Question about Kenwood Heating & Cooling
Broken handle to Kenwood kettle - Kenwood Heating & Cooling
  • 41 Answers
Need more info dan
Posted on Jul 17, 2008
The lid on the kettle as broken need a new handle for the lid 12w08
perhaps you know a wood worker that can turn you a wooden handle .
Jul 21, 2015 | Kitchen Appliances - Others
I wish to register my kenwood electric kettle
http://www.kenwoodworld.com/en-us/customer-services
Mar 06, 2015 | Kenwood Kitchen Appliances - Others
The lid of the kettle has got out of place and cannot be closed
should be two screws on top under lid by hanle and two on bottom this will allow the handle to come apart should be able to reajust lid.
Feb 27, 2011 | Kenwood 100JKP Cordless Electric Kettle
My Braun electric kettle won't click on. Do I need to replace the kettle or is there some way it can be fixed?
It's possible it can be fixed. Ours also no longer clicked. I took it apart and found that the flat plastic piece in the handle that activates the circuitry in the base had broken away from the rocker piece in the base. Fortunately the same flat plastic piece conveniently had a couple of holes in it in a helpful location. I looped some wire through the holes and also around the bottom rocker piece to hold the two pieces together.
I reassembled the kettle and tried it out and it now works fine! Problem fixed.
To disassemble, take the four screws out of the bottom of the kettle. (You'll need the appropriate star bits to do so.) Put those screws in a safe location... Lift off the bottom plate.
Now, the plastic for the handle is held in place by the typical notched clasps used by so many plastic appliances. You unsnap the clasps by CAREFULLY inserting a straight blade screw driver between the handle plastic and the kettle and GENTLY prying the handle plastic away from the kettle. You'll hear the internal clasps "popping" as they snap loose. You CANNOT take the handle all the way off this way. You just loosen it. Now, the top of the handle is a separate piece. Do the same for this. The top will pop completely off.
Next, GENTLY remove the lid. You can slide it a bit up and away. It's a tight fit, so you need to use a little force, but not too much.
Once you've done this, there are two metal pins that hold the main part of the handle to the kettle. They have a little ridge around the top that you can use to pry them out with your fingernail. Once those pins are removed, the handle will simply come off.
BE CAREFUL! The various parts in the handle are now loose! If you aren't careful they'll fall off and you'll have to figure out how to reassemble them.
Now, you'll notice the long flat plastic piece running down the side of the kettle. That piece was hidden behind the handle. It is SUPPOSED to be fastened to a rocker plate at the bottom. If you look at the end of the flat piece at the bottom you will likely see what I did. It had just disconnected from the rocker plate. Take some wire and wire the two pieces together using the little hole-like slots at the end of the flat piece. Just loop the wire through the hole and down around the rocker plate piece exposed inside where the handle is.
While applying this wire, it will be helpful to put a little masking tape across the various handle pieces to keep them from falling off. This is important because you'll probably be wiring the pieces together with the kettle on its side like I did, and the parts will fall off if you aren't careful. When you are done wiring things together you just remove the tape.
Once you've done this, reassemble the kettle in the reverse order you disassembled it.
You'll notice that once you've wired together the two separated pieces, pressing the switch on the top pulls up on the flat plastic piece which pulls the rocker plate which closes the circuit in the base.
Jan 16, 2011 | Braun WK200 Cordless Electric Kettle
I have a relatively new kenwood kettle and yesterday it just stopped working. There is power to the kettle as the red light comes on just nothing else. Can you help?
suspect kettle heating element is defective. if the light did not come on then it could also be the thermal switch which may be sticking. if the product is relatively new you should still have warrenty, recommend contacting your vendor about this problem. Kenwood have a very good customer service network.
Nov 16, 2009 | Kitchen Appliances - Others
My kenwood kettle became wet and whenever I plug it in it turns off all the fuses!! so I cannot use it anymore. any idea how to fix it?
Looks like it is damp on the inside where the electrics are. Discontinue use immediately. You could try to open up the bottom and dry it out, but some do not allow access. So, in that case, a new kettle is in order.
Oct 03, 2009 | Kenwood SK997 Cordless Electric Kettle
Heating & Cooling Logo
Top Kenwood Heating & Cooling Experts
ray gallant
Electro Med Services...
Are you a Kenwood Heating and Cooling Expert? Answer questions, earn points and help others
