My television hisses intermitently. Reception is fine for 5 minutes then 30 seconds of hiss.
  • 8,617 Answers
I will need the model number of your set to help you, sounds like the flyback or splitter is the problem. If you post the model number I should be able to help you determine whats wrong. Please respond to this same post when replying
Posted on Jul 17, 2008
Lefoo pressure valve leak
Where is it leaking from? If the unloader hisses for a few seconds when the compressor shuts off, it is working fine. If it hisses all the time when the compressor is stopped, it is still fine, but your in-tank check valve is toast. If it hisses when the compressor is running, you need a new switch.
Mar 03, 2013 | Emglo LEFOO Pressure Switch LF10
Red screen
Your red tube is going bad or the CRT board is cracked. Either way your TV is done. You cannot get replacement parts anymore.
Jun 06, 2012 | Philips 51PP9200D Television
Radio and CD player both emit a hissing or buzzing noise through the speakers like there is poor reception. However, all the local signals are found and play just fine, just the hiss!
The CD player cannot suffer from poor reception, so if you are having the same hissing / buzzing sound from the Bose system irrespective of the source you have selected , its is coming from the preamp / amplifier section.Also could be coming from the electronic source selector in the preamp section.You will need profession help
Mar 10, 2011 | Bose Audio Players & Recorders
I just installed a fluidmaster 400a. Works fine but every 5 minutes or so makes a "hiss" noise like it's filling for a fraction of a second.
to get exact cause of your problem personal examination is necessary. But still visit to the given link. It may help you..
http://www.toiletology.com/troubles.shtml
Thanks...
Jun 22, 2010 | Home
It probably is filling a little I suspect that you have a slow leak and replacing the flapper will solve that
Jun 21, 2010 | Home
Hissing sound coming from speakers
I found out that if I manually turn the speakers down on the tv and then turn it up with the remote control the hissing sound goes away
Mar 18, 2009 | Toshiba 65HDX82 65" Rear Projection...
Sony kp-41s3u 50" hissing sound
sounds like high voltage arcing,caution
Oct 28, 2007 | Sony KP-41T65 41" Rear Projection...
Hitachi 46ux11kf/ keeps shutting off
Convergence amp maybe out. These are the big STK's on the video board that stands by a heatsink. THis set is bad for going out. You also can tell by checking L.E.D lights in back of set do they all come on or do some come on and go off?
Jul 05, 2007 | Hitachi 46BX01B 46" Rear Projection...
Hissing Sound
A hissing sound that comes from the back of the set (not from the speaker) usually indicates a high voltage leak, most likely around the "suction cup" at the top of the picture tube or around the flyback transformer. Remove the back of the set and turn it on, and when you hear the hissing sound, shut off all the lights in the room and you should be able to see a purple-ish or white-ish glow from the spot that is hissing. Shut the set off, discharge the high voltage and clean and seal the problem area. Of course this should be done by someone experienced with stopping high voltage leaks.
Jun 22, 2007 | Durabrand DU1901 TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
