Question about Hotpoint Washing Machines
Not empty the woter - Hotpoint Washing Machines
  • 1,462 Answers
Filter probably blocked.
remove rear bottom panel. you will see a large diameter hose going from bottom of tub to pump. undo this hose at the tub end - lots of water will come out. filter is inside this hose. pull out and clean.
while you are about it, check for foreign objects in the pump impellor
Posted on Jul 17, 2008
Beko wm 612 w not stoping only spining
Does it ever drain and then refill or just stay full and not stop?
Oct 07, 2014 | Washing Machines
How to solder copper woter pipe
Heat joint with torch, appy solder. Be careful not to set surrounding materials on fire!
Jun 01, 2012 | Plumbing
My nokia c3 is woter demej touch ped not working
You need to Send it for repair The touch pad might be needs to be changed
Feb 27, 2012 | Nokia C3 Cell Phone
Can't find leak in my inflateable ring have tried the srsy bottle with soapy woter anl other suggestions
Wow what a tough question! This is a real head scratcher.
Using a dye test solution or some of your pH indicator test reagent, drop near it with pump shut off and water still. See if the dye is sucked into the crack, gap or tear.
Jun 25, 2010 | Intex Easy Set Pool 15x36
Run ok out of water, in water wont rev up or plane out . Cleaned fuel tank,rebuilt carbs.
I think maby that you have a small woter or air leak somewhere, find that and you should be good
Aug 01, 2009 | Sport & Outdoor - Others
F 18
Remove lower rear panel of washer. Lay the drain hose down into a bucket or bowl, and drain all the water out, so you do not have a flood when you remove the hose.
Locate, and remove large black hose on bottom of tub. Remove plastic filter inside, and clean. Check pump also. Refit filter and hose.
Plz rate if helped.
Mar 25, 2009 | Hotpoint Aquarius WD640 Front Load...
No woter but comes on
no water drains out or no water enters machine?check mushroom shapedfloat swithcon inside of d/w pull up and down a few times if stuck in up position it wont let water in, itll think tos already full of water
Feb 22, 2008 | GE 24 in. GSD2000Z Built-in Dishwasher
Washing Machines Logo
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
