal and more likely to manifest when in landscape mode. (horizontal, normal)
try using flash pointed up to ceiling.
also, could need to check for auto sync speed setting. usually 1/125 to 1/60. if its off, it could be catching the shutter in the wrong place.
check manual for settings for using flash.
mark
Dec 09, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
CANON Rebel RTI Outdoor pictures are dark
learning to use light metering correctly can have its challenge.
the manual will guide you on how to set up to read light from the subject. spot metering a dark area will cause general overexposure, or a washed out look. spot metering a bright area will cause a dark image. if you are on spot meter and shoot two people standing together against a bright lit background, your meter will see between them if they are centered, and read all that bright background, setting the camera to a less sensitive combination of aperture / shutter speed, resulting in a dark image. use field averaging meter setting and be sure you are metering the subject and not the background. try shooting a wall that is fairly clear of other colors and uniform it light hitting it, you should have a correctly exposed image. since it works in other modes (at least 1, anyway) then it is unlikely you have an exposure compensation issue. that is the only other non defect issue that would cause your problem.
once you confirm that you have these settings correct and still get a dark image, its time to have it serviced.
good luck
mark
Sep 01, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Cameras Logo
129 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
