Question about Samsung WS32Z308P 32" TV
Samsung WS32Z308P TV has tuned out
Our Samsung WS32Z308P TV is no longer allowing us to change channels via the remote control. Volume and mute is still working via the remote but we just can't change channels. We tried to programme our "Sky" remote to operate the TV through that, but we can't do that either. We queried this with Dixons who advised that the TV may have tuned itself out. Does this happen, what needs to be done to correct the issue - do we just need to call out the service guy? Thanks
I rand the Samsung help desk and they guided me through how to reset the TV back to its original factory settings. This solved the problem.
Posted on Jul 18, 2008
Tivax STB-T9 DTV converter - remote control audio buttons no longer controlling TV audio
Maybe the remote got dropped by the cleaners. If you could control volume with the remote previously and now can't, I suspect the remote needs to be replaced.
Jan 26, 2014 | Televison & Video
Volume working
Code for NEO 1451 TV?(universal remote control)
Aug 14, 2013 | Samsung TV Remote Control
My philips srp5107wm/17 only changes the volume on my tv no matter what device i have it set on
The Philips remote is set to "push trough" the volume/mute to the TV for devices that typically don't have a volume function. Older versions of Philips remote used to allow you to select the device to push volume to, but for some reason this is no longer available (or at least I haven't found out how to). So here is the solution I used.
Teach (learning function) the remote to use whatever device you like for volume/mute.
1, Press the button for the device you would like to change
2. Hold down "learn" and the button you want to teach ex. "volume up" until the red light comes on
3. Place the original remote of the device you would like to change the volume on 5-10 cm away from your Philips remote and press "volume up" for this example
4. Repeat these steps for the "volume down" and "mute" buttons
5. Repeat these steps for other devices you would like to "push through" volume/mute to a device other than TV
Hope this helps others. I did find that some devices like SAT may not allow you to change the volume/mute, but otherwise this workaround does the trick.
May 05, 2012 | Philips SRP5107WM - Universal remote...
My remote won't allow me to turn on our TV but after I turn the TV on, the remote allows me to change the volume and mute but will not allow me to change channels.
I would re-program the remote. I don't belive this is the exact correct code. Some codes kinda work but no fully. That's when it's time for another code for your brand or use the setup and power auto-code search
Apr 08, 2010 | Philips Televison & Video
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Cheers Little Dish Fitter
Sep 21, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
Mitsubishi TV Channel Tuning/Remote Problems
To restore full functionality to your set you must replace the remote that came with set. Universals only control the most basic of functions.
Apr 27, 2017 | Televison & Video
My samsung tv is not responding to my remote control, actually even when I go and attempt to change the channel from pressing the up/down buttons on the tv it won't respons, some menu screen would come on...
your turning section is not responding to any input, hence needs to be checked by a technician. every thing you have mentioned are controlled by one ic, with its respective voltages.
Mar 21, 2009 | Samsung Remote Control
Code for Direct TV remote control
Program AV1 with 20695, program TV with 10765, then switch to AV1, press select/mute, enter 933, and press select
This will allow volume and mute controls while in DTV mode and allow power on and off while in TV mode. This worked for me on the RC32 remote control.
Best of luck
Nov 08, 2007 | Toshiba 14DLV75 14 in. TV/DVD Combo
Remote volume control for Sharp Aquos 42inch LCD not working
ok please open the remote then clean it with pencil eraser.
Oct 09, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Samsung WS32Z308P 32" TV Logo
356 people viewed this question
Henry  Thomas
Henry Thomas
