I have a combo dvd vcr player model #DRC8335. I am at my wit's end, the first one I had I returned because of a clock problem...now this....when I tape a dvd disc or play a prerecorded one, I do not get any audio, just the visual. I CHECKED the connections....seem to be o.k. what should I specifically look for to remedy this....Help Me!!
  • 2 more comments
  • morcara Jul 17, 2008
    Tried the first suggestion, didn't work.
    Don't quite understand the second suggestion...need more help.
    Thanks, will see if it works by unplugging.
    Tried the last suggestion...pressed the audio on the remote....no luck
    Thanks so much....it is working now...and I am finally enjoying the disc. C.
  • 2,071 Answers
You can record the video but no sound,this is common problem of dirt and dust accumulated in the tape head needs to clean;
Sound Problems Step1 Check all cable connections to make sure they're secure. Step2 Change the cable connecting the cassette deck to your receiver. Step3 Clean tape heads with isopropyl alcohol and cotton swabs. Oxide particles can flake off of tapes and collect here. Step4 Clean the contacts on the player and receiver with electronics-grade contact cleaner. Step5 Make sure the cassette output cables are going to the receiver's "tape," "cassette" or "aux" input. The "mon" (monitor) input will produce a low volume. Wow and Flutter Step1 Clean capstan and pinch rollers (the parts that spin around to move the tape) with isopropyl alcohol and cotton swabs. Step2 Inspect any belts (usually thick black rubber bands) that you can see inside the deck for wear. Step3 Replace broken, brittle or stretched belts. Other Problems Step1 Loss of High Frequencies. Make sure the bias settings are correct for the type of tape you're using (I, II or IV) and that the noise-reduction settings used in playback are the same as those used during recording. Check to see if tape heads need to be realigned or replaced. Step2 Incomplete Erasing of Tapes. Demagnetize tape heads with a cassette-deck demagnetizer (available at electronics stores). Check if the erase head needs to be replaced. Step3 Poor Sound With Tapes Made on Other Cassette Decks. Try adjusting the bias. On some high-end decks, this can be set by the user. Step4 Muffled or Garbled Sound, Especially With Tapes Made on Other Decks. Angle of the tape head gap, or azimuth, may need to be realigned by a technician. However, doing this will make tapes you've already recorded with the bad alignment sound wrong. Step5 Tapes Getting Jammed. The capstan is turning but the take-up reel is not, causing loose tape to bunch up and get jammed. Look for a worn or broken belt or a broken gear that might need replacing.
Posted on Jul 17, 2008
    Sergeant:
    Champion:
  • 417 Answers
Make sure the audio cords from the dvd vcr are going to the audio in on the tv its common people put them in the audio out
    Master:
  • 497 Answers
With no cd in the player..goto system menu..in that..selet the default option..this normally wrks in dvd players...hope this wrks for u
all the best
Thanks for using Fixya
  • Yaz  S
    Yaz S Jul 17, 2008
    and also check if u hav attached ur cables to the audio input and not the out jacks
    Novelist:
  • 121 Answers
Trace the cables from the DVD player to the TV. Are you using a reciever or just the DVD combo and a TV? The most common cables used are the RCA cables which are a total of 3 cables consisting of a yellow cable for video and red and white for audio. There are also output jacks on TV's so make sure you have it on the input jack on the TV for audio. Also TV's sometimes have more than 1 input. Make sure you didnt accidentally plug the audio cables (red and white) to a separate input than the video cable. Do the same for the dvd combo because this also has input and output jacks. Make sure you are using the output jacks on the DVD combo and the input jacks on the TV. Keep me posted.
- Tech101
  • Justin Jul 17, 2008
    Hey Morcara,
    You're welcome. I'm glad to hear that it is working now.
    - Tech101
  • 2,427 Answers
The problem could also be how the recorder is ste to record the audio, to verify this on a normal dvd player (if possible) play back the dvd that seems to have no audio, and press the audio button on the remote, this should toggle differnebt audio languages and you should hear the audio on a specific channel. thats the channel its currently set to, go to the recorder setup and change it .
    Sergeant:
    Champion:
  • 230 Answers
This may be due to the settings in tv, sometimes you need to change the settings in the tv for getting the audio make sure about it.Try the hard reset method for the dvd player, that is, unplug all the cables and leave for half an hour and then replug all the cables and try
    Brigadier General:
  • 6,966 Answers
Based on your description of the problem on your RCA unit, pls check:
1. how your audio is connected to your amp or TV. To my knowledge, this model has either an analog Audio (Pair) or Digital Audio (Coaxial);
2. if you can disable Dolby while using analog audio out;
3. if using coaxial audio output (digital) pls verify that the amp or TV has a decoder or a Dolby Digital compatible amplifier.
