Question about Alcatel Speed Touch Home Modem
CHANGE PASSWORD/ETHERNET ROUTER/WINDOWS VISTA
HOW TO CHANGE PASSWORD ON ETHERNET ROUTER?
  • mb1919 May 11, 2010
    I called manufacturer, they said it will cost at least $70 to provide any help, even help means resetting the password, they wanted my credit card info right away before even invetigate the problem, resetting the password should be automatic interface, a customer should eb allowed to do that on their own.
    Problem Solver:
  • 14 Answers
To make it clear..
change password meaning you need to update your router's password?
SOLUTION: access router's interface and enter correct password information
OR
change password meaning reset your password for your router?
SOLUTION: call router provider/manufacturer ISP to have router's password reset..
Posted on Jul 17, 2008
Driver windows 7
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Feb 04, 2011 | Lexmark Z600 InkJet Printer
Installer for windows vista
Plug into router with an Ethernet cable, logon with the word admin, & use admin as password, Then in the left hand side you will see a Setup Wizard, run this wizard, fill in the SSID (The NAME YOU Give it) & Your ISP's Details, & DNS. also Your logon & password for your internet account. When finished make sure you "Save" your configuration.
Feb 10, 2010 | Linksys Wireless-G WRT54G Router
If I reset my router, do I need the CD to reconfigure or change the password
You don't actually need the CD to reconfigure your router or change the password or anything related to your router. So long as the router is connected to your computer via ethernet cable you can access the browser configuration page of your router.
1. connect your router to your computer via ethernet cable
2. If you are using Windows XP
- click start
- click run
- type cmd
- in the black screen type ipconfig and press enter
- look for the default gateway (example 192.168.1.1)
- Open Internet explorer
- type in the address bar: http://the default gateway (example http://192.168.1.1) then press enter and it'll ask you for the password
- usually the username is blank and the password is admin or the username is admin and the password is pass or password
If you are using Windows Vista / Windows 7
- Click the pearl button
- Click on start search at the bottom of the pop-up window
- type cmd (don't press enter yet)
- right click the black icon on the top of the window after typing cmd
- click on the run as administrator
- click on continue if there's a prompt
After successful accessing the configuration page you can now configure your router freely.
Jan 11, 2010 | Gateway Wireless-B Router (wbr-100)
I want to secure my Belkin 'n' wireless router . I am running Windos XP, Windows Vista, Windows 7 and Mac OS Snow Leopard. How can I do this?
connect any one of the computers to the router with a ethernet cable. open internet explorer, clear out the address bar on the top, and type 192.168.2.1. when u hit enter, u'll get a router set up utility. in this page u'll have an option -security- below "wireless". when u click security, it'll ask for a password, leave it blank and hit submit. on the next window, choose the option WPA/WP2, then u'll have some more options, look for PASSWORD(PSK).. put in a password which should be 8 to 63 characters long, its case sensitive. click on apply changes.
Jan 10, 2010 | Belkin (F5D8231-4) Wireless Router...
How do I set up my router with out the disc? It won't run because it is Windows 95 not vista
if you connect the computer to the modem, does it work ?
If that works then the modem is working working properly.
now connect the modem and the computer to the router. open the set up page of the router.
here you can change the settings of the router.
You don't need CD to set up router
Click here to know more about how to set up router.
Jan 09, 2010 | Linksys Wireless-G Broadband Router
How do i set it up manually?
Connect an Ethernet cable to one of the Lan ports,
and to the network-card in a computer (running Windows XP or Vista or 7).
Via Internet Explorer, access the web-interface "inside" the router,
and run the "Network Setup Wizard", and run the "Wireless Setup Wizard".
That's all -- there is nothing dependent on "Windows 7".
Nov 23, 2009 | NetGear WGR614 Wireless Router
Dlink wireless windows vista
Connect an Ethernet cable to one of the 'LAN' ports on the router and to the network-port on your computer.
Click Start
Click Run
Type CMD and press ENTER
Type IPCONFIG and press ENTER.
You should get output like:
Ethernet adapter Local Area Connection:
IP Address. . . . . . . . . . . . : 124.268.336.448
Default Gateway . . . . . . . . . : 123.456.789.0
Start Internet Explorer.
