Question about Samsung YP-U3 MP3 Player
Mp3 won't charge or turn on
I bought it exactly 8 days ago. It was playing well until it turned off. I thought i ran out of batteries. But it wouldn't charge when i got home. NOthing happened
  • TheRucoon Jul 18, 2008
    Yeah, I am having the same problem! It started skipping and then just turned off. I can sort of see the display of the song that it was last playing, but it'snot doing anything. I tried to look for a reset button... anything, any way to open the thing up to reset it, but nothing! I can't even figure how to take the damn thing apart. Help?
  • 3 Answers
Press the A/B and Menu buttons together to reset.
Posted on Jul 23, 2008
Psp not detecting battery
Sounds like you might need a new power board. I know videogame911 does service PSP's your best bet might be to send it in to someone who can tell you exactly what the problem is, specially if you replaced the battery and still have the same issue.
Apr 23, 2013 | Sony PSP-3000 Black Console
I just bought the eclipse cld and it won't turn on after charging for hours
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Sep 30, 2012 | Eclipse Audio Players & Recorders
2005 Honda VT 750 Shadow Aero will not turn over
Hi, James before testing any electrical component in the Starting System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand, clutch, neutral safety switch.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter have failed or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. The electric starter is working but starter clutch has failed.
14. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2000 Honda Shadow Ace 750 Wont Start Turn over at all
What to do When Your Motorcycle Won Start
Honda VT750C2 Shadow Spirit Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT750C2 Owner Manual
Jun 01, 2017 | 2005 Honda VT 750 Shadow Aero
The battery light on the dash came on 4 days ago on my 2000 Ford Expedition (5.4 l), but still ran ok for a day. The next day, started car, then the radio shut off and I turned off the car and tried to...
When your battery light comes on it is telling you that your ALTERNATOR is not charging your battery! So you need to replace the alternator.
You can verify that it is bad by taking the car or just the alternator to an auto parts store and having them test it for you for free.
Aug 04, 2011 | 2000 Ford Expedition
Swagger MP3 audio player does not hold a charge. I plugged it in overnight and could bearly play a song in the morning.
Most likely you have a full charge but the problem is FALSE Advertising! Swagger MP3 players only support MP3's downloaded from Amazon.com, any other MP3's will only play for a matter of seconds before shutting off. These players are a total rip off.
Nov 19, 2010 | Sakar MP3 Player
Won't Start
bad ground wire on battery.
Feb 07, 2009 | 1997 Oldsmobile Achieva
Samsung YP-U3 MP3 Player Logo
66 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
