Question about Kenwood Audio Players & Recorders
Display doesn't work some times comes on but not all the time
  • 2,071 Answers
Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....If i have helped,please click fixya.It is the only way i get paid for my work...
Good luck:
Posted on Jul 18, 2008
Air conditioner display screen doesn't light up
The Control panels go bad. Check with your local salvage yards. They may have a used one, but can probably get you a reman, which is a better choice. In the mean time try hitting it on top of the display a few times. It will probably come back to life.
May 25, 2012 | 1999 Chrysler 300M
My microwave doesn't work, but display works
I would strongly consider replacing the microwave oven, prices have dropped considerably. The problem you are describing is in the keypad controller board.
Apr 01, 2012 | Samsung Microwave Ovens
How to reset sony tv KDS.60A2000 after replacing lamp so the warning doesn't keep coming on
With the set turned off:
RESETTING THE LAMP TIME
When replacing the lamp, use the following to reset the lamp time.
1. If the Self-Diagnostic screen is already displayed, proceed to step 4.
If not, Power off (Set to Standby mode).
2. Press DISPLAY Channel 5 Sound Volume -
POWER
3. To access the Lamp reset, press 5 until the TIME category displays.
4. Press 1 until the RSET item displays.
Mar 01, 2012 | Sony KDS-60A2000 60" HDTV
Doesn't display time of text's
Texts time display is normally set by the network
Dec 19, 2011 | Nokia Classic Cell Phones
Previous homeowner turned off GE Spacesaver 2.0 microwave display and now we can't turn it back on. Tried directions given to press option button 5 times then #1 to turn display back on. Doesn't...
I was not aware you could turn off the display, maybe it is just a bad display and you need to replace the board??!!
Ive been repairing Microwaves for 37 years. i do not remember seeing one where you could just turn off the display.
Oct 16, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
I have a 2004 Pontiac Aztek, from the time I bought it, the display light in the radio doesn't come on(original radio) When the sunlight hits it the right way threw the sunroof, you can tell there is...
Sounds like the back light for the display has gone out. When that happens the clock will still work but the light is not their to push the display through. It is not cost affective to try and fix this just buy a new radio.
Jul 28, 2011 | Car Audio & Video
THERE ARE 2 DIFFERENT POWER WIRES CONNECTING THIS PLAYER TO 12 VOLTS FROM YOUR CAR ... ONE WIRE MAKES THE UNIT WORK WHEN THE KEY IN YOUR IGNITION IS SWITCHED ON AND ANOTHER THAT HAS 12 VOLTS ALL THE TIME TO KEEP THE RADIO CHANNELS PROGRAMMED AND SUPPLIES MAIN POWER TO THE UNIT , MY GUESS IS
THE WIRE THAT CONNECTS TO IGNITION HAS COME APART AND THIS LEAVES YOU WITH
NO DISPLAY ...... CHECK IT ........
Jun 10, 2011 | Car Audio & Video
Dosnt work
If display is scrambled, reset timer: Push reset button while holding down enter button.
If display doesn't show, check AAA batteries.
If timer still doesn't work, then Contact Intermatic.
8000 series comes with 1 year limited warranty
https://parts.intermatic.com/
Intermatic does not show replacement memory board for ET8000 series
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 29, 2011 | Intermatic ET8215C- 7-Day Electronic...
How do you adjust the tanita 1479 scales
what do you mean by adjust it? to calibrate it follow below
Switch off.
2. Press and hold OFF key.
3. Quickly press ON/ZERO key three times then release both keys together. The timing is rather critical, so if it doesn’t work first time, try again.
4. Display shows [ 0.-0- ], followed by [ 0.-1- ].
5. Place 50gm weight on plate.
6. Display shows [ 0.-2- ].
7. Place 100gm on plate.
8. Display reverts to weighing mode.
Mar 12, 2010 | Tanita Health & Beauty
Display zooms and blanks
Sounds like it has a CRT and the EHT is collapsing. Maybe a dry joint around the timebase output transformer.
Mar 18, 2017 | LG Flatron Computers & Internet
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