Type: http://123.456.789.0
to connect to the web-server "inside" the router.
Run the "wireless network setup wizard" to configure the router
with an SSID and a password.
Save and reboot the router.
Disconnect the Ethernet cable.
Your computer should report "Wireless Networks are available".
Choose your network, and enter the password for the network.
Nov 18, 2009 | D-Link DIR-615 Wireless Router
Unable to connect to Linksys BEFW11S4 router from new Toshiba lap
this sounds like security problems , other people have experienced problems with vista but most have been able to resolve them.
whilst connected to your router using an ethernet cable open a browser windows and type in the rounter address these
are usually one of 2 most likely yours is
192.168.1.1
and typing password as "admin" and no user name. Use your password if you have changed it earlier 2
Go to wireless tab. 3. Go to wireless security sub-tab 4. If security mode is wpa or wpa2 note down passphrase/shared key, if security mode is WEP note down wep key number 1. This will be your network key
also check other.
On the Vista laptop with the connection
Start --> Network
Click on Network and Sharing Center
if It shows a red X between my network and the Internet.
click on the Customize link (below and right of the red X)
Under location type if it was set to Public. change it
to Private. Hit Next
At that point my whole network might go down,  and
reset the router. (turned off and turned on)
After that my red X under network and sharing center
was gone. And my internet connection problem was gone.
I forgot to mention that before you shoul have turned
off all software firewalls and virus scanners. prior.
if that does not work when you are logged into the router page 192.168.1.1 check to see if their is an option to update the router software/firmware ,if their is no option then you  may have to manually downlaod the firmware from linksys and update that way .
Hope this helps if not ask for clarification on anything your unsure of.
May 14, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Need to change netgear router rp614 from dsl to cable
Hello
First connect one of the ethernet ports (LAN) to your computer.
In windows to this:
XP: Start -> Run -> write CMD and press ok-> Black window pops up-> write IPCONFIG and press Enter. -> Look for Local ethernet connection and write down the ip adress outside default gateway (f.ex 192.168.0.10 or 10.0.0.1).
Vista: click windowsmenu icon-> write CMD in search field and press enter -> Black window pops up-> write IPCONFIG and press Enter. -> Look for Local ethernet connection and write down the ip adress outside default gateway (f.ex 192.168.0.10 or 10.0.0.1).
Open a webbrowser and clear det adress field, enter the adress (with the dots and no www.) you wrote down from default gateway and press enter.
If you get promted for a username and password the default is: username: admin password: password (you can find it on the side of the netgaer box under deafult accsess.
If you cant get in try to do a "hard reset" (push the reset button for 30 sec with a pen).
You are now in the web user interface for you netgear.
On your lefthand side, you should have a blue menu, click on the first option on the top and run the setup wizard, dont change anything (dont choose that your connection needs a password to connect) just use the default settings. Remember to press save on the botom.
You should now be ready to use your netgear router.
If this guide didnt fix your problem, i need more details to help you.
Check with your new service provider if they require a username and password to connect (PPPoE).
Feb 07, 2009 | NetGear WGR614 Wireless Router
Secutiry for BelkinF5D7230-4 router using Vista
Hi, here's a quick guide for you:
1. Connect to the router via Ethernet cable
2. Login to the router via a web browser, by typing 192.168.2.1 in the address bar
3. Click to login, leaving password blank (unless you have set a password)
4. Go to Wireless > Security. Select Security Mode WPA-PSK.
Enter your network key (password) under ‘Pre-shared key’ – make a note of it – click ‘Apply Changes’. That’s it, your wireless is encrypted.
For better security/more details:
1. Pick up a manual from Belkin UK
2. When you’re in your user interface, change the SSID and router password for a better level of security (see this tip for more details).
Hope this helps, but please come back to Fixya if anything doesn't work, or if you need more info. Good luck
Jan 20, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Alcatel Speed Touch Home Modem Logo
1,913 people viewed this question
Top Alcatel Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you an Alcatel Computer and Internet Expert? Answer questions, earn points and help others
