Question about Raymarine GPS
Raymarine gps sounder
On the screen the boat is turned the wrong way. How do you turn it back the right direction?
    Novelist:
  • 113 Answers
This is a common problem if the GPS is hooked up to an electronic heading sensor such as an autopilot. If the heading sensor is not calibrated properly, the boat will appear to be facing the wrong direction.
If you have an autopilot, consult the installation guide and perform the sea trial procedures. That should get your boat lined up properly.
Posted on Jul 21, 2008
My boat is pointed in the wrong direction on my Raymarine C80 chartplotter?
I'm not sure where you would locate "reset to factory specifications". Look for it in the GPS menus (may be in the System) and reset, it is no big deal to reset a GPS, it will not hurt anything. I the GPS is set to back Track. To check this turn your boat around and follow the track on the lake chart. If you and your boat are now going in the same direction the GPS was set on Back Track.
Aug 31, 2010 | Raymarine C80 GPS Receiver
How to hookup RL70CRC to boat wired for C70
There are 5 wires running out of the antenna and the 5 wires that you need to connect.
Oct 30, 2008 | Raymarine Computers & Internet
My Raymarine C 120 GPS intermittently stops working.
I had to replace a GPS antenna unit with cable. Sometimes, during bad weather or strong sun, I lost FIX on satellites. Cleaning the top of antenna did not help. Unit from Ebay was also a junk. Get a new one after testing display on a friend boat.
Jul 28, 2010 | Raymarine C120 GPS Receiver
Sounder picture on e 80 freezes 20 min. after power on.
your feeling is correct on this it is still probably software! but also be aware that the power in connections are very susceptible to vibration and strains and once cracked inside they get a mind of their own. If this is a come and go problem that won't resolve, reflow the solder joints inside the DSM.
Jan 14, 2010 | Raymarine Dsm30 Digital Sounder Module
Boat on screen does not point the direction the boat is going e-80 series also chart will not go course up or heading up like the radar does unit is set in relative motion mode
The direction of the boat symbol is depending on the compass course from the autopilot. You will see that your GPS course (COG) and magnetig heading on the autopilot differs. Solution is to calibrate autopilot compass. Will advice you to not use course up, stick to north up or heading up.
Sep 08, 2009 | Raymarine C80 GPS Receiver
Problem getting a proper fix
The antenna should be replace by raystar 125.
Regards
Michel
May 31, 2009 | Raymarine RL70CRC GPS Receiver
Locks up after a few seconds/have to kill power to reset
This may help. Mine has the GPS antenna build into the bracket at the back. I removed the bracket and the unit did not go into the error screen and the sounder worked fine. The GPS would not locate but it has not antenna attached so DOH!! I have orderd a new antenna with the BNC connector and will post if that fixes the problem. At this point I'm guessing its a blow GPS antenna.
Dave
Oct 12, 2008 | Garmin GPSMAP 168 Sounder GPS Receiver
Keeping course
Please check if the pilot is acting the right direction ,press +10 key and check if boat teers STB,
press -10 and check if boat turns PORT ,if it acts reverse, see handbook to reverse action.
Verify if compass course in standby is indicating correct course .
Do the calibration procedure as stated in in the handbook (360 degree turn)
If it still not indicate the correct course ,or is frozen, compass or printed circuit is faulty.
Check the resistance between the wires of the compass unit .(see google internet)
Good luck
Jean
Sep 11, 2008 | Raymarine RL70CRC GPS Receiver
RAYMARINE
With the charts page up, start by hitting the find ship softkey at the bottom of the screen.If that find the boat on the chart all is good.If not you need to check you have a GPS fix. Go to GPS screen and see you are seeing satalites.
If all is good when you hit find ship and the boat disappears again from chart while underway you will need to go into the chart setup menu and see if the screen amplifier is turned off. If off turn on.This is first place to start. Hope that helps
Jul 13, 2008 | Raymarine A65 Combo GPS...
Raymarine C120
I don't have the sounder so can't address your question directly, but you can download all Raymarine manuals for your gear directly at www.raymarine.com
Aug 23, 2007 | Raymarine E120 GPS Receiver
GPS Logo
407 people viewed this question
Top Raymarine GPS Experts
Steve
Steve
Jon Piercy
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
