Till now i can not get tiscali working in my computer. is still dificult to set broadband. since got tiscali broadband i have never used it, but iam still paying. I tried to contact you over the phone but could not get throuhg. Please I need help to fix the problem. Iam mr. Bernardo, and my phone is 07943342799. please I'm waiting to hearing from you. many thanks
  • 981 Answers
You're not really acting sensible, and you have not described what is difficult about uh...setting broadband. Setting it up, I suppose. I mean, if you set it up and then some thugs come by and rip up the cords, that would really set your case apart. Which is weird for country 79...Belize or Brazil? Have a friend whose Tiscali service works show you what her configuration is so you can copy what isn't privately hers, and indicate what works for her, and help call the company and find out what's going on, rather than wait.
Posted on Jul 19, 2008
Tiscali login
I would suggest that it's probably your computer that is getting slower. Try checking your machine for viruses/malware. I suggest using CCleaner and Defraggler from Piriform.com (both free for personal use). I would also suggest using Microsoft's Windows Defender Offline, to make sure it's clear of anything (use a "clean" machine to create the software).
On the router side, check to see if there are any firmware updates. Also, determine if your router supports 802.11n...if not, consider upgrading.
Sep 07, 2014 | Belkin Computers & Internet
Hi I'm looking to install a DG834G router to give wireless access but the only instal disc is from AOL and I'm not with them anymore, I have tiscali broadband. How do install the router if it won't plug...
Try NOT using any install disk.
Turn the TISCALI router off.
Turn the NetGear off.
Use an Ethernet cable to connect from the LAN port on the TISCALI router to the WAN port on the router.
Use another Ethenet cable to connect from one LAN port on the router to the network-port on your computer.
Turn the TISCALI on. Wait 60 seconds.
Turn the NetGear on. Wait 60 seconds.
Restart your computer.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like: Default Gateway....192.168.123.456
Note that the '123.456' will be some other numbers.
Start Internet Explorer.
Type http://192.168.123.456 (substitute the current values)
Login to the web-server running on the router.
Run the "Wireless Networking Setup Wizard"
to configure a SSID, an encryption-level (use 'WPA')
and a password for your network.
After the router restarts, you should be able to get wireless access, using the SSID and password that you configured your router to use.
Sep 29, 2010 | NetGear DG834G Router
Ive lost the set up disc and i want to put tiscsli on my laptop
Unfortunately you can't download the Tiscsli Broadband setup CD from the net.
Call the Tiscali Broadband Support Team (0871 222 3311) to request a replacement CD.
Regards.
Dec 01, 2009 | Computers & Internet
Netbook won't connect to my home network
I re-typed in the WPA number in the new netbook, which has now got it working. I found the WPA number by typing in a number Tiscali gave me to search for my router information (Netgear) in the search bar on my main computer and getting my WPA key from there.
Dec 27, 2008 | Computers & Internet
Tiscali broadband wireless connection. Router modems last 6/7 wks then won't connect
Hi, have you got filters on all your phone lines, including  a sky box if using one?
Oct 20, 2008 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
Siemens modem does not connect
If you are using modem (Gateway)
Acess the GUI (192.168.1.1)
1. Set to PPPoA
2. VCI - 0 , VPI - 35
3. Enter usename and password provided By ISP
4. Select Keep Alive
5. Save Settings
-In case wont work try to unplug the modem for 10 sec. and plug it back wait for lights to be stable.
-Try to check i nternet connection.
Hope it will help you
Oct 01, 2008 | Computers & Internet
Tiscali Siemens SE587 router
I have solved my problem, after researching various messageboards yesterday to try and discover why my Siemens Tiscali router didn't work. I'm going to send it back and go with another company!
It seems there has been a lot of debate on these messageboards about Tiscali and/or Siemens products and it now seems also that no one would recommend them. I hereby add my name to that list.
Aug 19, 2008 | Computers & Internet
Help with my router
You did not have this problem before because port forwarding was set on the previous router settings, or you were using a modem ( no firewall) .
Here are instruction for port forwarding
Here are more instuctions
One last thing, if your computer is powerful enough (1gb memory would be good), use Azureus, is much better.
Jun 08, 2008 | Linksys Wireless-G Broadband Router
Setup siemens se587wlan dsl - tiscali
For RandomButton
Log in to router and change signal number to the highest number, you may also want to try and move computer to different area in the house
Jan 30, 2008 | Computers & Internet
No connection
what you should have bought was a ADSL modem/router, but if you only have a router, try the following:- go to the TCP/IP properties of your network card and ensure that it is set as obtain ip address automatically, restart the pc. Connect modem to the router then connect your router via rj45 cable to your pc, then type 192.168.1.254(This should be the default gateway) into your internet browser to get to the router settings. Look for DHCP and enable it to give your pc an automatic ip address and save settings. You should now have a 100MBPS connection to the router, if you have got a modem router ensure that you have the correct Tiscali settings inputed.
Oct 09, 2007 | 2wire HomePortal 1800HG Router...
Computers & Internet Logo
David Payne
David Payne
