Question about Ruud UBHC Air Conditioner
EVAPORATOR MOTOR WILL NOT STAY ON
HAVE REPLACED CONTROL BOARD BECAUSE OK LIGHT  KEPT FLASHING ON\OFF,BLOWER BLOWER CYCLES INTERMITTENLY 'PROBLEM PERSISTS
  • DNBT332 Jul 23, 2008
    found prolem, i think, dust on blower motor housing would trip over-
    heat sensor  but still my wholesaler tested original control
    board sho-nuf it was bad. COULD THE OVERHEATING MOTOR
    DAMAGE CONTROL BOARD? yes installed new control board
    appreciate your nput THANK YOU,ELECTRIC 201
  • 20 Answers
M
ake sure yo have a good ground to the unit
allso take note of blinkingg ligths these are codes to let you know what the problem is
Posted on Jul 23, 2008
  • daniel stein Jul 24, 2008
    nope overheating of the motor would not have caused the board to go power surge bad grounding ligthning and directly shorting it would cause that the board should be protected by 3 amp fuse
ASTA12JCC Inverter system coming up flashing LED error
could be the evaporator capacitor in the evaporator that has gone bad.As long as the motor in the evaporator is free to spin ,more likely the capacitor is defective . Its normally on the logic board soldered in place ,between 1-2.5 uf 450volts (rectangular black looking thing with 2 leads)
Apr 27, 2014 | Fujitsu Heating & Cooling
I have a Amana unit Model# PGA60C1152F that has a blinking light on the control board it blinks 4 times. That heat will come on then go off but the blower nevers comes on.
look on the inside of the door that you took off and there should be a diagram and on that there will flash code that will tell you what 4 flashes means.i think it is a flame rollout or high limit.
Nov 16, 2012 | Amana Heating & Cooling
Freezer flashing E Refrigerator flashing F what does this mean????
The code "E - F" is related to evaporator fan motor. You have a bad evap fan. This is the fan that is behind the back panel INSIDE the freezer.
This code is for the evaporator fan motor but it could also be due to a defective main board. If the fan motor in the freezer is still running, disconnect power to the refrigerator for 30 seconds and then reconnect it. This resets the board. If the code disappears and the motor is still running, it may be ok now but if the code reappears, the board will need to be replaced.If the motor is not running, some voltage checks will need to be made at the motor and at the board.------------The EF error code indicates a problem has been detected with the freezer fan motor (evaporator fan). This type of symptom could be caused by the fan motor stalled out on some type of obstruction, defective fan motor, faulty wiring or the main control board.
you can get required parts from sears part direct online site or from repairclinic.com site.---------
This should help.Thanks,.Helpmech.
Apr 04, 2011 | Kenmore Refrigerators
I have a Rheems Criterion Furnace and the main blower does not kick on any more. The ignitor coil glows, the burners kick on along with the venting fan and stays on for roughly 1 minute. The main blower...
Yeah i would change out that board .Should be a 3 amp fuse so maybe as simple as that but if not a cycling blower motor is a tell tale sign of curcuit board
Nov 21, 2010 | Water Heaters
99 Buick LeSabre, Heater/AC blower kicks in and out. Works intermittenly. Is it the blower motor, relay, of resistor?
most likely it's the switch.
Please see my tip at http://www.fixya.com/cars/r6234839-doesn_t_heater_or_air_conditioner_blow . These are generic instructions. If you get stuck or need specific instructions for your car, please get back to me with model, year and engine info.
Oct 27, 2010 | 1999 Buick LeSabre
Furnace lights fan comes on then fan goes off furnace stays light until overtemp takes it out code flashes 4
Have some one hold the bottom door safety switch, turn furnace on wait until heating fan relay clicks, and check at terminal (Heat) & terminal (neutral or where all the white wires are located on the control board) for 115 volts to 120 volts. If voltage is present replace blower motor, if voltage drops out while running then replace control board.Turn power off to furnace, open bottom door and feel blower motor with hand, if motor is real hot replace motor. you can not oil this type of motor, it has to be replaced along with the compacitor. Good luck.
Jan 22, 2010 | Goodman Furnace Draft Inducer Blower ...
Blower motor stays running ,can't shut it off ,on my 2003 envoy 4,2,it's has dual climate controls , with blower controls on the steering wheel as well as on the dash.please help with the location of the...
you need to check / replace the blower speed resistor module that should take care of the problem it is located lower evaporator case right hand side very bottom by the blower motor.
Nov 04, 2009 | 2002 GMC Envoy
Replacing Blower Motor Resistor
  1. Disconnect and isolate the battery negative cable.
  2. Open the glove box.
  3. Flex both sides of the glove box bin inward near the top far enough for the rubber glove box stop bumpers to clear the sides of the glove box opening, then roll the glove box downward.
  4. Reach through the glove box opening to access and disconnect the instrument panel wire harness connector for the blower motor resistor from the resistor connector receptacle (Blower Motor Resistor).
  5. Reach through the glove box opening to access and disconnect the blower motor pigtail wire connector from the resistor connector receptacle.
  6. Remove the two screws that secure the blower motor resistor to the evaporator housing.
  7. Remove the blower motor resistor from the evaporator housing.80ac4e54.gif
Feb 04, 2009 | 2003 Chrysler Town & Country
Ruud UBHC Air Conditioner Logo
51 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
