Digital Cable Ready Question
I want to buy a Samsung 61" LED DLP Model HL61A750 HDTV and I see on their specs that it says it's not digital cable ready. What does that mean? It doesn't need anything to plug it into the cable and play, right?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 265 Answers
Hey barfinkl1,
"Digital cable ready" TV's have a built-in feature that allows them to receive both standard and high definition signals, typically through the use of CableCARD technology instead of a set-top box.
While this specific Samsung model (HL61A750) is not digital cable ready, it does feature both an ATSC and Clear QAM tuner. This means that it should still be able to receive locally broadcast and unscrambled over-the-air digital signals, but will require a set-top cable box to receive any kind of scrambled digital signal.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jul 17, 2008
Check Fan #1 message on screen.
that would lead me to believe it needed to go to a repair shop.If I were not an electronics minded person .
Sep 26, 2015 | Samsung Hl61a750 61" LED Powered DLP HDTV
White dots on screen
http://www.metacafe.com/watch/yt-XeIOwN1CIp8/samsung_mitsubishi_toshiba_dlp_hd_tv_repair_tips_black_white_dots_on_tv_problems_bad_dlp_chip/
I believe it is the digital projection chip that is beginning to fail. Causing white and black spots to appear. To repair this may cost more than a new tv. If you want to attempt it yourself check out the above link. Hope this helps
Jan 12, 2014 | Samsung Hl61a750 61" LED Powered DLP HDTV
Samsung 61
If using a cable or sat box try a DVD etc when set cold, a box can cause lockup issues via signal.
Not a color wheel is correct, more likely a DMD which is rather pricy and almost as much as the entire light engine which comes with it.
Oct 12, 2012 | Samsung HLP6163W 61" Rear Projection...
I Have A Samsung DLP 61 Model HL-T6187AS and Serail- AHEK3CKPA01439H and It Has No Red What Could Be The Problem
Most likely problem is the Red LED (pt# BP07-00023A, substitute BP07-00029A) $96.68 https://www.encompassparts.com/item/7806544/Samsung/BP07-00029A/Led_Display-red
OR http://www.shopjimmy.com/catalogsearch/result/?q=BP07-00029A
& or the LED driver board (pt# BP94-02321B) $170.00 includes core https://www.encompassparts.com/item/7696533/Samsung/BP94-02321B/Assy_Pcb_S-led_Drive
Don't forget that if you are using component input cables it could be your Red input line either faulty cable or not plugged in all the way on either end.
Oct 03, 2011 | Samsung HLT6187SAX 61" DLP HDTV
The display does not show any reds. The faces are green and some objects are blue or blue green.
Check for good connection from cable to TV , connection is good, check for a bad mother board TV board needs replaced
May 10, 2011 | Samsung 61" Slim-Depth LED DLP HDTV
What is a analog board ? and is it expensive?
Video Board is divided in 2 sections
one is the ANALOG BOARD an the other one is the DIGITAL BOARD
Analog is the old entry like red, yellow and white cable..
Digital is like for computer adapters and usb
Expensive? mmmm.. is arrowed $60-100 depends where you buy..
here a some images of the analog and digital..
this is depending on you model..
some time the capacitor just blow up..
Jan 30, 2010 | Samsung 50" Slim-Depth DLP HDTV
Samsung HL61A750 61 Inch 1080P Led Powered DLP HDTV will not stay on. It can be turned on, but 15 or 20 seconds go by and it goes/tunrs off. Everytime.
It sounds like the lamp bulb, I had the same problem and I took the bulb unit out of the back, cleaned it out really good and replaced it, it works fine now and I didn't have to buy a new bulb unit for about $200.00. Good luck.
Sep 06, 2009 | Samsung Televison & Video
I have a Samsung HL-S6186W 61" DLP HDTV I could get the hd channels over the air with an antenna before but now I can't get any thru cable without going thru my dvd recorder tuner first which degrades the...
Select TV input, Press Menu, Select Channel, in menu Antenna=Cable (for you), (then perhaps, Auto Program with Cable or Air+Cable), tweak Channel List, turn on LNA if needed, shouldn't be.
Somewhere there may be different modulations, some offset the channel a fraction and are important for channels above 13. I'm basing this on my non-cable Samsung HL-T5687.
BTW, I had an HLS until it gave trouble, paid for an upgrade to LED from bulb when I got HLT. Very pleased, until it fails. -Ken
Jul 15, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung hl61750a - unable to display video service over hdmi
I was using an hdmi cable purchased online. A friend told me that it might be the 'cheap' hdmi cable. I tried a set of Monster hdmi cables and problem solved. So all hdmi cables are not the same.
Jan 29, 2009 | Samsung HLN5065W 50" Rear Projection...
Televison & Video Logo
228 people viewed this question
Top Televison & Video Experts
Electro Med Services...
