Question about Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive
Windows XP driver?
Hi, I purchased a StoreJet removeable harddrive which, according to the manual, shouldn't need a separate driver for Windows XP. However, when I plug it into my computer, my computer detects new hardware but the harddrive never shows up in My Computer. Any suggestions?
Thank you!
  • Anonymous Jan 27, 2009
    Hi, I purchased a StoreJet removeable harddrive which, according to the manual, shouldn't need a separate driver for Windows XP. However, when I plug it into my computer, my computer detects new hardware but the harddrive never shows up in My Computer. Any suggestions? This is Transcend 250 GB Hard drive.
    Thank you!
I have a Transend Storejet 2.5 which goes off whn it gets detected. plz can some1 giv me a solution for this.
Posted on Jan 31, 2009
MY PC WINDOWS XP ASKS TO FORMAT MY STOREJET 25 320 GB TRANSCEND PORTABLE HARD DRIVE
If it's asking to be formatted you need data recovery help. For remote data recovery and do-it-yourself data recovery see http://FreeDataRecovery.us
Sep 04, 2012 | Transcend StoreJet 25 Mobile - Hard drive...
I have Transcend 1TB 25 inch StoreJet H2 USB 20 Portable Hard Drive... not long enough, it's broken; there's a sound "clutch - clutch - clutch"... I cries for my valuable data... Why...
Inside the plastic case of the Transcend StoreJet H2 1TB, is a small circuit board, and a laptop size harddrive.
The small circuit board is an Interface Board.
The harddrive plugs into it, or there are cables which come from the Interface Board, and plug into the harddrive.
The other end of the Interface Board has a USB cable attached to it.
Most of the time it is this small circuit board that fails. Very rarely does the harddrive fail.
(Unless the external harddrive was dropped)
I would suggest removing the harddrive from the Transcend, and putting it into an inexpensive external enclosure.
One example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
Basic guide on how to open the case of the Transcend StoreJet H2 1TB
http://www.youtube.com/watch?v=GvGP6C-rH2U
There are other related videos to the right.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 10, 2011 | Transcend 1TB 25 inch StoreJet H2 USB 20...
I have bafo-bf-1284 usb to parallel converter but i don't have driver cd. problem creating to install this product in windows 7 or windows xp please help me.
The BF-1284 driver (zip file) is available from BAFO support: http://www.bafo.com/menu-support.asp . Scroll down the list to the desired product. The driver is for Win98se and Windows Me. You shouldn't need a separate driver for Win7; the drivers should be in the OS. (See the link on Windows 7 compatibility near the top of the URL given above.) I suspect the driver should also be available in the OS for XP.
If your computer doesn't find the driver automatically, check if the driver is listed in Windows Update as optional updates. (You may have to manually check for updates.)
I hope this helps.
Jul 30, 2011 | BafoTech BAFO BF-1284 Parallel Adapter
I have Transcend storejet 500GB external HDD is nor working pls provide me the software for it. Thanks
click here Click on above link select your model and download driver then install. Also follow below. First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Let me know if you need further assistance. Thanks for using FixYa
Oct 18, 2010 | Transcend StoreJet 25 Mobile 500GB USB 20...
Hi my trancand external hdd is not detected bt my laptop --- dell inspiron 1545 --- windows vista
Oct 11, 2010 | Transcend STOREJET 2.5 HI- SPEED USB...
Need to format my dell with vista on it so I can install XP HELP!
hi..ya you can install but you need the drivers
that supports your configuration for xp.
check it out..
thank u..
rate me..
Apr 19, 2009 | Dell Computers & Internet
Transcend 250 GB Hard Drive not recognized by Windows XP SP2
u may got installation cd for storage device.if not download software from www.transcend.uk  ......... otherwise try for this..
goto control panel...
then goto add hardware...
overthere check out for connectivity
Jan 28, 2009 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
I have just purchased a samsung printer, but it says on the user sheet "according to the policy Microsoft does not support Windows 98 USB Driver and PS Driver of Windows ME/NT. Does that mean I can't...
no, it means if your windows version is win 98, then you need a separate driver for the printer to work with usb. You can use the printer for other versions of windows like win XP and win 2000 or maybe even windows Vista
Jul 02, 2008 | Samsung Office Equipment & Supplies
Driver
What you need to do is email transcend with folowing email address: techsupport@transcend.nl.
They will be able to send the drivers to you.
Mar 18, 2008 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive Logo
492 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Josh Whitehead
Josh Whitehead
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
