Question about Pioneer Audio Players & Recorders
I cannot work out how to connect my pioneer C90 control amp to my pioneer M90 power amp
  • 2,071 Answers
The audio output of C90 control amp.is in the>INPUT of your pioneer M90 power amp.
message me if ever not ok..
Posted on Jul 18, 2008
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: how do i connect everything.
What other device are you connecting?
Posted on Jul 17, 2008
What to look for my m90 boulevard wont crank over - had service done 6mths - just replaced with brand new battery - but bike wont crank over
Hi, Anonymous and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
http://meiguohosting.com/How-to-fix-start-problem-for-your-2013-Suzuki-Boulevard-M90
06 Suzuki Boulevard C90 won turn over
Suzuki VL1500 Service Manual
OEM parts for Suzuki
Suzuki VZ1500 Owner Manual
Jan 16, 2017 | Motorcycles
Have a m90 boulevard 2008-2009 bike has had service done ,replaced with brand new battery turn key on everything works well except the bike wont crank over what to look for
Hi, Thomas and the usual suspects are:
Pioneer PD M502 won't recognise Remote controller
this Pioneer PD-M502 have no remote sensor.mean this model was not designed to work by remote control.
Jul 01, 2012 | Audio Players & Recorders
I have ancient but good condition Pioneer M90 and C90 amplifiers and Bose 901 speakers, but have never been able to get decent bass reponse. Is this a hookup problem or a compatibility problem?
If it's connected properly AND directly between the preamp and the amp it WILL sound very good across the band. The Active EQ also has sliders for tweaking the tone. If you vary them and hear no change it is NOT connected correctly.
Get the manual at Bose.com. It lists several connection scenarios.
Jan 07, 2011 | Bose 901 VI Main / Stereo Speaker
My Dell precision M90 will not turn on all the way it acts like its going to boot up and then comes to a screen that either says the battery can not support the system press F1 to shutdown (when it is not...
Seems that either the battery or the power adapter is defective. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Oct 27, 2009 | Dell Precision M90 Notebook
Suzuki C90 Won't Start
Check your battery cables, especially the ground cable. Check your ignition switch for loose wires/connections. Check your fuse box. Check your wiring harness for shorts and broken wires. When you say "battery seems to have plenty of power" what does that mean? What test(s) did you perform on it?
Jun 04, 2009 | 2005 Suzuki Boulevard C90
No power to my pioneer gm5300t
arcanum,
good day bro, from your Pioneer amp supply line do you also see a terminal marked as " System controller" ? did you also supply 12V DC to this terminal?
the standard power configuration for Pioneer Car amps would be:
12V Dc (+) supply / ( - ) supply ground / System Controller ( supplied by +12V DC)
12V ( + ) supply and The ( - ) supply ground is for stand by power, once you connect the supply through this terminal you will now have the stand by power but will not power on the unit even the LED power indicator.
System controller terminal, this should be supplied by ( + ) 12V line to power up the amp. this serves as the ON/OFF switch for the amp.
cheers,
mark
Jan 25, 2009 | Pioneer GM-5300T Car Audio Amplifier
236 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
