Question about HP Pavilion ze2000 Notebook
Screen problem when i turned on my laptop there was a 2 inches highlighted vertical line which really makes me difficult to make some typing jobs because it looks like the letters are highlighted and it makes pictures dark. i hope anybody there could help me solve my problem. thank you so much.
  • 1 more comment
  • rikihara137 Jul 18, 2008
    how do i connect an external monitor to my laptop. im using a hp pavilion ze2000 model.
  • naseerapm Dec 01, 2008
    when i turned on my laptop there was a vertical line on the left side of the screen
    when i turned on my laptop there was a vertical line on the left side if the screen
  • HP Master
  • 13,433 Answers
Im afraid this may be a fault in the display or the video card.
You could test the laptop on another monitor assuming it has a external video connector.
if the picture has the same problems in the external monitor then the problem is in the video card of the laptop, if not then the screen is faulty.
if you have warranty on the laptop, use it. if not you may have to send it in for service and pay the repairs, but as the repairs may come close to 200-500 usd or more, Im not sure if its worth it.
Posted on Jul 17, 2008
  • 45 Answers
Sure, To find out if it is a Display issue or not,
you can connect an external Monitor to the Notebook.
If you see similar display issues then The issue may be fixable otherwise you will have to Replace the Display of your Notebook.
  • Imran Fazil
    Imran Fazil Jul 20, 2008
    To connect the external Monitor,
    You will have to Remove the cable Big blue plug and it might have 2 screws holding it.
    In case you Removed it Connect the Monitor to the same Port with the Very Similar cable on your Notebook...
    (it is like a Jigsaw puzzle you would not be able to amke mistake)
Lines vertical
These lines are called vertical retrace lines, and caused by the video output section; or improperly set screen voltage. All of these type of lines will be a little slanting type, across the screen all over, with an approximate one inch apart to each other. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 21, 2013 | Daewoo DTQ-14U5SC 14" TV
MacBook Screen Repair
well dont fret, sounds like you need a new screen.
http://www.screencountry.com/ has them the cheapest ive found. replacing them does take time and alot of screws but is doable.
check out http://repair4laptop.org/disassembly_apple.html for instructions on replacing the screen for your specfic model. please take care when replacing the screen, there are alot of small part and screws. be sure to work at a clean table and make sure you have a couple hours to do it all at once. I did mine in two days and ended up with 7 extra screws when i was done :)
May 17, 2009 | Apple MacBook PC Notebook
2 vertical line in laptop screen coming
Only way you are going to be able to remove this is by replacing the LCD. It is not a huge job, and not extremely expensive if you can do it yourself.
Here is a link to the maint and service guide that should show you removal and replacement of parts.
http://h10032.www1.hp.com/ctg/Manual/c00637377.pdf
Mar 17, 2009 | Compaq Presario M2000 Notebook
My screen showing a vertical line
Replace the laptop under warranty. No point trying to fix the error and voiding the warranty.
May 25, 2008 | Compaq Presario Notebook
Blue Vertical Line on my laptop screen
Does the line still appear if you plug it into an external monitor? If not sounds like your laptop screen has developed a fault, unlikely to be related to what you did with your camera just coincidence. The only way around this would be to replace the laptop screen. Not an easy job but not too difficult if you can find the same screen for sale on Ebay for example. Either that or replace the laptop and sell the old one on ebay for someone else to fix. Hope that helps Chris
May 22, 2008 | Toshiba Satellite Pro 6000 and 6100 14.1...
Vertical lines in screen
Are the Lines Symetrical in distance and space? Makes a diferernce..
Jan 21, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Red line across top half of screen
Uh-Oh.. Sounds like the BGA RAM in the video circuit. (These units are Intel based and Core 2 duo if posted correct).. We can repair if you need help and its under warranty and sorry its not a home remedy situation..
ikenfixit.com
Jan 17, 2008 | Apple MacBook Pro Laptop Computer with...
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
Vertical lines in my laptop screen
The LCD would start to fail eventually, there is a fix you can try which has worked for some, but it solely depends if you want to try it out, it might revive your LCD...
http://udpix.free.fr/
Dec 09, 2007 | Toshiba Satellite P30 Notebook
HP Pavilion ze2000 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
