Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hotpoint Aquarius WD440 Washer/Dryer
How do I Clean the Filter?
  • green lady 3 May 18, 2009
    does the filter have a little round ball in it - about the size of a ping pong ball? undid hose - lots of water came out. After putting it back together I seem to have a round ball left over - trying to work out if this belongs in the cup shaped filter???
    President:
  • 1,462 Answers
Remove bottom rear panel. you will see a large diameter hose going from tub to pump. undo this hose at the tub end - lots of water will come out. filter is inside this hose. remove and clean
Posted on Jul 17, 2008
My Hotpoint Aquarius WD440 smells of hot rubber when it is on the M (drying) programme and the clothes come out smelling of rubber. Can you tell me why this is happening. Everything is working fine...
Hotp[oint Aquarius WD440 washer /dryer - Has a distinct smell from clothes when washed like stagnant water is lying somewhere in the machine, It has all benn stripped down but cannot find anything wrong. Whats the solution????
Aug 11, 2011 | Hotpoint Aquarius WD63 Front Load...
HI I have a hotpoint Aquarius wd440 1400 spin. i have a problem where it leaked all over the floor. this happened before and when the engineer fixed it he said it was a clogged filter. its now happened...
You should find it located at the rear of the wsher at the bottom.
Remove lower panel, remove large black hose from bottom of drum, filter should be located inside hose, remove and clean.
Nov 04, 2010 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Washer/Dryer,Aquarius WD440 will not take softener.
take out small either blue or green filter from detergent drawer where you would normaly put the liquid softner and run it under hot water tap my guess is that the small pipe within is clogged this should clear it
Oct 13, 2009 | Hotpoint Ariston WD440G Front Load...
Hotpoint aquarius wd440. Flashing lights
press and hold on off button till the display panel lights up.Then press and hold the on/off button and the start /cancel button together.You will now reset the washing machine settings.And just pick your cycle again
Oct 04, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD440 tripping out as soon as program is select
it sounds like you have a direct short in the wiring some where on your machine.the only other option is the main control board needs to be replaced
Sep 16, 2009 | Hotpoint Aquarius WD63 Front Load...
I cant find the filter on the hotpoint aquarius wd440
Depending on which model you have ,there are 2 possible locations for the filter.
Check to see if there is a removable plastic panel at the botom front of washer, if there is then remove it and if there is a filter there , you will see it, unscrew the cover anti clockwise and clean same.
If no filter there then remove lower rear panel of washer,locate large black hose, and remove clip and hose from bottom of tub,be careful as there will be some water run out.
Remove plastic filter and ball ,clean and replace, and refit hose, making sure it is secured properly.
Test for leaks.
Plz rate my solution.
Thanks.
Jan 15, 2009 | Hotpoint Aquarius WD63 Front Load...
Not drying
the steam gets condensed back to water and pumped away so sometimes draining problems cause poor drying. is the machine plumbed in according to handbook?
also your dryer filter may be blocked but this is not accesable without the dryer box being stripped down.
Nov 05, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wd440 flashing dryer heat button and onoff button !
I had to have a tech come out for the same problem two weeks ago. They had to clean the lint collector which you cannot get to on your own. He said now that this has been done everytime I use the machine, take the clothes out and then run a rinse spin cycle.
Aug 04, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD440 Error
Remove the white plastic cover on the back near the bottom. To the right as you look at it their will be a black concertina pipe with a hose clip on its top edge. Undo this and pull the pipe downwards to reveal the filter. There will be a plastic ball inside (which is supposed to be there) remove this and clear out the cr*p.
Re-assemble as removal.
That should fix it
Jul 26, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
1,347 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
