Today my Logitech speakers arrived and i hooked them all up.
I connect them via the optical in on my razzer ac gaming card.
It seems everything works fine, when i do a sound test in windows
(where you pick the speakers to hear a sound) all work, except the
centre speaker.
I made sure its all connected properly and no luck.
I have set it to output DTS and Dolby Digital and always the centre speaker dosn't work.
Is there something im missing? Or something i can try?
I can think of two things., you may need to do the update on your sound card and computer and make sure you have the correct codec's installed or also you may need to go to the web site of the makers of your logitech speakers and see if they have a common solution for this problem...... i also wonder if you should bypass the sound card and directly connect your speaker system to the out put port on your computer ..... give it a try what can it hurt .... if all else fails maybe there is a faulty wire in the speaker system ....... ahy ?
There may be any
speaker problem.............
The possibilities
are
1> to change
the speaker by psp repair shop
2> or any
loose connection
3>any can
change in your psp settings
you can take
your psp to repair shop or else download the repair guide which will help you
to get rid of many problem
Click Here to download repair guide
