Question about Pioneer Audio Players & Recorders
How do i connect everything. i have a pioneer m90 power amp and a pioneer c90 control amp and have no instructions to connect them
    Brigadier General:
  • 6,966 Answers
Basically, the Pioneer C-90 would serve as the INPUT and Control Center. All your Video and Audio sources would have to be connected at the rear.
The M-90 on the other hand is the amplifier side. Other than a pair of RCA cables and your speakers, nothing is to be connected. You need to select a particular source on the front selector switch and connect the RCA pair to the corresponding rear RCA females. The other end of the RCA cables goes to the Line Out/ Pre-Amp Out of the C-90.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 17, 2008
  • 813 Answers
Resitor & login & download the manual of connaction
http://www.hifiengine.com/manuals/pioneer/m-90.shtml
  • 151 Answers
Look at the back of your control amp for sockets marked pre out,connect these to sockets marked power in on the power amp with good phono cables,now put your cd player etc into the control amp and connect speakers to the power amp.
hope this helps.
CABLE GUY.
  • Pioneer Master
  • 19,396 Answers
What other device are you connecting?
  • Ginko
    Ginko Jul 17, 2008
    Generally you use a pair of RCA cables to connect your control amplifier to your power amplifier.
2 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: i cannot work out how
the audio output of C90 control amp.is in the>INPUT of your pioneer M90 power amp.
message me if ever not ok..
Posted on Jul 18, 2008
Have a m90 boulevard 2008-2009 bike has had service done ,replaced with brand new battery turn key on everything works well except the bike wont crank over what to look for
Hi, Thomas and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Suzuki VZ1500 Owner Manual
OEM parts for Suzuki
Suzuki VL1500 Service Manual
06 Suzuki Boulevard C90 won turn over
http://meiguohosting.com/How-to-fix-start-problem-for-your-2013-Suzuki-Boulevard-M90
Jan 16, 2017 | Motorcycles
I have ancient but good condition Pioneer M90 and C90 amplifiers and Bose 901 speakers, but have never been able to get decent bass reponse. Is this a hookup problem or a compatibility problem?
If it's connected properly AND directly between the preamp and the amp it WILL sound very good across the band. The Active EQ also has sliders for tweaking the tone. If you vary them and hear no change it is NOT connected correctly.
Get the manual at Bose.com. It lists several connection scenarios.
Jan 07, 2011 | Bose 901 VI Main / Stereo Speaker
I have a deh-2200ub model... everything is hooked up properly, but no audio. any ideas?
What kind of vehicle? If it's on a Ford, make sure you connect the blue/white power amp wire (Ford installs factory amps in their vehicles)
Aug 13, 2010 | Pioneer DEH2200UB with iPod Direct Control...
SUBS WONT TRUN ON
Hello fresttadefjm,
There are no subwoofer settings on the Pioneer DEH-2800MP.
You need to check the external power amplifier and the connections from the Pioneer and from the sub(s). If everything is plugged in and wired correctly, check the amp fuses, both on-board and the main power fuse (located in the amp positive lead usually near the vehicle battery).
Hope this helps.
Jul 21, 2009 | Pioneer DEH-2800MP CD Player
Suzuki C90 Won't Start
Check your battery cables, especially the ground cable. Check your ignition switch for loose wires/connections. Check your fuse box. Check your wiring harness for shorts and broken wires. When you say "battery seems to have plenty of power" what does that mean? What test(s) did you perform on it?
Jun 04, 2009 | 2005 Suzuki Boulevard C90
Nothing working! please help!
no it doesnt HAVE to be wired in it just lets you control the amount of output from the sub. however the spark could have blown out the internal workings of the amp. there are genereally multiple fuses on car amps. have you checked these? if they are blown replace and reinstall if not then it very would could be that the spark caused the amp to fry.
Feb 18, 2009 | Kenwood KAC-5203 Car Audio Amplifier
Power light kicks on then off when I turn on the stereo
The amplifier likely has shorted output transistors. To confirm that it's not some other fault, go to the following page. It will guide you through the troubleshooting.
Troubleshooting - Amp Going into Protect
Let me know if you have any other questions.
Jul 20, 2008 | Pioneer GM-5300T Car Audio Amplifier
I cannot work out how to connect my pioneer C90 control amp to my pioneer M90 power amp
Jul 17, 2008 | Pioneer Audio Players & Recorders
180 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
