Question about Jl Audio 250/1 Car Audio Amplifier
My amp ok so i have the JL 250/1 mono amp and i have been using it for about two years now and hav gone threw a few systems to find one i like and i bought an audiobahn 15" and it is in my truck. when i turn up the volume i get a "pop" sound when it hits and it happend with a few diffrent subs so ni was wondering if you could tell me how to make it stop if i can
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 108 Answers
First thing is to make sure that the 15" subwoofer's RMS power rating (not peak power rating) is at least 250watts. Also, you have to be sure that the woofer is in the right enclosure. I am guessing that since you didn't post a model number for the subwoofer or the type of box it is in (i.e. - ported or sealed) that you are putting the woofers in too small of a box or too big of a box. Trucks typically don't have much room for woofer enclosures, so many people favor smaller boxes. The incorrect box will affect how the speaker cone moves due to the internal pressure in the box. Too much movement without and the voice coil hits the magnet causing that "popping" sound. reducing the gains on the 250/1 can often help.
Posted on Aug 03, 2008
I have a Jl Audio 250/1 mono block amp and the thermal light keeps coming on what could be causing this?
It could be a number of things? 1 to many subs, speakers wired to the amp causing it to overheat and making the thermal light come on. 2 It all depends were your amp is. If it's clear and nothing covering it, obstructing it, Ie sub in front of it, amp inbetween the rear seats and sub.
Mar 04, 2011 | Jl Audio 250/1 Car Audio Amplifier
Need to bridge a JL 250/1 car amp , but I want to make sure I do it right
the amp is a mono block so you cant bridge it. There are 2 set';s of speaker terminals to make wiring multiple driver easier
Jun 13, 2010 | Car Audio & Video
Shuts off when the volume gets turned up didnt do this wen new
A mono amp usually can handle only two 4 ohm subs. You see when you hook up two subs in parallel it drops the ohms too 2 ohms and 3 in parellal drops it to 1 ohms overheating the amp and cause power failure. Unless you bought a Mono amp thats 1ohm stable. But still I've seen cheap 1 ohm stable amps not last long. Also possible your subs are fried too check them with a multimeter and measure each sub ohms.
Apr 06, 2010 | Kenwood KDC-BT838U Car CD Player
I hooked up my two 10 inch JL Audio W3v2 2 ohms to a mono JL Audio 500.1 amp and the subs will not work. I have the subs wired in a series. I then hooked them up to my friends amp and the subs worked. Any...
try one at a time. if they work then try hooking them up differently. if none work, then check to see that your amp is not in protect mode. if amp is ok, then check to make sure you have your rcas connected to your amp. in other words, re-check all your wiring. if still nothing, try your amp on your friends car and vise versa.
Apr 01, 2010 | Jl Audio 10W3v2 Car Subwoofer
JL audio 250/1 not powerful enough for pioneer TS-W307D4?
you should move up to more power....underpowering subs is bad! try not to go under the subs rms by 5o watts?
Jul 02, 2009 | Jl Audio 250/1 Car Audio Amplifier
1 10 jl jl 250/1 mono block amp cuts off an on help
your subwoofer is wired incorrectly to your amplifier. Figure out which ohm load of subs you have and then what ohm load options your amp is stable at. Next go to either the Crutchfield website. find their learning center. go to subwoofer wiring diagrams. or go to www.the12volt.com and find their section on it
Jun 11, 2009 | Jl Audio 250/1 Car Audio Amplifier
Which amp do you guys prefer will bumps better on the jl 12w3v2?
jl audio is a good name to stand by for amps kickers amps sound good at a high vol but not at a low vol
Nov 30, 2008 | Jl Audio E1200 Car Audio Amplifier
Jl audio 250/1
ok what is the amp out put of your altanator and were did you hook the romte turn on wire two. It is usally blue.
Jul 20, 2008 | Jl Audio 250/1 Car Audio Amplifier
My JL subs just dont beat like the ONES IVE HAD before as well as the ones my friends have had
sounds like they have your sub amp in mono but they put the speakers in series which totally cancels the benefit of running your amp in mono. you will probably be happier if you just hook the left speaker to left plus and minus and the right to right plus and minus. Cuz even though subs aren't directional they do pass some higher frequencies that are and that dilutes the stereo effect.
Jan 19, 2008 | Jl Audio 500/1 Car Audio Amplifier
Jl Audio 250/1 Car Audio Amplifier Logo
115 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
