Question about Lowrance GPS
I have a Lowrance LMS 320 GPS/Sonar and the screen does not light up. Power to the unit is there. Have tried soft and hard reset. Unit is 4-5 yrs old.
  • Anonymous Mar 18, 2014
  • Anonymous Mar 21, 2014
    Unit sat for 4 yrs previous owner had 2 neither screens show anything.
  • 113 Answers
Are saying you can't read the screen at night, or is it hard to read the screen anytime?
If you tap the power key, you should here a beep and the screen should get brighter. If you hear the beep and there is no light, then the internal light has failed.
If you can't read the screen in normal light conditions try viewing it under a bright light at various angles. You may notice that the screen is just barely visible. If this is the case you may be able to fix the problem by adjusting the contrast. Try tapping bthe power key and then tap the right or left side of the track pad. It may take several taps to see the results. If left or right doesn't work, try up or down.
Posted on Jul 21, 2008
LMS 520c back light not working
the light switch is in the power up button...turn the unit on let it boot up then push power button to set light as you want it do not hold down power button that will just turn unit off.. push the power button just one time if you want light brighter push till you get the back light you want
Jan 21, 2014 | Lowrance Lms 520c 5" Screen Color External...
My lms 332c wont stay on tried soft reset turn it on goes off what to do?
what do you have your unit hooked to too power up straight off the battery or thru a power switch if thru a switch hook it straight to bettery
Nov 15, 2012 | Lowrance Lms 522c 5" Screen Color Internal...
Lms-332c lowrance fishfinder unit turns on as soon as the power wire is plugged in and goes to blinking pinging beeping between hi and low light settings constantly. All other features seem to work fine. A...
I don't know whether you have made a factory reset to this device or not. If not, set it first and see whether it helps you. To make it factory settings:
[1] Press 'MENU""MENU" (down arrow to system setup) "ENT" (down arrow to RESET options/ ENT
[2] The unit asks if you want to reset all the options. Press [<---] to YES and then ENT. All options are reset, and the unit reverts back to map page at 4000 miles zoom range. Any recorded sonar logs of GPS data will be unchanged. OK.
Sep 23, 2011 | Lowrance LMS-332C GPS Receiver
Lowrance 330c gps not responding
do you have both power and ground wires hooked up?
Jul 27, 2010 | Lowrance LMS-330C GPS Receiver
Lms 520c 5" Screen Color External Gps And 200 Khz Sonar System: I have a Lowrance LMS 520C on my boat. The GPS wi...
I have the same problem on my 520C.
I have no solution but I hope you have find some?
Best regards
May 07, 2010 | Lowrance Lms 520c 5" Screen Color External...
Hi,when i switch on my lms-332c the map does not come up on the screen.If I remove and replace the map card it works perfectly. Can I fix this? regards nigel
I am guessing that the card you are using is a NAVIONICS chart? There have been some Lowrance units that were made around the same time that have had problems recognizing a Navionics chart right from power up.
Make sure the LMS-332 has the latest firmware version which can be downloaded from
If the update doesn't help, this is going to be a compatibility problem with the LMS-332 and that particular card. You will need to replace the card or upgrade to a newer unit...but probably can just get used to removing and replacing the card when you turn the unit on.
Jul 08, 2009 | Lowrance LMS 332c Mapping Sonar/GPS...
I have a lowrance LMS 332C GPS. After 5 years I
The LGC-2000 is bad would be the most likely cause, but if this started right after you changed the cables, Try connecting the NMEA 2000 network to a different power source than the main power. If you still have the original cables, and you didn't have the problem before, try using those again to make sure there isn't anything wrong with any of the new cables.
But most likely, the LGC-2000 is toast and you will want to contact Lowrance support to see about getting it repaired/replaced.
Jul 04, 2009 | Lowrance LMS-332C GPS Receiver
Cannot access main menu or pages screen
I think I can help with your issue. I have an LMS 334c and have had a few issues in the past. Called the factory (this answer is not listed any where in your manual) and they instructed me to "Soft Re Boot" my unit and it would put everything back to factory settings. Try this anytime it does not respond for whatever reason.
Turn the unit off.
At the same time press the Pages and Power button. Hold both down until you see the square box come up in the screen. You should have your factory settings again. May need to try a few times.
Lowrance said it works just like a computer, ever now and then it just tries to disect to much information at one time and hangs up.
Good luck. James Cantwell
Nov 03, 2008 | Lowrance LMS-330C GPS Receiver
Lowrance 330c gps unit
A "soft reset" can be accomplished by pressing and hold "Pages" key and press and hold "PWR" key till USA map comes on , then release both. A "hard reset" requires press and hold both "Z in" and "Z out" buttons and press and hold "PWR" button releasing all three when USA map appears.
Oct 18, 2008 | Lowrance LMS-330C GPS Receiver
GPS Logo
283 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
