Question about Kirby Heritage II Vacuum
PROBLEM I HAVE CLEANED PART OF MY CARPET, BUT WHAT SUCKS UP THE DIRT OR WATER AS CARPET WAS WET, I HAVE WATCHED A VIDEO, BUT DIDN'T GO FAR ENOUGH TO EXPLAIN THIS, AND WHAT DOES THE BELT DO THAT IS LOOSE FITTING IN BETWEEN EACH SIDE OF BRUSH. KINDEST REGARDS
    Problem Solver:
  • 5 Answers
A Shop vac is my usual solution to my crappy Kirby shampooer..
Posted on Jan 26, 2013
  • 4 Answers
Well with a Kirby shampoo system there is no actual suction to clean up the water, they use a foam to clean if you are using the genuine Kirby shampoo, what the brush does is scrub and collect excess foam, I've used them before and really I'm quite pleased with the Kirby shampoo set it doesn't take as long as my parents Bissell did to dry
Posted on Dec 14, 2008
I have a Delonghi Multi Vac M31 and have never used the wet part...I would like to clean my carpet using the wet vacuum...can you please tell me how I can do this? Many thanks
A good place to start is the owner's manual. If you don't have one, you can google the make and model of your multi-vac to get another copy.
Most wet-vacs work off the same principle. Pre-vacuum the carpet to make sure there is not normal surface dirt and dust. Next Squirt on hot soapy water, scrub it in - then suck up the dirt and collect the dirty water.
So after vacuuming the area to be wet-vacuumed and you are lucky enough to have a separate reservoir on the wet-vac unit - add pre-mixed carpet cleaner into hot tap water (with carpet cleaner mixed into it by the ratios described on the carpet cleaner soap bottle) to the multi-vac water reservoir (from a quick look, the Delonghi doesn't have one) . With the settings for wet vac (per the owners manual), squeeze the trigger for applying the carpet cleaner. Typically, you will go slower than normal vacuuming. Give it a chance to soak in and dissolve/lift the grim and dirt. Come back slowly to pull the dirty water out of the carpet.
There are multi-wet vacs (like the M31) that don't have a reservoir for the carpet cleaner. In that case, you need to pre-mix a couple of gallons of carpet clean in a separate container or bucket. Next spray or sprinkle carpet cleaner onto/into the carpet. Try to scrub the cleaner into the carpet to really get at the dirt and lift it. Next is to vacuum up the wet stuff.
Some carpet cleaners do not contain an anti-foaming agent. I recommend you either add an anti-foaming agent or buy a carpet clean product that already contains it - otherwise, it tends to be a big mess that takes a lot more time.
I hope these tips help.
Nov 07, 2014 | Vacuums
Model #169171 not sucking up dirt
I have the same problem. When I pull the hose out it seems to have plenty of sucking power though. I dont know what the problem is and why it wont pick up much from the carpet. The stuff it does pick up never seems to make it into the canister either.
Jan 23, 2010 | Kenmore 85930 PowerSpin Deluxe Upright...
Eureka 2812 shop boss wet/dry..water is being sprayed out of the
je ne trouve pas un magasin ou je puisse acheter des filtre a poussiere
Jun 20, 2009 | Eureka 2812 Wet/Dry Vacuum
Water lesking from vax rapide carpet washer
i have been using a vax v26 carpet cleaner and the washing water is leaking from the bottom then the solution will not come out has the pump given up?
Jun 07, 2009 | Dirt Devil CE5500 Floor Keeper Upright...
Carpet stained
Ok in the future try to have carpet cleaned only by a pro. For spot cleaning use white paper towels or dish towels and warm water. (ONLY WHITE) 99% of fabric is white and then dyed to color and if you use a color cloth you might pull the dye from the cloth into the carpet. Now what you can try is your basic dishwashing detergent like electrosal with warm water and a dishtowel. little at a time try to blot not rub. try AFTA if that doesnt work. wet the rag first with warm water. pour the afta on the wet rag not on the carpet.
Jun 10, 2008 | Bissell OxyKIC - Oxygen Activated Carpet...
Can't get it to **** up water from the carpet
Check the filter on the bottom side of the lid, make sure it has at least 1/4 inch gap from the top of the filter to the to of the lid. Is the lid secured all of the way around and not loose on the back part of it. Is the duct in place in front of the tank?
Mar 28, 2008 | Hoover SteamVac F5914-900 SpinScrub...
The water swirts ou put the vacuum does not pick up the water
Make sure that you are using the wet hose and that it's not clog and hooked up tight to the hole in the front of the vacuum.The same place that you would hook it up to vacuum.
Dec 02, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
178 people viewed this question
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Roger Potts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
