Question about Fisher and Paykel Dishwashers
Washig Machine AWO85U
Fischer and Paykel AW085U, Digital controls with yelllow board.
Machine won't go past turning and selecting wash, does not fill with water to start cycle. Water solenoids have14 ohms resistance and are 12v.
5 Suggested Answers
Rotu
  • 175 Answers
SOURCE: washer
If I'm not mistaken, these dishwashers are built by Asko for Viking. If thats the case then you probably have a bad circulation pump. Under Asko's warranty (not sure if Viking is the same) these pumps are covered parts and labor for 3 years from installation date, and 5 years for the part only. The pump is accesed from the back of the machine,so you have to pull out the dishwasher. Then you remove the lower plate in the rear and the motor at the very back center is the pump. You remove it by turning it about a 1/4 turn either clockwise or counter clockwise, depending on the style, then place the new one in and turn it to lock it in place, being careful that the sealing oring stays in place or youll get a leak. The part will probably cost you around $150 unless viking marks theirs up more than Asko. Good Luck!
Posted on Nov 23, 2006
RescueTech
  • 145 Answers
SOURCE: problems with fischer paykel self cleaning oven
Hi and welcome to FixYA.com!
Here are links to the two most popular Fisher Paykel Wall Ovens:
OD/OS301:
http://www.fisherpaykelparts.net/partmanuals/545619C_Aerotech_UGM_USw1.pdf
OD/OS302:
http://fisherpaykelparts.net/partmanuals/599194C_Aerotech_ugm_USw.pdf
If neither od these is your model, let me know which one you have and I will locate a use and care guide for you.
Hope this helps and Happy Holidays from the FixYa crew!
Posted on Dec 15, 2008
SOURCE: won't fill with water
Went through the diagnostic sequence on control board as per maintenance papers in machine, the problem corrected itself.
Posted on Mar 07, 2009
  • 901 Answers
SOURCE: Water fill problem on Hotpoint Dish Washer Deluxe Model DF 31
Pl check the small filter fitted near the water inlet hose. Probably you may have to pull this filter as this is housed in the threaded pipe attached to the body.
Remove the hose from the machine and try flushing. see whether you get sufficinet pressure from over-head tank!
Clean the filter with tooth brush or reverse clean. Do no for get to fit rubber washer.
Posted on Mar 30, 2010
I only have a hose attached to the cold water tap and inlet valve of my Fischer & Paykel top loader washing machine as I only do cold washes, this hadn't been a problem until recently, when th
it could be that the water level got to high and came out of the valve you could try putting a cap on the valve and see if that works and if it does not then it might be a bigger issue.
Dec 23, 2012 | Fisher and Paykel GWL11 Top Load Washer
I have a Fischer Paykel Smart Drive 5.5 which is leaking water into the machine when it is switched off. Obviously when I turn off the feeding taps the water stops dripping but how can I stop the leaking...
(pre-typed to cover hot and/or cold!)
This is symptomatic of a malfunctioning (not closing completely) water control valve
With power off, if it is hot AND cold fill, turn one or the other off and see which one is causing the problem. Sorry but it needs replacing and a service call ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 17, 2011 | Fisher and Paykel Fisher & Paykel Washer
We have a fisher and paykel AW085U. The cold inlet valve has been replaced and the machine worked well for a coulpe of weeks. Now its pulsating while filling with water and then alarms with every second...
Those lights are adding up to a fault code.Add them together across the top from right to left,Only the ones that are on!..Il tell you how..They are binary numbers..eg: 128 64 32 16 8 4 2 1..here are the numbers for each light.Add only the ones that are lit together & you will have your fault code.It will be one of 2 problems.(Out of balance micro switch) in the top right hand side under computer board..OR (Rotor Position Sensor)down on the motor underneath machine,try balance switch first.much cheaper,$15-$20 . Rotor positon sensor about $60-$100.Goodluck!
May 24, 2010 | Fisher and Paykel Washing Machines
F&P washing machine:GW709 doesn't cut out when filling
could b pressure switch tube is blocked or your control board with the pressure switch attached is faulty. empty water from machine, remove pressure switch hose from control board, blow thru tube to remove any blockages, refit tube. turn on cycle, select low water level, push start, after about 30sec"s push start again, that should stop it filling straight away. if the water stops push start again to continue filling. if it doesnt stop filling after restarting the cycle then it is your control module.if the water doesnt stop filling after the 30 sec stop it is the water valves. by the way what country do u live in because $120 seems to b alittle too expensive. please reply 4 more help.
Apr 29, 2010 | Fisher and Paykel Fisher & Paykel Washer
Trouble code of #104
From past experience it is a motor controller fault(Main PCB)
If pump running all the time PCB is sending power to pump continously
Part 426204p About $200.00 AU $216NZ
Please rate our help to keep the FREE saervice online++++Thanks for using FIXYA
Sep 17, 2009 | Fisher and Paykel (IWL12)
Fisher and Paykel washing machine fills and won't stop filling...
If the water stops when you shut if off at the wall you have a bad cold inlet valve, or the valve is getting a constant "open" command from the controller and thus the controller is faulty.
Jun 18, 2009 | Fisher and Paykel (IWL12)
Problems with fischer paykel self cleaning oven
Sounds like Clothes Washing Machine To Me!!--Methinks You have "Posted Incorrectly"--Stay Upright --Des.
Dec 15, 2008 | 2006 Fischer MRX 650
Fischer Paykell 7.5kg Smart Drive top load washer
Have you checked the lid micro switch under the motor controller which activates when you close the lid to start the machine?
Jul 24, 2008 | Fisher Paykel EcoSmart GWL15
Dishwashers Logo
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
