Question about Microwave Ovens
Matsui MT180TC switches of before set time. If left (not cleared) will turn on and off randomly thereafter. Has to be turned off at mains.
  • William Miller
    William Miller May 11, 2010
    Does it ever start by itself when it is just setting and has not been programmed to cook?
    Or is it only when cooking that it shuts off and then starts back?
Problem "solved"...... Wife bought a new one!
Posted on Jul 21, 2008
It not cooling
If you're talking about a microwave oven:
[1] plug the mains cord in to the wall socket
[2] switch the socket on
[3] put food to cook on glass turntable, never use empty oven.
[4] close oven door fully until it clicks
[5] set the power
[6] press 'start' or turn the timer-dial,depending on your model.
It will start to cook immediately.
The humming sound is the energy heating the food in timed bursts of power.
If nothing happens or it won't cook, post clear description of fault with problem, make, model.
Hope this helps,
Clive.
Oct 19, 2017 | Microwave Ovens
I cannot set the time on a Panasonic NN-GD566M microwave oven
Sounds like the dial control on the timer board is bad, the only way to repair it is to replace the whole time board. Try a place called encompass parts. they are a distributor for Panasonic.
Oct 18, 2017 | Panasonic Microwave Ovens
The fan turned on randomly and will not shut off
A make & model number would help...There could be a number of possible causes. The overheat saftey, depending on the make & model this senses ambiant heat on the frame / chassis, the door sensing interlock switch. Depening on the make & model the control board fan relay. All these could be shorted closed. Depening on how the fan switch is wired the on / off switch or the routing through the control board might be at issue. If the unit has a schematic it may help troubleshoot the issues.
Mar 28, 2012 | Maytag Microwave Ovens
I have a cata ceramic hob. the child lock has been engaged & is restricting operation of any of the 4 hob's
When you turn on the hobs main power, press the the rear left hand element pad at the same time and the lock will come off.
press the centre minus button and the bottom right plus button at the same time it will work if not keep trying
You have to hold down the centre sensor button with the minus on and the sensor which turns on the bottom right ring immediatley after turning the hob on. It should unlock, then press the minus again
the hob switchs off
when you now switch on there will be no lock
Feb 04, 2011 | Microwave Ovens
Getting an error F-9
Reason for F-9 error code:
1. Door motor failure/jammed. Latch motor switch failure.
2. Control software failure.
3. Wiring problem
Solution:
1. Press CLEAR key
2. If CLEAR key does not eliminate the problem, turn power off for 30 seconds, then turn power on.
If this still does not correct the problem the wiring of the Lock Motor, Lock switches A, Door switch circuits and main control panel will need to be check and would require a professional service technician.
Hope this helps.
Shane
Feb 01, 2011 | Microwave Ovens
Clock setting
Mine is a Samsung, I don't know about your brand, but mine has a "CLOCK, AUTO/START"
button. Press & hold this & punch in the numbers until have the correct time
Aug 09, 2009 | Microwave Ovens
Kenmore Microwave Turns itself on randomly
22 years old and you are complaining that it starts andomly, you got way more than your moneys worth for heavens sake loosen up and buy a new one. Help the economy out.
Feb 24, 2009 | Frigidaire GLMB209D Microwave Oven
How to set up matsui microwave oven.
If for some reason you don't have your owner's manual, I would suggest calling the dealer you purchased it from.
They may have a contact phone number for Matsui.
Nov 26, 2008 | Microwave Ovens
I have a matsui 320 microwave oven, had it for some years now and can't find manual, we had power cut lately so microwave went off, i just cannot remember how to set it back up. any ideas now . if i press...
Otherwise, here are some sequences to try:
CLOCK SETTING
CLOCK > 1 > 2 > 3 > CLOCK
CLOCK > 1 > 2 > 3 > START
CLOCK > CLEAR > 1 > 2 > 3 > CLOCK
CLOCK > CLEAR > 1 > 2 > 3 > START
Microwave Ovens Logo
29 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
