I have a acer travelmate 3000 laptop and cant get my wireless to work, if i plug in a new wirless usb stick it works fine but i wont the internal wireless to work, does this mean my internal wireless card is faulty.?
  • 3,940 Answers
Odds are pretty good the wireless is not enabled.
If you look at page three item three of the manual, it shows the button/indicator on the front of the system to enable wireless.
http://www.acerpanam.com/synapse/data/7117/documents/TM3000_UG_Eng.pdf
Posted on Jul 17, 2008
Ports on acer travelmate 4200 not working?
sounds like you may have driver for usb ports missing. check in device manager and see. if so simply reinstall drivers
Aug 12, 2012 | Acer TravelMate 4200 Series Laptop Charger...
I want to get a possibility to get a wireless driver for my acer computer
Does it have a working wirless card or adapter now?
If so just go to the acer website and download the driver for your model.
May 17, 2010 | Acer TravelMate 2303LCi Notebook
I reinstalled my OS win XP . now no usb
Open Run and launch regedit
Browse to the following location
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\USBSTOR
In the right pane, look for an entry named Start. If you find one delete it. Your USB devices should start working immediately.
If not please report back.
Nov 11, 2009 | Acer TravelMate 240 Notebook
Hi cant get my acer aspire 100 to connect wirless
Hi
Has it worked before, if not I suspect that model may not have any built wireless facility.If so you can always buy a wireless USB dongle for it.
Cheers cbacer
Aug 11, 2009 | Acer Aspire One A150-1006 Notebook
Can't make webcam work on Acer Travelmate 4500
This sounds like a USB issue. Not all USB ports on laptops are created equal (they should be but they are not) some usb ports supply enough voltage and current to run usb items properly and some dont. It is always better to run direct from the computer / laptops ports .
If you cant do this then use a HUB but make sure the HUB HAS IT"S OWN POWER SUPPLY !
Also make sure you always use the same port and swapping them around does not always work for all hardware.
Aug 09, 2009 | Microsoft LifeCam NX-3000 Personal Web...
Wireless never worked in Acer Aspire 3000 notebook ..help!
you have to install the wireless drivers, check it on cd
Oct 15, 2008 | Acer Aspire 3000 Notebook
Acer Travelmate 3200 usb dont work
this may help - or not..
http://support.microsoft.com/?kbid=310575
If you have damaged the USB chip on the motherboard, you may be able to disable it in the BIOS. Then when you install your PCMCIA card it may work...
USB is not as tolerant of short circuits as RS232. I know I managed to destroy one of the ports on my m/b.! Using a Hoover may not be a good idea.
Apr 10, 2008 | Acer TravelMate 2300 Notebook
Acer travelmate(belongs to my grandson), one rear usb three side mounted. Rear socket had been damaged, plastic contact support missing, pins touching case. Before I looked at it, notebook crashed if any...
motherboard dont have fuse has diodes which act similar to fuses but wont be blown.only things that will blow in that area are transistors or capacitors;but if these were blown usb's would not be detected.
in device manager were its says working correctly it relates to software istalled and working properly it cant tell u that the hub connection is damaged internally.
if your usb's are on card and connected to motherboard they can be replaced otherwise if built into motherboard youll have to take it to repair shop.
if the only problem is when u connect a usb device and not causing any other problems,u could use usb hubs that go into the pcmcia
Mar 30, 2008 | Acer TravelMate 2300 Notebook
Acer TravelMate 4020 Blutooth
does not have ! Look at the "communication" tab
Acer TravelMate 4020 Notebook Specification:
Operating System Linux BE (Basic Edition) Platform Intel® Pentium® M processor 725 (2MB L2 Cache, 1.6GHz, 400MHz FSB)
- Intel® 915GM Express Chipset
- Intel® PRO/Wireless 2200BG Network Connection 802.11b/g Memory 256MB DDR2 SDRAM, upgradeable to 2GB Display 15.4" WXGA TFT LCD, 1280 x 800 pixel resolution Graphics Intel® 915GM integrated 3D graphics, featuring Intel® Graphics Media Accelerator 900 and up to 128 MB of shared memory, supporting Microsoft® DirectX® 9.0 and dual independent display Audio Audio system with built-in speakers
MS Sound compatible
Built-in microphone Storage 60GB ATA/100 HDD Optical Media Drive DVD/CD-RW Combo Drive Communication Modem: 56K ITU V.92 modem
LAN: 10/100 Mbps Fast Ethernet
Wireless LAN: integrated Intel® PRO/Wireless 2200BG network connection Size & Weight 364 (W) x 279 (D) x 33.9/38.9 (H) mm (14.3 x 11 x 1.3/1.5 inches)
2.95 kg (6.48 lbs.) Power ACPI 1.0b power management standard
32.6W Li-ion battery pack (4-cell), battery life: 2.5 hours Special Keys & Controls 88-/89-key Acer FineTouch™ keyboard with 5-degree curve, inverted "T" cursor layout, international language support, 2.5 mm (minimum) key travel
Touchpad with 4-way scroll button
12 function keys, four cursor keys, two Windows® keys, hotkey controls, embedded numeric keypad
Four easy-launch buttons: Internet, email, Empowering Key, one user-programmable button
Two front-access LED-buttons: WLAN, Bluetooth® I/O Ports Three USB 2.0 ports
PC Card slot (one Type II)
External display (VGA) port
Headphones/speaker/line-out port
Microphone/line-in jack
Ethernet (RJ-45) port
Modem (RJ-11) port
DC-in jack for AC adapter Software Optional Items Li-ion battery pack
65 W AC adapter
256/512 MB or 1 GB DDR2 533 soDIMM memory modules
External USB floppy disk drive Warranty 1 (one) year International Traveller's warranty (ITW) Price
Jan 21, 2008 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