Should this be not corrective pls consider that several issues has been brought up on this unit, if at all possible, check if you can have it replaced by another brand/model.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role Jul 17, 2008
    Hi again,
    Pls post back with the brand make/model of your TV. Likewise is the RCA DRC8335 connected to a home theater or amplifier or straight to the TV?
  • 813 Answers
Restore your dvd on factory setting your problem will solvs
I have a RCA DVD/VCR combo DRC8335. I tried to put a VHS in it and it won't take it. It is like it is not even reading it. THe VCR power is on but nothing is happening! Now the VCR door is stuck open! ...
The loading basket is defective, or the loading gears are out of alignment. Check for broken gears, belts, and a twisted basket after removing the top cover. If speed is an issue you may need to take it to a technician to see if it can be salvaged.
Apr 30, 2011 | RCA DRC8335
I need a manual for this product. Any chance I can download one? RCA DRC8300N DVD Recorder / VCR Combo
I see RCA no longer has any manuals for that unit. But, is this the exact model number? I mean like I have an RCA DRC8335 VCR/DVD recorder, so I am wondering if it is similar? If so I could work out something for you. Email me at jmsekola@citizens-tel.net if you think I can help with my manual.
Jan 01, 2010 | RCA DRC8300N DVD Recorder/VCR
My combo DVD/VCR DRC8335 will only display HELLO and not respond to the remote or buttons on the face. I have tried the troubleshooting portion of the manual and need help.
I have an rca drc8335 vcr/dvd player that is locked. I have the code to unlock it, but don't know where to post the code. Can you help me?
Dec 12, 2009 | RCA DRC8300N DVD Recorder/VCR
RCA model DRC8335 Loosing the date and time
That will be a problem from the text side of the broadcast, the clock is set from the text transmission, ( in other words a problem from the transmitter ) possibly due to digital switchover or work on the transmitters. One possible solution would be to turn off auto clock setting, and/or auto summer time adjustment.
May 16, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
DVD/VCR picture (and sound) are not on tv screen
Try setting the TV to AV1 & see if the dvd picture appears.There should be a button on the remote to change TV/video. Hope this helps.
Dec 24, 2008 | Sony SLV-D300P DVD Player/VCR
RCA DRC8300N DVD Recorder / VCR Combo manual
Gary. The DRC8335 User Manual is no longer available on Thompson's official support site. But fortunately a few of us downloaded it a year or more ago before it was pulled!
I tried uploading the manual to Fixya several times including just a short while ago. It seemed to upload successfully, but after performing a Fixya search it's still nowhere to be found, just like many others I've uploaded in the past.
But don't worry! You can download it NOW from my personal User and Service Manual archive on OwnerIQ using the hotlink below.
OwnerIQ encrypts all filenames within our personal folders for security purposes which ends-up making them rather unreadable. For this reason, please rename it back to my original filename appearing in blue in the hotlink just below when the download completes
Respectfully, Mike Adams
mikeadams110@yahoo.com
RCA DRC8335 User Manual (PDF 1.92mb) <---click here to begin immediate download
Nov 07, 2008 | RCA DRC8300N DVD Recorder/VCR
Change clock
how do I change the time on my sansui vrdvd4000 dvd player / vcr combo
Nov 06, 2008 | Sansui VRDVD4000 DVD Player/VCR
Zenith XBV443 DVD Player / VCR Combo - Set Clock Manualy
I have the Zenith xbv613 model DVD/VCR player and also need to change the clock set up. For the xbv613 I had to switch the player to VCR. The menu button did not bring the clock set up in DVD. When I switched to VCR and hit the menu button the clock set up showed, where I used to right arrow button to change the time. Hope this helps.
Sep 24, 2008 | Zenith XBV443 DVD Player/VCR
Can i hookup extrnal speakers to my hi-fi vcr-dvd recorder without a tuner or a reciver, my model # drc8335. Think you.
I do not think so because the first problem is that the VCR recorder uses RCA audio cables (the White and Red colored cables) but the speakers use regular speaker wire. You cant convert from RCA to regular speaker wire. Second problem is even if you find a way to convert the wires, the DVD recorder does not amplify the sound signal. In fact all DVD players and recorders including VCR combos do NOT amplify the audio signal so you will barely hear it. The receiver does two jobs. First it converts from RCA cable to speaker cable and Second it also amplifies the signal before it sends it out to a speaker. Thats why a receiver is important.
May 01, 2008 | Televison & Video
RCA DVD RECORDER AND VCR COMBO
Your question is not clear?Are you asking a blank dvd on a home line dvd recorder/player or a blank dvd from a computer or a blank dvd in a dvd camcorder?
Jan 06, 2008 | RCA DRC8335
Televison & Video Logo
128 people viewed this question
Top Televison & Video Experts
