I need a remote control for a sansui rz 1900 amp/receiver
  • 2,071 Answers
Click this site to order a remote control;
www.sansui.us
Posted on Jul 18, 2008
I need to find a user guide for the sansui gs35, the instructions do not come with the box and I have no idea how to use all of the features. can anyone help with an online guide I can print off?
datasheet,schematic,electronic components, service manual,repairs,tv ... ( welcome to eserviceinfo.com at 04 Jan 11:35 pm GMT) ... Kyocera FS-1900 Service Manual.part1.rar, 24-05-2005, FS-1900 Laser Printer Service Manual, Printers, 2041 kB, 3734 ... Sansui G-8000.part2.rar, 22-08-2006, Service manual for Sansui ... www.eserviceinfo.com/index.php?what=search2&searchstring=sansui rz 1900 www.eserviceinfo.com/index.php?what=search2&searchstring=sansui+rz+1900
checked this site and they definitely have a manual for yr printer. Hope this will help
Feb 06, 2012 | Office Equipment & Supplies
How do I connect Subwoofer in sansui rz 5200 av model receiver?
You could refer to the instructions presumably available for the unnamed sub. THAT would determine the methods it can use.
Aug 17, 2011 | Sansui RZ-5200AV Receiver
I have a Radio Shack 6 in 1 remote (15-1923) and a Sansui RZ-3000 receiver. Had to change the batteries and lost the connection. What code can I use to make this work again?
The Sansui receiver should be programmed manually. Turn on the receiver manually, then press and hold Setup until the light turns on. Press the button that you want to control the receiver. The light will blink once. Aim the remote at the receiver and press On until the unit responds. When the device turns off press ENT within 5 seconds. If you miss the code, press repeatedly Last and then On until the receiver responds. Then press ENT. Check if the code works. If it doesn't repeat the code search but wait longer between key presses.
To record the code, press and hold setup until the light turns on. Then press the device control button. Then press 0-9 individually (wait a few seconds between key presses) until you see the light blink. That will be the first digit in the code. Repeat the 0-9 sequence for the second and third digit in the code.
Radio Shack has the code list and manual here: http://support.radioshack.com/support_video/42245.htm . Sansui CD player, TV and VCR codes are listed in the documentation.
I hope this helps.
Mar 02, 2011 | Televison & Video
I am fixing a sansui rz-5000av receiver /amp. the problem is the power supply,it does not switch on. the fuse is fine, capacitors are all ok. But power does not reach connector for the standby supply to...
So you're saying ac doesn't get very far into the unit. THAT should be easy to diagnose with CARE since ac is usually passed unmodified to the fuses and power supplies, maybe through a relay. Get a digital voltmeter and find out where it disappears after getting into the unit.
Dec 31, 2010 | Sansui RZ-5200AV Receiver
I have a sansui stereo av receiver rz 7000 from 1990 which works on 110 220 230 volts and the receiver has a voltage selector on the back - I need to understand how to move the selector from 220 to 110...
Remove the fuse cover with a flat screwdriver, then pull the surrounding circular black plastic piec straight out and reorient it to show the desired voltage, then plug it in, insert the fuse and cap.
Nov 24, 2010 | Sansui RZ-8150AV Receiver
I have a Sansui receiver Model RZ-1000. The left channel is out. Cheaper to repair? or just buy another similar on ebay?
I have this unit. It is built with disable links for each of the channels, which are easy to replace. The replacement part is only a few dollars.
Oct 11, 2010 | Sansui RZ-5200AV Receiver
Sansui
I need a card with SMD ICs located on the circuit board of my sansui RZ6800 AV Reciever.(its a digital card with function IC and many more SMD components)
Sep 01, 2007 | Audio Players & Recorders
106 people viewed this question
 Grubhead
Grubhead
